» Looking For Comet Tri-Pacerby DanMc Today at 7:25 pm
by 944_Jim Today at 7:04 pm
by 944_Jim Today at 4:31 pm
by balogh Today at 4:08 pm
by rdw777 Today at 3:58 pm
by rdw777 Today at 3:46 pm
by roddie Today at 3:07 pm
» Removing old decals
by latole Today at 3:06 pm
by rsv1cox Today at 2:29 pm
» Cox Ryan ST 2.0
by 944_Jim Today at 11:52 am
by getback Today at 6:46 am
by GallopingGhostler Today at 6:33 am
Homemade Washers
Homemade Washers
Not a very exciting subject but something we need from time to time for our models…. I’ve been making these for a long time for small models, particularly for wheel retainers… Always hard to find the just right size so I make them from copper wire..,Photo below shows the steps from left to right….
Wrap the wire tightly around a drill bit secured in a vise… The bit needs to be slightly larger than the landing gear wire
Peen the loop flat on a hard surface with a small hammer…. Test fit onto the LG wire… Peen it some more if the inside hole needs to tighten up…
Cut the washer free with some small wire cutters
I prime the solder joint first with a little plumber’s solder flux to help it flow better … Any burr’s on the washer can be filed off after soldering….., Done!!
Hopefully it might be useful to some needing that just right size washer
rdw777- Diamond Member
Re: Homemade Washers
NEW222 wrote:Very neat concept. I can definately see this being handy.
Yes.. we like this stuff..
Hi rdw777,
Nice solution to make custom washers ! Thanks !
(I knew I joined CEF for a reason ! )
I am not good at all at soldering without melting/burning, plastic/wood hub wheels and getting them to turn...
And that perfect looking solder blob I could make, guaranteed a locked wheel !
You are an Artist my Friend.
Thanks for sharing,
Take care,
Have fun,
Dave
Thanks for sharing,
Take care,
Have fun,
Dave
HalfaDave- Platinum Member
Thanks for a great tutorial, Robert!
I've seen this one, or a variation some time in the past. I don't why I can never remember this one when building the LG. To fix the memory lapse, this one picture (top) instruction is being printed and pinned to my Hobby Closet wall.
