» Looking For Comet Tri-Pacerby DanMc Yesterday at 7:25 pm
by 944_Jim Yesterday at 7:04 pm
by 944_Jim Yesterday at 4:31 pm
by balogh Yesterday at 4:08 pm
by rdw777 Yesterday at 3:58 pm
by rdw777 Yesterday at 3:46 pm
by roddie Yesterday at 3:07 pm
» Removing old decals
by latole Yesterday at 3:06 pm
by rsv1cox Yesterday at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Yesterday at 11:52 am
by getback Yesterday at 6:46 am
by GallopingGhostler Yesterday at 6:33 am
Kingpin, I said I wasn't going to build it...
After reading the Scientific Kingpin thread and looking over the “plans”, I decided to pass. I didn't care for the hammerheaded look of the cowled engine on a profile fuselage, and the wing mounting method seemed suspect.
But after giving it some thought, all the issues seemed fixable. I decided to go ahead, but to build it a little differently. I made 3 changes.
1. Extended the fuse profile to the nose and used a side mounted engine. Also slightly changed the vertical tail shape.
2. Made a full wing slot in the fuse, and sheeted the wing center section. The wing then mounts the same as any profile.
3. The kit wing has a straight LE and a tapered TE. I simply made it into a 'Hershey Bar' wing and added fixed flaps to give the taper.
The actual size of the original is uncertain due to plan inaccuracies. I decided to disregard this, and press on as if they were correct. The span came out to 14-1/2”, length to 14”. Weighs 3.3 oz. Power is a PeeWee with a drilled tank. (Not by me!) The trim is like the boxtop. For colors, I tried to match the decals pictured in RSV1cox's thread.
duaneh- Gold Member
Re: Kingpin, I said I wasn't going to build it...
DuaneH knocked it out of the park...again!
How did you do the lettering and scallop job?
That is a beautifully made and finished lil bird, congratulations!
Very nice job , absolutely love the color scheme
akjgardner- Diamond Member
Nice variation @duaneh , changes are practical but still meets the original intent, should fly well.
By the way, excellent craftsmanship, a real head turner!
Scientific had a habit of modifying their kit designs over time to reduce the cost of manufacturing. Example, they retained the original photos on Little Bipe and Little Devil, but the later versions deviated slightly in looks from the original design. I imagine that this could account for differences in the .020 Kinpin over time as well.
Glad you guys like it!
Jim, for the lettering, I typed into MS Word, then played with fonts and size until I got what I wanted. Then printed and cut the letters from Monokote. The resulting stencil is used for positioning.
The tail scallops are monokote cut directly from the plan, using a penny as a cutting guide. Wing scallops were redrawn and cut freehand from the plan. I fudged the spacing slightly so that the scallops would fall on rib locations. Makes it a little easier to avoid wrinkles.
duaneh- Gold Member
Good methodology for the lettering, Duane, thanks for sharing.
Regarding one less scallop in the wing trim, perhaps the original photo had an extra wing rib? That is what comes across my mind with Scientific kit changes over time.
Another home run duaneh. Seeing a new plane posted here always brighten up the day. Thanks for posting your Kingpin.
Mike1484
Mike1484
Mike1484- Gold Member
GallopingGhostler wrote:Regarding one less scallop in the wing trim, perhaps the original photo had an extra wing rib? That is what comes across my mind with Scientific kit changes over time.
My rib spacing is different from the kit because of the change to the wing center section. The first rib moves outboard about an inch to support the sheeting, then the others are evenly spaced from it.
duaneh- Gold Member
The finish is beautiful with the bright trim….Excellent build too….. Would love to see that one in the air!…
rdw777- Diamond Member
» Gifted Scientific "Kingpin" gets a Re-Fit
» Breaking the seal on a Scientific Kingpin
» Help Deciding on Kit
» Looking for first RC build...
