» 12 string guitar suggestions by 1/2A Nut Today at 1:58 pm
by Admin Today at 1:11 pm
by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by rsv1cox Today at 7:32 am
Cox 045 power pak engine
Hi everyone Im currently restoring a cox thimble drome special with the 045 power pak engine I need a bit of advice on two problems I have 1 what is the best way to unfreeze an engine I currently have it soaking in isopropyl alcohol to get rid of the baked on castor oil and number 2 the engine looks like it's been apart before there is only one Reed valve in situ when there should be two is there a replacement Reed valve I can use or is there a Reed valve that fits the 045 off another engine ??
Any guidance would be a great help
Thanks
Graham
Thanks
Graham
Wiggy- Moderate Poster
Re: Cox 045 power pak engine
It looks like a Space bug /Jr. reed set have you looked at the breakdown ?
https://drive.google.com/file/d/1B6bSvican1D-l6EnFDQXkRClxGeA-Pus/view Have you got the engine rear end out of the car ? And it will run OK on just one reed and Yes there hard to find but not impossible .
Here is one but don't know if its the inner or outer one is thicker https://www.ebay.com/itm/155749157055?
Thick one is the outer > https://www.coxengineforum.com/t10877-how-to-arrange-thermal-hopper-reed-valve-components?highlight=space+bud+reed
» Reducing Engine Power
» Engine size and pulling power
» Cox 140 Beaver
» Testing model engine power output question
» 010's more run time and POWER I MUST HAVE MORE POWER WMAHHAHA
» Cox 140 Beaver
