» Looking For Comet Tri-Pacerby DanMc Yesterday at 7:25 pm
by 944_Jim Yesterday at 7:04 pm
by 944_Jim Yesterday at 4:31 pm
by balogh Yesterday at 4:08 pm
by rdw777 Yesterday at 3:58 pm
by rdw777 Yesterday at 3:46 pm
by roddie Yesterday at 3:07 pm
» Removing old decals
by latole Yesterday at 3:06 pm
by rsv1cox Yesterday at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Yesterday at 11:52 am
by getback Yesterday at 6:46 am
by GallopingGhostler Yesterday at 6:33 am
Micro equipment for DX5 Xmiter question
Can anyone tell me where I can source micro RC equipment that is compatible with a Spectrum DX 5 transmitter, I intend to build some Guillows 500 series planes for micro electrics.any help would be appreciated. Thanks
akjgardner- Diamond Member
Re: Micro equipment for DX5 Xmiter question
I wonder if the dx5 use dsmx dsm2 protocol? Personally I use a good dx6i dsmx dsm2 and easy to find compatible micro radio reciver i use this
this Very small and very light receiver used with strong micro linear servo also very light less than two grams each The system works with 1 cell lipo battery also possible to find model with integrated esc for brushles that work wit 2 cell But often use the as3x micro receiver The as3x receiver is very effective, helps stabilize the model and gives the impression of a larger and more stable model but more complex installation and programming
davidll1984- Diamond Member
Thanks Daviddavidll1984 wrote:I wonder if the dx5 use dsmx dsm2 protocol? Personally I use a good dx6i dsmx dsm2 and easy to find compatible micro radio reciver i use this
I cant say for sure but i would text / call them and asked it is there radio anyway and bee easier ;look on there site >> https://www.spektrumrc.com/vehicle-receivers/ i have a SR 310 > https://www.rcsuperstore.com/spektrum-sr310-dsmr-3-channel-sport-receiver/ <
i think and spectrum mini and micro servos and futaba will work just cut the ear/line up plastic off and plug
Thanks Eric, I e-mailed them and R waiting for their reply
I hope they can help you with getting what ur looking for !?!
That is a surface receiver and will not bind to the DX5 unfortunately. Something along the lines of what David has posted would be your best bet. Or if you can find any older Parkzone airplanes, you can use their receivers as well. They usually have 2 linear servos built in.
I was wondering about that while i was looking ,But seen some that where air ?? I think , Joe does it look like these >> https://www.spektrumrc.com/search?q=dx5%20rugged ??
Something to check when shopping for a spektrum controller this is the example model here I have two identical controllers both dx6i but one is dsm2 the other dsmx and it has a difference in range The dsmx has never lost the signal, even with micro receivers the dsm2 Lost the signal twice out of two different models for a land vehicle it's ok but not for an airplane I don't trust that controler only my dsmx is in my opinion 100% reliable
But for a vehicle I prefer a pistol grip control with the wheel I also have an old one with a stick for car but it's old I prefer the 2.4g controller
For the elicopter I have this very simple model but works very well 6 channel dsm2 the other one that I have dsm2 must be damaged or I don't know but hey I really have the choice I have several controllers normally I use the dx6i I like it
Those DX6i s look almost the same ? Mine is like the one you have your finger on?? The good one ? I have a few extra transmitter and receiver gear I can let Joe see if its something that will work I'll ship it too him ... Joe you there !?!
OK well Cool , did the people at Spectrum get back to you ?
» Micro equipment for DX5 Xmiter question
» Wingtip Micro Cam Attached to one of Bernie's Micro Servos
» TD .010 Micro Cam Racer
» Cox micro servos
» Cox micro servos
