by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
Another C.T. engine rebuild completed -- this time a Cox Tee Dee .049
This Cox Tee Dee was in fair shape, compared to the .051 engines (especially the KK .051!)
Below is the before and after picture:
As on the KK engine, the prop driver was stripped and could be pulled of by my fingers.
So, that needed replacing ----- also need to order a thrust washer as it was missing.
Unscrewed the venturi and this needed to be replaced as it was severely corroded.
Removed the venturi body nut and the "black" venturi body.
Order a replacement as the original venturi body was cracked in 3 different places.
The piston was stuck --- not much of a problem with some oil and heat it freed up easily.
Backplate unscrewed with no problem and also unscrewed the cylinder head and sleeve.
Then removed the piston/con rod from the crank.
Placed everything into the sonic tank for a cleaning. (20 minutes)
The engine cleaned up well --- the sonic tank got the "gunk" off.
The bluing on the sleeve looked o.k.
I took the aluminum parts to the buffer and touched them up a little.
Reworked the needle valve by removing the lead solder and "silver" soldered the needle valve extension as the silver solder is stronger than the lead solder. (and it was loose anyway)
I had this Kustom Kraftsmanship Throttle ring and decided to give it to C.T. for this .049.
I have it on my other Tee Dee .049 and works out well.
One thing that I have noticed from the KK throttle ring over other throttle rings is that 1/2 way on either side of the exhaust ports in the ring there is a "hole" exactly in the middle of them.
Interesting thing is when the ring is wide open the hole is shut off.
But at a little past 1/2 throttle the hole is uncovered to the one exhaust ports.
I have some Cox throttle rings and some Ace R/C rings and they don't have this little hole?
Photo below of the KK throttle ring.
Anyway,
After the light buffing on the aluminum parts, I placed the parts back into the sonic tank for the final cleaning before assembly.
Reassembly went on without a problem.
I reset the piston socket, installed the "new" venturi body and tightened up the venturi nut, pressed the prop driver on (and installed the thrust washer).
Installed the piston onto the crankshaft and screwed on the backplate.
Checked the deck height and used one of the four shims that Burnie/Matt sells but had to sand it down a little to .009" (0.23mm)
to get the setting just right.
Tightened down the cylinder and installed and tightened the glow head.
Installed the new venturi and the old needle valve, also added a small piece of surgical tubing on the needle valve (for a seal).
Added the new spinner, the starter spring and a socket head 5-40 bolt.
Now she looks like brand new again!
Hope you like the KK throttle valve on it as now you'll have another engine with throttle control C.T.
Anyway,
sosam117- Diamond Member
Boats13- Silver Member
Re: Another C.T. engine rebuild completed -- this time a Cox Tee Dee .049
It's beautiful work, I've never seen this model of restriction ring wit Mabe idling hole ? At least that's what it looks like! CT I think you're going to have good engine well tuned for new projects
davidll1984- Diamond Member
davidll1984 wrote:It's beautiful work, I've never seen this model of restriction ring wit Mabe idling hole ? At least that's what it looks like! CT I think you're going to have good engine well tuned for new projects
Yes, sir, I believe so!
David
» Tee Dee Engine rebuild
» Engine rebuild help please
» Nice -- New -- In Good Shape Tether Car with a "New" in the box Enya .10 engine for it! **** NOW COMPLETED ***
» Coper Reed valve melted too mutch détergent in fuel mixture
» Engine run time?
» Engine run time?
