» Prop Rod - resto to a runnerby rsv1cox Today at 7:32 am
by roddie Today at 6:12 am
» Looking For Comet Tri-Pacer
Cox Curtis Pusher Pilot
I just placed a want add in the classifieds about a Curtis Pusher Pilot. I'm here in this section to ask if anyone has measured one up and knows of a common toy action figure that I could use as a substitute? This will be a replica made from alternative materials but hopefully it will look a lot like the original when finished and I plan on flying it before I get too old and decrepit !! Any leads will be appreciated!!
Type at you later,
Dan McEntee
Type at you later,
Dan McEntee
DanMc- Gold Member
Re: Cox Curtis Pusher Pilot
I'm no help to you Dan, but it's an admirable project and look forward to seeing your progress.
Hi Dan, thats going to be a hard one take a look at this guy >
he is a little expensive ! https://www.1001hobbies.com/132-scale-figures/27434-pj-productions-pj321110-british-wwi-pilot-seated-in-aircraft-optional.html?gad_source=1&gclid=Cj0KCQiAoKeuBhCoARIsAB4WxtdCdzFNBOvB-zxPAuovKpTSvK4uTnruYyVGeVwWyfC1T7DPGAIrjHUaAtG6EALw_wcB#lg=1&slide=1
Cox Curtis Pusher
Thanks for the lead!! getting something the correct size is important. I need to find out how tall the Cox pilot is and compare. The details on this little guy say it's 1/32 scale ( which sounds small) and is 54mm tall. That sound small also. But thanks for pointing it out!!
Type at you later,
Dan McEntee
Type at you later,
Dan McEntee
DanMc- Gold Member
Just a thought , grab the one on E-bay , have someone print u one and give u the file . Have some made up to sell and keep the good original one
akjgardner- Diamond Member
» Cox Curtis Pusher Pilot Figure WANTED!!!
» Cox Curtis Pusher Pilot Figure / Pitts Special Left fuselage Side and Main Struts
» Cox Curtis Pusher
» what is value of 1911 curtiss pusher thimble drone
» Cox Curtis Wright SB2C "Helldiver" finished
» Cox Curtis Pusher
