by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
Tee Dee .010 Needle valve setting
Greetings- FYI.... my Tee Dee .010 required me to open up the needle valve 6.5 turns to start and run. Kind of unusual, I thought. Anyone else have similar experience?
rfara- Moderate Poster
Re: Tee Dee .010 Needle valve setting
Hey man sorry no one has replied ! The instruction sheet says 4 turns , I have had to open my a little further before . have you inspected the spray bar hole ? If you can see it open the needle and put the filler on the end nipple and give it a good squirt !! Hold the engine upside down as not to flood it ck. your stream at 4 turns if it dirty this will help clean it also + I have took the needle out and used my finger on the insert and pressure it . >> https://drive.google.com/file/d/1Lsh_5irMK8e6VdAIzW4TSCNQrrUC3Ui1/view
» .049 Needle Valve Setting Too Touchy
» Setting up a poll
» Carb setting getting rich in the air?
» Re-setting a piston?
» fuel pickup tube spring
» Setting up a poll
