» Fun Times Keeping Busy With Lead.....by getback Today at 8:44 am
» Feed Station Zebra.. Spring 2024
by roddie Yesterday at 8:30 pm
by balogh Yesterday at 5:17 pm
by GallopingGhostler Yesterday at 3:12 pm
by cstatman Yesterday at 1:41 pm
by Myk Mon May 27, 2024 10:26 pm
» Scientific Gulfhawk
by roddie Mon May 27, 2024 8:59 pm
» Memorial Day 2024
by roddie Mon May 27, 2024 8:48 pm
by rsv1cox Mon May 27, 2024 5:31 pm
my attempt at making an exhaust throttle for Cox .049
I bought some .750" OD Aluminum tubing.. hoping it would be a candidate for my muffler design. It's just a 12" length piece.. which is good because it won't work for what I originally hoped.
The tubing might work-out for making cylinder-sleeves as exhaust throttles.
Shown below with your "garden variety" Cox .049 cylinder inserted..
.5885" pipe ID..
.5935" cylinder-neck OD on crankcase...
Deburring the pipe's "bottom" to fit the case.. along with a cross-drilled "relief-port".. might work. We'll see...
.5885" pipe ID..
Re: my attempt at making an exhaust throttle for Cox .049
Roddie, a very interesting project. Remember though when designing the ring internal diameter, that aluminum has about 2 times higher thermal expansion coefficient than steel, therefore when fitted cold, the throttle should be sitting on the cylinder almost tight, so as when running hot, and expanding more in diameter than the cylinder, there should still be a very small radial gap that, if excessive, would compromise sealing for an efficient throttle.
I make my home made exhaust throttles out of thin aluminum coil cut from beer cans, wound around the cylinder neck with free ends allowing free expansion with no diamater increase, and use a steel circlip to keep them tight on the cylinder neck even if hot..a photo below, showing my March 2024 COX engine of the month winner queenie features such a DIY exhaust throttle on a thin wall No1 cylinder with a bottom flange on it, that would not allow the use of a normal throttle.
I keep watching your posts with excitement.
Nice work Guys. Way beyond my skills
Greenman38633- Gold Member
Good start Roddie, Will be interested to see what you come up with!!…. Throttled engines are fun to play with
rdw777- Diamond Member
Even a little loose the ring still changes the rpm just less efficient for very low rpm I like the idea of an simple rc silencer
davidll1984- Diamond Member
I measured, marked/scribed and cut a ring from my 12" length pipe.. to the approx. length of 7/16".. using my new "Rigid" cutting-wheel plumber's tool.
This gets it fairly close..
Then I used my deburring tool to gradually produce a beveled slip-fit.
Not sure how I want to proceed.. Cut a groove for a clip-ring I guess.
So.... the ID of the clip-ring is .692" and the OD of the barrel is .748".......... That's a difference of .056". A groove in the barrel that's .028" deep should then measure-out to that .692" diameter. If I go halfway; with a .014" deep groove.. that should be adequate for the clip-ring to seat and hold position.
I'm planning to make a mandrel for the barrel; that I can "chuck" in my VSR drill and either file a groove.. or use a Dremel/cut-off wheel. I'm leaning toward trying one of my V-cutting riffler-files.
I bought those file and rasp sets 30 years ago at a local job-lot outlet... on the cheap.. and have used them countless times for different things.
The mandrel... I made from one of my 1/4" square-drive socket-wrenches.. and some D/S foam tape.. (the same concept I used to finish-sand my aluminum muffler-rings..)
I'll admit; I wrapped X3 sockets before I arrived at the size that worked.. peeled the adhesive-liner from the D/S tape... and applied the talcum-powder (anti-sticky) treatment to the exposed adhesive.. but the fit was so tight.. that I couldn't get the barrel to go on all the way. I ended up using triple antibiotic ointment for its petroleum-jelly base to get the barrel all the way on. A comedy of errors.. but I managed to cut a groove which was deep enough for the clip-ring I'd picked-out.
It's a redneck way to do it.. I know.. but I don't have access to the machinery that I used to when I was employed..
So now......... I'm wondering if I can simply drill a "cross-hole" for the exhaust-relief.. or does it need to be a pair of "slots".. 180 degrees apart? I blocked the crankcase openings (crankshaft and backplate) and with cylinder and barrel installed; used my mouth to blow-through the top of the cylinder. Some very slight leakage is present.. but I think I have something that will work.
I'm hoping that this will work on the stepped-wall cylinders.. as well as the "two-slit" type. We'll see..
Very well done, Roddie, looking forward to seeing the end product. I would suggest a rectangular relief to be cut instead of 2 holes drilled, even if this is less difficult..the latter will block the exhaust even if fully open..
Redneck or not you are getting it done with Good progress , like the file set handy to have , drill two holes side by side and file out the rest to get the oval hole is what i would do but its ur puppy .
Great work Roddie!….Just for reference on the round hole type: I have one on an .049 I use in my Zoomslot Saucer…. Idle’s great when fully closed but will not kill the engine…. The hole size is a #23 dill …. Obviously smaller area than the cylinder’s exhaust port but doesn’t seem to take away top end….. Photo for reference of the hole to the engine’s port…. The lower left corner of the port is the last to close (I don’t know if that makes any difference). The engine has SPI…I used it as a model for a homemade throttle for an .020…
I have a rectangular port factory throttle on an .020 that works good as well… Just don’t have one in .049 to measure for comparison…
Thanks guys, The "drilled-hole" (#23 drill, thanks Robert) is what I'm going to try first.
» Tee Dee .09 exhaust throttle
» Cox .010 exhaust throttle... the U.E.T
» exhaust throttle idea-redneck
» exhaust throttle ring - again
» Texaco and Exhaust Throttle Sleeve
