» Looking For Comet Tri-Pacerby DanMc Today at 7:25 pm
by 944_Jim Today at 7:04 pm
by 944_Jim Today at 4:31 pm
by balogh Today at 4:08 pm
by rdw777 Today at 3:58 pm
by rdw777 Today at 3:46 pm
by roddie Today at 3:07 pm
» Removing old decals
by latole Today at 3:06 pm
by rsv1cox Today at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Today at 11:52 am
by getback Today at 6:46 am
by GallopingGhostler Today at 6:33 am
Me 163 in 1/32 scale
Hello together,
I´m new in the forum and hope to have nice conversations. I´m from germany so I will
post all data in metric system, Hope this will be fine for you.
Ten years ago, I took my worn out TeeDee 010 from the early 90´s (used it long time on a scratch built 2-channel glider) and
held it in the fuselage-shell of a 1/32 plastic Modell from Revell. It seemed to be possible...
So I made a negative moulding and got out a nice part. The first wings I made out of Balsa,
Rc equipment was from an horizon-micro heli. Long story short, I failed many times for several reasons,
with different equipment and starting methods and ended up dissapointed and with an even more worn out TeeDee!
I friend of mine proposed to use a bigger "foamie model" bring the Me 163 up and just
try it as a glider. So I took out the Cox engine and putted in a servo to decupple from the towing-model instead.
And it went well! It is steerable, it is fast, the only permanent direction is downwards, but we have the proof!
Equiped now with "Hott" micro reciever and 1,8g-Servos, Lipo 1S 70mah. The wings are fom styrofoam, paper-covered.
Coming back to the cox-powered variant, calculation showed no chance with the standard propeller. The model has
290mm wingspan, weight is 45g, resulting wingload is around 35g/dm²
I need to be fast! So with a new engine, I will cut down a 3x3 prop to around 60mm to get on the requiered rpm´s.
Than I will measure static thrust.
If this shows efforts, I´ll take care about a sled, that will ru on to wires, to let it start "on its own".
Any feedback will be fine and I will post next steps...
Jo Nuesseler- Beginner Poster
Re: Me 163 in 1/32 scale
Cool project post a vid if you can
The props I went with one of my TD .010 projects.
Prop 2.56 x 4N / 30% Nitro / 18" wing span 43 sq. in.
Static 28,858 rpm / 109.3 mph prop pitch speed / .028hp / 21w / 1.5oz thrust
Best down wind pass 35,184 rpm / 133 mph audio tach / 130.4 mph per Doppler
2.8oz RTF / 2ch RC micro race plane. Winds gusty to 14 mph.
Hobby People - HP 4x4 E prop cut down.
Prop 2.7x3 / 186.27 km h / 116 mph - per doppler
Unloaded 39,754 rpm 113 mph - per prop calc
Static 30,972rpm / 88mph / .035hp / 26w / 2.3 oz thrust
Stock prop 3x1.25 black prop
TD .010 / 41,985 rpm unload best peak down wind.
Best Pass 50 mph prop pitch speed / Stock Black Prop
2ch / 3oz RC Plane 35% Nitro
ME163 Komet, such an interesting and dangerous to service and fly airplane.
https://www.nationalmuseum.af.mil/Visit/Museum-Exhibits/Fact-Sheets/Display/Article/196267/messerschmitt-me-163b-komet/
Welcome to the forum. Hoping to hear more from you about this.
Waow, these are very impressive values! Thank you for sharing!
In german puplications they strictly recommend castor oil.
Is it the same under experts here?
And how is your break-in procedure?
yes the Komet is very special. I have it in different configuration up to 1/4 scale.
you will find one based on a hobbyking foamy with ecu-controlled hybrid rocket. Probably still the only one worldwide. Search for "worlds first rc me-163 with real rocket engine" I'm not allowed to post a link...
Currently I build one in 1/7 with 23N thrust for 30sec.
Jo Nuesseler wrote:Waow, these are very impressive values! Thank you for sharing!
Not wanting to pretend that I am an expert but could not agree more to use possibly all-castor lubrication for COX engines, up to 20% in the fuel. A few tanks with rich setting is normally enough to break the COX engines in. Short runs, let it cool, restart, and at the end of say, the 5th tank of the 010,just set it for the max speed and you are good to go...(the stock tank will hold fuel for a ~2 minutes run at full speed)
COX engine manuals advise that due to the excellent manufacturing tolerances applied, breaking in in the conventional sense is not really necessary.
Thank you!
For my understanding, everyone who has the skills for reliable COX-enginge usage is quiet an expert.
I think I killed my first 010, thinking that synthetic oil, wich serves well my other glow engines couldn´t be bad
for my Cox...
for my Cox...
It is the balljoint between the piston and conrod where castor varnish helps keep metal surfaces away from each other and prevent premature wear. The soft steel cylinder and hardened steel piston will also last for long with castor. COX tested in an engine test run 400 hours effective lifetime whit of course castor oil in the fuel.
Thank you for your answer! I would need at least 1,5oz of thrust and maximum availlable speed. Therefor a 3" pitch would be good, or what do you prooose?
I read, that you got 1,5oz of thrust even with a 4" pitch.
Do you have a flying video of the red plane posted on youtube?
Plane weight size and drag controls the best prop for the plane.
The project should do well with a 3x3N
The 2.56x4 is for very light fast designs.
Static thrust at 1.5oz achieved through high rpm.
2.7x3 prop
NANO II - 2nd Trim Flight 2.7x3N Prop / 62.3g - 2.2oz RTF
Best pass this vid: 39,244 rpm / 112 MPH
Best pass vid 3: 41.5k rpm / 118 MPH
Static 31,815 rpm / 90 mph PS / 2.46 oz thrust
Engine run time 5 mins. 10sec / 7cc tank / 35% nitro
2ch plane / 15.5in span 28 Sq. In. airfoiled solid balsa wing.
2.2g RX 150 mAh 1S 3.7v / 2g servos. Very min. deflections.
Nervous test flight took 110% full attention.
T3x2 drone prop high thrust made up to 64 mph passes with a larger heavy plane.
Lil Speedy TD .010 / Test Flight 3x2E Green Drone Prop
Best pass cross wind 32,792 rpm / 62 mph / per prop calc.
4.7oz RTF solid pull better loops and faster turns great prop with a throttle.
Down wind passes: 33,941rpm / 64 mph - per 2in pitch .
2.7x3 prop
Many thanks again! Unfortunately there is no Video of my Me-163. It weighs 1,55oz and has
a wing area of 20sq.In. So it schould be possible
to get a 1/1 power/weight ratio.
Wow, great build!
I'll be reading along here with interest.
Grüsse aus der Schweiz
Tobaiies- Silver Member
Here is some carbon 3x3 data
Carbon 3x3 Prop / Best Noted Peak 33,107 rpm
More typical 32k rpm / 91 mph static prop pitch speed / 3.6oz thrust
Per prop calc: .058hp / 43.3w / tank duration 2.57 mins. / 35% nitro / 20% oil.
Blades carbon leading edge was reworked to reduce drag and make more rpm and thrust.
» Printing out .pdf plans to scale
» More Old Stuff...
» build log - 1:16 scale P-40, cox 049
» Scale nitpicking
» measurement questions
» More Old Stuff...
» Scale nitpicking
