» Feed Station Zebra.. Spring 2024by roddie Today at 5:53 pm
by balogh Today at 5:17 pm
by cstatman Today at 1:59 pm
by cstatman Today at 1:41 pm
by Myk Yesterday at 10:26 pm
» Scientific Gulfhawk
» Memorial Day 2024
Cox planes CG
Cox planes CG
I have noticed that several of my Cox Control line planes have the Center of Gravity too far forward. This makes for a hard landing damaging landing gear at times. It is my opinion that if the CG was where it was supposed to be at 20 to 25% behind the wing leading edge then you would be able to get the nose up a little more and try to do a 3 point landing instead of a trip and fall. Who of you guys have similar experiences ?
Greenman38633- Gold Member
Re: Cox planes CG
For me, it's always come down to adjusting the individual plane's CG. Seems like almost ALL of the Scientific "Hollow Log" models come out nose-heavy with that monstrous (by proportion) .049 on their snout.
Cox's original P-51 Mustang, in my opinion, can use a little lead in its rear, and even the PT-19 will glide and loop a bit better with a small amount of tail ballast. We found this out back in the day when I felt mine needed to have a tail wheel, then noticed a bit friendlier glide.
I think it'd work better to do test flights with minute changes in ballast, to hit the sweet spot...but that's just me.
Good luck !!!
Good luck !!!
Re: Cox planes CG
I imagine they errored on the side of nose heavy . It’s easier to control a nose heavy airplane in my opinion.
akjgardner- Diamond Member
Re: Cox planes CG
akjgardner wrote:I imagine they errored on the side of nose heavy . It’s easier to control a nose heavy airplane in my opinion.
Yep!!!! Agreed!
Re: Cox planes CG
IMO, like others have said, @Kim and @akjgardner , Scientific, Cox, Wen-Mac / Testors, Goldberg, Sterling / Estes, Top Flite, Enterprise, Midwest, Dumas, Veco, and etc. had nose heavy half-A aircraft especially with their "beginner" series was for stability for the neophyte. Balance was around the leading edge of the wing or a bit forward. A seasoned flyer could modify the fuselage to shorten the nose / install a lighter engine to give a better CG location.
Besides, most of those aircraft weren't laid out for stunts, around and around and up and down, crude wing overs, maybe a wide loop.
I think it was Bob @rsv1cox who noticed that his early 1960's TD-3 (or TD-4?) with Babe Bee tank engine was more nose heavy than the others with earlier plastic tank Space-Bug Junior. The integral plastic tank engines were lighter, moving CG back.
But, to the then adolescent / teen, now senior, they still are fun.
706jim- Gold Member
Re: Cox planes CG
I’ve got 2 Cox spitfire planes… they balance in different locations… there’s a video on YouTube showing one them. It was hard to keep in smooth flight. I think it is nose heavy. I plan to add ballast and fly again and fly the 2nd one at some point.
Jerry- Bronze Member
Re: Cox planes CG
Jerry wrote:I’ve got 2 Cox spitfire planes… they balance in different locations… there’s a video on YouTube showing one them. It was hard to keep in smooth flight. I think it is nose heavy. I plan to add ballast and fly again and fly the 2nd one at some point.
I got to get some dedicated video of those planes!
Re: Cox planes CG
That would be Great to see your Spitfires. I saw a Spitfire on YouTube video of a guy flying a Cox Spitfire. On a very short concrete pad the prop kept hitting the ground and dying. Must have had bent landing gear. So they threw it into the air and then it flew well. But no good way to land it in the grass so it’s always a nose over type landing. I don’t like that. I want my planes to be able to land well
Re: Cox planes CG
The landing wheels are not easily removed without nipping off the factory flattened pinched music wire end that holds the wheel on.
One could probably bend their own music wire landing gear replacement and up wheel size so it rolls better.
This is where the beginner balsa planes do better. Back in the early 1970's, my 21" wingspan Sterling Beginner Fokker E-III Eindecker would take off when released on a portion of lower cut or bare spot in a mowed grass field.
When engine ran out, being considerably lighter, it lost enough forward momentum that it sort of "parachuted" down, didn't even get a quarter circle. But in soft grass even if it flipped on landing, was undamaged.
Me personally, I'd dread to fly such a venerable collectable off a hard surface, as more likely than not, might be my last flight with it.
But I do enjoy watching others give it a go.
Re: Cox planes CG
Greenman38633 wrote:That would be Great to see your Spitfires. I saw a Spitfire on YouTube video of a guy flying a Cox Spitfire. On a very short concrete pad the prop kept hitting the ground and dying. Must have had bent landing gear. So they threw it into the air and then it flew well. But no good way to land it in the grass so it’s always a nose over type landing. I don’t like that. I want my planes to be able to land well
That guy would be me
» Good models for .09's
» New to me Planes
» New TD .010 and Pee Wee .020 Planes
» 1/2a rc planes
» New to me Planes
» 1/2a rc planes
