» A choke-tube with velocity-stack configured Beeby roddie Today at 8:23 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
I'm newcCoy or Cox
I'm newcCoy or Cox
Hello...no apologies but, I am new to all of this and looking for a little education.
I like the idea of starting a collection of vintage engines...my day had a couple of McCoy airplane engines and that was 50 years ago! (damn, am I that old already??)... anyway, I see some for sale on eBay for $15 to $70 dollars...they say, "glow plug / nitro...my question cos this...can I still buy nitro fuel and glow plugs for engines built on the 50s'..60s'..??
Appreciate you all putting up with this newbie!!
Hope all have a great weekend!
Kell
Kell
Kjemison- New Member
Re: I'm newcCoy or Cox
Of course we can still find fuel and glow plug sometimes even parts But you have to know where to look and what to look for... if you want to buy an old model of engine, know that you will have to mix castor oil in today's fuels, the manufacturers no longer offer fuel specially designed for them but you can mix to have the right amount of oil and the right type of oil It's important to use castor oil Regarding the choice of engine I would tell you a small .049 Cox will be a good little engine to have fun with.
davidll1984- Diamond Member
Welcome to the Cox forum Kjemison. Yes fuel and glow plugs are still available and parts for the Cox engines are also available from our favorite venders and sponsors here . McCoy glow stuff can be hard to find but there are swap shops that usually have lot's of used McCoy's at reasonable prices. The ignition McCoy's are higher in price and can run into several hundred dollar range. Hope this helps you ...
Mike1484
Mike1484
Mike1484- Gold Member
Fuel is not a problem...even if you have to mix it yourself. PARTS are the problem....simply because if you are interested in typical 50's or 60s eng ines.... then most of what you will find for sale will be second hand and well used. New in box examples will be few and far between-and premium priced.
Affordable engines will normally have both cosmetic wear-faded paint, chipped fins, scratches, burred prop nuts, etc and also real internal wear. Cosmetic wear/damage can often be cleaned up....some of us here get a buzz out of restoration of 'basket cases'...but if you want to run your engines-or use them in models, then the internal state becomes a consideration. Conrods and wristpins are two areas where wear becomes quite apparent, along with bearing and cylinder [and I've stated these in approximate order of occurence]....now ballbearings can be replaced...a worn plain bearing is another story....yes it can be done-by skilled machinists...or in the case of a worn unbushed crankcase, a bush can be fitted-again by a skilled machinist. Likewise rebores-but in both cases, there are few people capable or willing to do such work-and they charge appropriately.
Moving to the mundane-you cannot fully assess wear without dismantling the engine-in doing so you will almost certain damage the gaskets-and in the unlikely event you don't it is still good practice to replace the gaskets on reassembly. So now you need gaskets-for engines made 50 or 60 years ago-only a bit of thick paper-but usually vital to operation. Fortunately there are a couple of people who specialise in gaskets for long out of production engines-check out 'RC Gasket Company' on Ebay-and also 'the-old-engine' also on Ebay.
Conrods are another issue-they are prone to wear at both top and bottom (hardly surprising!) and replacements are VERY thin on the ground...you can make a conrod with simple tools with care-it may look a bit agricultural compared to a machined one...but it will do the job. The alloys now are a lot better so your hand made replacement may give better service than the original.....providing it is accurately made. The elephant in the room of course-is ideally you'd need an OEM rod to measure from to get the centre to centre distance for the bog end and little end bores.
Then there are the things that happen in a normal working life-models get crashed-if you're unlucky the shaft gets bent-and THAT is a tricky thing to deal with, if you are a bit luckier you break or bend a needle valve assembly....which is why these are often the most common spare part you find in a shop....and equally-why it is nigh impossible to find an original spare from the 50's 60's and 70's....they've long since been purchased by people fixing THEIR damaged ones...
....so you have two choices-MAKE a replacement....tedious-but not impossible-and requires a lathe at the very minimum......or fit a needle valve assembly from another make.
So yes-go ahead -it quickly becomes an absorbing interest-but there is quite a lot of work involved-depending on where you want to go with it...some people are happy to collect for sentimental reasons "I had these when I was a kid" "my father had these when I was a kid"; others are attracted to a particular make-for whatever reason-in my case as a junior, I acquired an ED Hornet from a schoolmate, not much later-a few months at most- another-an ED Bee Mk1...and all the time you're reading Aeromodeller or MAN or whatever the magazine was in the library...and you see the ED (insert the brand of interest of your choice) advert and think "wow-imagine having all of them'....and years later, you realise that 'hey I do'-i've acquired them here and there...and I do. Now I have a collection of over 900 engines-not all rare and exotic-many quite mundane.
There are people out there who collect only Fox engines...and have spent a lot of time tracking down and acquiring very single size and submodel-of Fox engine...you could do the same with Super Tigre, or McCoy or OS or Enya....or..TA DA..Cox engines....
The take home message-engine collecting is enjoyable-and can become a lifelong obsession-but it requires patience, an ability to ferret out things in unlikely places, goodwill-without swapping, trading and favours owed and received you won't make much progress, good dexterity, and over time an increasing set of skills...to end up with a collection others will admire and perhaps envy.
ChrisM
ChrisM
ffkiwi- Gold Member
