» Prop Rod - resto to a runnerby rsv1cox Today at 7:32 am
by roddie Today at 6:12 am
» Looking For Comet Tri-Pacer
K&B Torpedo .19 Green Head CL Needle Valve
Can anyone show me a photo of the needle valve parts (all parts). I have one that is definitely missing stuff and want to see what I'm I'll need to find or make. Thanks, Dan
rueschda@gmail.com- New Member
Re: K&B Torpedo .19 Green Head CL Needle Valve
K&B made two styles of needles for this engine. The one version was what looks similar today known as the K&B universal and they made a racing style. The universal uses a spraybar, a needle, a ratchet clip and the nut to retain it. The racing style doesn't use a spraybar. It used two separate pieces. The needle itself passed through the venturi and not a spraybar which opens up the cross section of the venturi allowing for more air. I do have a .19 and I just equipped it with a original new in the package needle and spraybar. I will post pictures when I get a chance today.
In addition, a important factor to this engine is the aluminum insert which goes into the venturi. This also takes up choke area and is critical to proper fuel draw on suction. These were typically removed by many and are no longer present in the engines. One thing to note about the spraybar assembly is that nut which retains the bar is on the ratchet side and not on the entrance side.
My example no longer has the green head, the cylinder and head itself were turned down to fit inside a speed plane. I blued the head and left the cylinder head mill finish. I should paint the head as I found a very close match and recently re painted a Torp.35. So far the paint is holding up nicely.
Re:K&B Torpedo .19 Green Head CL Needle Valve
Ken, Wanted to comment to you on this thread. You brought up some important things, I appreciate your knowledge here much. I was shortly gifted an almost brand new Green Head .35. it was minus the carb insert. Fortunately, I have a parts engine that gave up the correct carb insert. The .35 did come with a brand new in package needle valve assembly. I only bring this up as the package states it fit's .19 & 45 engines with the original price of only $ .50. The .09 to .15 must have used a similar same needle valve assembly for those engines I guess? Not to hi-jack this thread, Last year we talked about the K&B series 75 .35 engine which I had been having issues with the engine speeding up after launch. You suggested a uniflow fuel tank, and you were right with that suggestion. Just wanted to get back with that information to you, A big thank you my friend.
Eddy- Silver Member
Eddy, I do have the .09 Torpedo and the .15 as well. The .09 has the stock needle valve but the .15 I have is using a old Austin Craft. I like the Austin Craft as it was a high quality inexpensive replacement. My .15 runs quite strong. I also have two of the .15 rear rotor versions. I think they're the most beautiful engines ever made.
Ken, I remember those Austin Craft needles, used to be advertised in America's Hobby Center and other shop catalogs and nearly every hobby shop engine section. Now that I think of it, they used to advertise occasionally in the modeling magazines.
While we're discussing Greenhead 19s...Has anyone got a spare prop driver for the Greenhead .19? I have one here that is minus the whole front end...the nut and washer I can make if needs be-but the prop driver has a D-shaped hole-to engage with the equivalent male D-shape on the shaft. [And you need a broach to make those accurately] Have searched fruitlessly on Ebay for a GH19 one (as well as trying other brands such as OS for size...with no luck).
ChrisM
ChrisM
ffkiwi- Gold Member
» k&b 19 torpedo green head
» K&B .35 Torpedo Green Head
» Tip: Green Goo Clogged Glow Head
» K&B Green head torpedo .35 - It worked
