» A choke-tube with velocity-stack configured Beeby roddie Today at 8:23 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
Getting ready to get ready - Running the CW Testors/McCoy engine
I think these engines were only used in the "big" Cosmic Wind models.
Designed to break-away in a crash they sit in a saddle inside the fuselage. The bolt is there for nose weight only but I used a longer example plus a shim at the top to hold the engine in place for tests. 2X4 provides a stable platform, I have tried 1X2's before but they are subject to vibration. 3/4" hole for the fuel tank plus 3/8" for the bolt holds it secure.
This engine is my test mule, uncleaned and missing the roto-matic starter but with good compression.
Field box battery is dead and needs charging. Fuel, I don't know. Very old Cox 25% or Traxxis.
We shall see.........
Re: Getting ready to get ready - Running the CW Testors/McCoy engine
I have read from several people that Traxxas top fuel is not of very good quality for this reason I do not use it ... But surely the problem is the oil content so with castor oil added I imagine that it does the job I too am going to have to test some engine when the outside temperature allows me here in Canada Quebec the temperature warms up Summer activities will start soon
davidll1984- Diamond Member
Well, that was easy.
Battery fully charged, Cox 35%, needle four turns out, prime in the intake and one exhaust port, third or fourth flip and it just took off running great. I didn't even adjust the needle. Took a couple of pictures, ran the tank out. Now I want to mount and run three at the same time on that 2X4.
Always fun to do bench runs, I enjoy it often……. Three at one time?… That’s ambitious!!!…. Prelude to the tri motor tether machine?… I hope so
rdw777- Diamond Member
rdw777 wrote:Always fun to do bench runs, I enjoy it often……. Three at one time?… That’s ambitious!!!…. Prelude to the tri motor tether machine?… I hope so
Thanks Robert, I hadn't thought of that. A Tri-motor! I have been thinking P-47 likes. Maybe another ground tether or a Ford Tri-motor...........
Engine leaking a bit. I haven't disassembled it, some had case gaskets some not. Bolted onto the 2X4 it had no centrifical force to pick up all the fuel. Going to take it apart and see what was left.
Darn good runner with no pampering.
Good to hear it didn't misbehave starting and ran good , is the engine mount the back plate for the CC?
getback wrote:Good to hear it didn't misbehave starting and ran good , is the engine mount the back plate for the CC?
Thanks Eric.
It ran really good. Offered no trouble at all. Gave it a little after-run pampering. Covered with spent castor, a bath, a litlle hair drier and we're back in business. Completely emptied the tank too.
But, venting on this fuel tank has me confused. How do they do it!!! With most if not all others you have holes or nipples marked fuel or vent or as with the Cox Babe Bee's just a couple of smoke stacks sitting up there. Not so with this engine.
I thought I had it figured there is a hole just above the mounting screw on the exterior
and behind the tubing in the tank is a dimple which may be a hole - shown here in white for clarity. I thought they were connected, but notice on the white tank there is no exterior hole.
Testors made two different fuel tanks and color is not an indicator. I have orange tanks with and without the exterior holes.
Inquiring minds would like to know??????
The orange one has three holes on one side i bet the center one is the vent ? Is there a hole in the back ?
getback wrote:The orange one has three holes on one side i bet the center one is the vent ? Is there a hole in the back ?
The center hole on left-upper group is a mounting-screw hole.
Here's one of mine (white one below). Those other two holes don't go through. I don't know what they're for. Maybe for tooling.. mold-release??
It appears that the "fill" becomes the "vent" once the filler-hose is removed. I just don't understand how the tank could be filled if the needle-valve was all the way closed. Maybe Testors instructions said to open the needle-valve prior to fueling? It would of course be open when "re-fueling".
The below instructions "do" say to open the needle valve first (see step #1).. but also say that fuel will squirt from the vent when full..
Three holes in the back Eric, drill throughs for the mounting screws. Not connected.
I put the orange tank/mount in water and blew low pressure air through the top hole of the three. The lower hole is blind, the center for a mounting screw and the exposed top blows air into the tank by the fill hole providing the vent. But that doesn't explain the white tanks no-hole vent. Still working on that one.
Your a sometimes cook Eric. I baked a yellow cake this afternoon........my weakness. Covered it with chocolate frosting. By 6 pm a quarter gone.
Edit add:
Ah roddie chimed in while I was typing. Nifty picture with the sprouts coming though the mounting holes. But I did get air through the top hole into the fuel tank so I'm thinking that has to be the vent.
More added stuff:
"It appears that the "fill" becomes the "vent" once the filler-hose is removed. I just don't understand how the tank could be filled if the needle-valve was all the way closed."
My needle was open four turns when I started it. But - the filler tubing fills the enterance hole completely. There has to be a vent to allow the fuel to pour in. Either that or it comes in through the tubing to the NVA flooding the engine which it didn't.
There has to be a vent hole in the tank somewhere. It probably is quite small as in that dimple I pointed out in the white one. Remember when Cox the BB went to the single stack with the very small vent hole in the backplate. When I applied air pressure I was getting air out around the filler hole. Still can't figure the no hole examples. The Black one I have has no hole there either.
Nice picture roddie. Think there must be an opening in the plastic between the top hole and the filler hole. Short distance. I could be wrong, so will check again. Glad someone else has an interest in these.
I gave up on it, an unimportant mystery that will remain that way.
I just do not know how it vents when the fueling tubing is tight in the hole yet fuel flows into the tank and not out through the NVA supply tube. It has to vent somewhere. There may be enough looseness between the engines fuel line and the tank for air to escape. I dunno!!
This morning I filled those two vacant holes with water and it drained nowhere. It's possible that yesterday I did not have the compressed air nozzle tight against the hole. But I did get air bubbles into the tank.
rsv1cox wrote:I gave up on it, an unimportant mystery that will remain that way.
I think you're correct in that the engine's fuel-line is not a tight fit where it exits the tank. It might be designed that way for ease of replacement without having to remove the engine. When viewing the instruction sheet; what Testors refers to as the "vent".. is to the right side of the fill.. which is where the engine's fuel-line exits the tank.
and then there's this tiny dimple.. which would seem to ensure venting; should the other venting system become blocked. It would also be washed with fresh fuel every time the tank is filled.
The fuel-filler itself is a lousy design in my opinion. A place for debris to accumulate.. and end-up inside the tank. A nipple would have minimized that hazard.. but Testors didn't go that route for some reason.
Thanks roddle, the nipple is the better idea. I have never provided a good picture of that filler hole, so........
and............."it's a little known fact"...........Cliff Claven mailman CHEERS 1990ish
that the Tyco SkyHawk is just a Testors Cosmic Wind in disguise.
(It was under the Skyraider when I pulled it out for pictures.)
NICE CAKE !! Sweet and sour chic. rice no pic. mostly gone LOL still working on my pizza skills one-two a week pizza day ..... That is just weird the filler hole? and venting at the loose hose going at the mount ! Glad you got some help and figured out what the deal is .
getback wrote:NICE CAKE !! Sweet and sour chic. rice no pic. mostly gone LOL still working on my pizza skills one-two a week pizza day ..... That is just weird the filler hole? and venting at the loose hose going at the mount ! Glad you got some help and figured out what the deal is .
When all else fails........contact Kim.
» testors mccoy running poorly video
» The troublesome Corsair engine, the gruesome twosome, another Hero Testors McCoy .049 and the yellow prop returns.
» Testors/McCoy Spraybar ID
» Wen-Mac/AMF .049 FRV MK XI, running on 30+ Y.O. Sig Champ. 25
» Testors/McCoy .049 smoked...
