» Looking For Comet Tri-Pacerby DanMc Today at 7:25 pm
by 944_Jim Today at 7:04 pm
by 944_Jim Today at 4:31 pm
by balogh Today at 4:08 pm
by rdw777 Today at 3:58 pm
by rdw777 Today at 3:46 pm
by roddie Today at 3:07 pm
» Removing old decals
by latole Today at 3:06 pm
by rsv1cox Today at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Today at 11:52 am
by getback Today at 6:46 am
by GallopingGhostler Today at 6:33 am
Make Your Own Gasket Paper
You need a photocopy paper, silicone oil, plastic container or an old plate and scissors. Silicone oil can be find at art supply stores.
Paper must be a little thicker than ordinary copy paper, must be a little heavy paper. Cut the paper to get smaller pieces. Place papers in plate and pour silicone oil. Let the paper sheets totally impregnated with silicone oil. Take the papers and hang them with pegs to dry. Don't place papers on an absorbing surface while drying. That's all.
I made a paper gasket for Enya .09 engine which gifted by Bob (rsv1cox).
Levent Suberk- Diamond Member
Re: Make Your Own Gasket Paper
That’s a good tip Levent,…. I’ve made paper gaskets using brown kraft paper but used castor oil to soak them in…. I’m sure silicone oil allows a better penetration into the the paper fibers….I’ll have to add silicone oil to my Cox related liquids inventory
rdw777- Diamond Member
I always use nautical chart or sea chart. They're made of thick paper and are very strong. After spending 10 years at sea, I have a reasonable stock. We made gaskets with it in the engine room and I also use it with an engine overhaul.
OVERLORD- Diamond Member
» Do newer plastic reed cage still need paper gasket? And TD .15 Special MkI question.
» how to clean cox engines and make make them look like chrome?
» Looking for a scan of old tee dee 010 paper box
» Paper or Plastic?
» RARE COX THIMBLE DROME PROTOTYPE "PT-19 COROPLAST BUILD" GAS MODEL AIRPLANE
» Paper or Plastic?
