by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
K&B greenhead .35
K&B greenhead .35
I have a few greenheads. I have the .09, .15, .19,.29 and a older .32. The one greenhead .35 I own is in terrible condition. I mean hacked up.The piston liner is also in poor shape. I came across a .35 greenhead and it had me looking twice at it. First thing I look for is the butchered slotted screwheads. For the life of me, I can never figure this out. WHO DOES THIS? Obtain a properly fitting screwdriver. I see more butchered screws, it makes me sick to my stomach.I find it really detracts the value and appreciation for a engine. Some don't care obviously. Most of these screws are practically unobtainable now. I also noticed that on my example someone broke two screws off in the backplate. HOW DOES THAT HAPPEN? It's bad enough trying to remove one let alone two. I have a cross slide vice in my drill press which is a huge help. Nonetheless, the softer metal always wins and regardless of my attempt, the hole went off center. I was able to substitute 5-40 screws for the now ruined 4-40's.
This engine had NO compression, zero. I looked at it closer and closer and was puzzled. The piston liner didn't look terrible so I looked at the gaskets. Indeed the base gasket was a problem. Next was the head gasket, also a problem and then there was no copper washer under the plug. Having two broken screws in the backplate also proved problematic as it wasn't tight.
I made new gaskets which is a bit of a chore. I don't like fiber head gaskets, they blow out and they're not efficient. They cause poor heat transfer. Metal gaskets are much better. I was able to lap the cylinder and use a Fox .35 head gasket. I glass beaded the cylinder head and used Rustoleum mixed with auto urethane hardener. Not only does this make the paint dry faster, it makes it hard and chemical resistant. Only running will tell if heat is a issue. I'm thinking it will be fine. Worst case scenario, I redo it. I used a screwdriver through the plug hole to paint it. I got some paint on the screwdriver and a wirewheel in the drill press didn't want to remove it.
This is the later version which used a bushed rod on the bottom and a two piece needle valve assembly. This needle doesn't utilze a spraybar. I'm not certain if it was a upgrade offering or it came stock. The needle is visible through the venturi. This isn't a aftermarket needle, it is a K&B needle.
Re: K&B greenhead .35
Lovely work Ken.I agree with your sentiments early on-there are people out there who should be jailed for being found in possession of tools. I react similarly when I see vice gripped cylinders and fins, or plier graunched prop nuts.
the most extraordinary case I can think of that I'm personally acquainted with was when I was given the carcass-that's the only appropriate word-of a Davies Charlton Rapier 2.46 diesel-the original 1957 greenhead model-not the later 1973 re-introduction. Someone...not the guy who gave it to me-had DRILLED a 1/2" diameter hole through the bottom of the crankcase!!!
The mind simply boggles as to what strange universe the person who did this lived to think that this was a reasonable thing to do. I sent the engine-along with several others that needed work-to Robin Hiern-the Australian speed flier-who was at that time doing engine work as his full time job-with the words "i think this is a complete write off-but see what you can do.."
-anyway he did an extraordinary repair job- made an insert, welded the case and machined down to original dimensions, made a new 'cap' to replace the broken off down draft venturi and several other things to get it back to working order-which it now is. He did manage to assemble it so tight though I've been unable to get the fins off to reanodise them back to the nice lime green they were when new.
If you're not familiar with the Rapier; see: https://sceptreflight.com/Model%20Engine%20Tests/Allbon%20Rapier.html
ChrisM
'ffkiwi
ChrisM
'ffkiwi
ffkiwi- Gold Member
Hi Ken,
That is beautiful...
My friend John Cook (probably DNA related ! ) had a Greenhead like that.
Out performed my McCoy RedHead .35, by a fair bit, but luckily I could snag his streamer as he had to pass me !
Great times, until, mufflers needed to strapped on to those nice engines...
No kidding,
13yr old kids, hand flipping Tornado 10-6s and getting the football field cleared for the 'Longer Lines'...
In the 'Heyday' of the local hobby shop having everything we needed for flying the Cox.049 Cl planes...
Thanks for the memories,
Take care,
Have fun,
Dave
P.S. Chris, your engine knowledge is amazing, I Thank You !
No kidding,
Take care,
Have fun,
Dave
HalfaDave- Platinum Member
Dave-I have been at this game since I was 8 years old-plus I have a VERY good library, and a more than decent (but not photographic!) memory-plus I own a LOT of engines-and was fortunate enough to grow up at a time-and in a country-where diesels were as common as glows-and grew up with both...and you never stop learning-sometimes even unexpectedly at your own hands....this morning for example I posted a comment on facebook where someone had posted photos of an OS Pet III 099 still NIB and was reminiscing about the earlier Pet models...which inspired me to grab one of my Pet-IIs that is still presentable to post a photo of it in reply. Whilst digging in a box of assorted engines intended for display mounting I had a close look at my Pet-I and discovered to my surprise that contrary to what I had thought it DOESN'T use the same crankcase as the Pet-II-the Pet-II case-whilst clearly derived from the Pet-I, has thicker mounting lugs, thicker backplate mounting points, an enlarged transfer passage bulge, and a longer fore and aft exhaust stack.
truly-you never stop learning in this game...
ChrisM
ChrisM
ffkiwi- Gold Member
Hi ChrisM,
Back in the Cox heyday here west of Toronto, Canada...
We went to the Library to learn stuff from latest model magazines...
Peter Chinn proclaimed the "Cox TD .010 as the most power full engine in the world yet".
Just after, Man landed on the Moon.
The Local Hobby Shop was the 'cool' place to be...
Well worth cutting lawns and shovelling snow, to spend money there.
The amount of different engines over the decades are mind boggling.
Thanks for sharing your expertice with us Chris... Much appreciated.
Take care,
Have fun,
Dave
Take care,
Have fun,
Dave
Great job restoring the K&B .35 Torpedo into a runner, looks really clean and like new on the outside, too, Ken.
I got a used .35 Torpedo, but someone hacked the bottom of the piston skirt in a crude attempt to create SPI. The hack wasn't even cleanly machined. It's got almost 3/32nds of a gap.
The auctions overall want too much for the Torpedoes. I've made do with several .35 Stallions with very good compression.
I've always been a fan of K&B engines. I just never use them as much as I should be. I truly love the K&B .61, it's a remarkable engine. In addition, the Sportster series. The Sportster engine line receives a bad reputation from many. The technology in what was supposed to be a inexpensive engine line is amazing. K&B invested a lot of money into those engines and the quality is very impressive. The Dykes ringed .4011 engine is a true powerhouse and is found in abundance for low dollars.
You put a lot of work into getting back to running and looking great order , proves you have a love for the engine .
It did take some time to clean it and make the gaskets. One thing I can't tolerate is having junk. I want good to perfect examples. So so stuff goes into a box and onto the swap meet table. What most don't understand is that if a engine is incomplete in anyway, it's a parts engine. Needle valves are a big expense, if it's missing, the engine is going to require a immediate $20 or more to put it into service. I deal with control line members who are the cheapest on the planet. I won't say that I have a love for the K&B greenheads, they're cheaply made engines similar to the Mccoy redheads. I just have a bunch of period planes that would utilize such a engine and I find it neat to use them.
"Nonetheless, the softer metal always wins and regardless of my attempt, the hole went off center. I was able to substitute 5-40 screws for the now ruined 4-40's."
I feel your pain Ken. I have been there. Best center punch, start with a smaller bit and graduate to proper size and half the time you still get drift to the softer metal. Discourging.
Did you glass bead the case as well? Looks fantastic.
Bob, I buffed the case on my buffer. I really don't know what I'm doing with it. My dad made the buffer and I used it many many times but I'm not certain if I'm using the correct buffing rouge. The dark reddish brown rouge works quickly but also loads the wheel fast. Aluminum being so dirty to begin with I think requires a different rouge. I believe the dark reddish brown is tripoli but I have a white bar as well which I didn't try. The K&B case had a lot of flash and craters. I filed them first and cleaned up the case prior to buffing. I ran the engine today. WHOA, it's loud. It was very cold today and it was being very problematic requiring 2-3 times the amount of prime it usually takes. On a Master Airscrew 9.5 x 6 it was taching 13,560 on 10% nitro.
Generally the lighter the color the less abrasive it is. I have yet to try it on a model engine but you have lit a fuse and set a very high standard. I might tear down Fred's Torpedo engine again and give it a try.
I miss Fred's posts, he still checks in but has very little to say. Freddies SE-5 engine on left.
cstatman- Platinum Member
I remember. You are the authority on this. It's too bad that shiney didn't translate into sales. Pride of posession though.
davidll1984- Diamond Member
In its day-the mid to late 50s one- of the hottest 09s around-the TD 09 being a good 6-7 years in the future-even by later sport 09 glow standards it was a good performer. I still use them in Nos models
ChrisM
ffkiwi- Gold Member
I see the engine has a Arden glow plug in it too. I have a few new ones and the parts to rebuild one or two.
You got a nice .35 Torpedo coming in the mail Bob, NOS with box and spares nonetheless.
Reminds me a year ago around this time, I purchased a K&B Allyn .09 Torpedo Green Head for $23 + $12 shipping, that was in NOS condition (hardly run if that) and with "tool drawer head paint chips", signs of mounting without box or instructions and an original Champion glow plug: https://www.coxengineforum.com/t16866-kb-09-torpedo-engine .
K&B .09 Torpedo, left side.
It was in much better condition than the Ebay example you mention, Bob. I know I wouldn't spend $70 for a crashed (broken rear lug) and carelessly drilled out mount hole Allyn .09. Yup, agreed, if it remains unsold at end of bid or BIN cycle, then we know why, seller wanted too much.
GallopingGhostler wrote:You got a nice .35 Torpedo coming in the mail Bob, NOS with box and spares nonetheless.
He sent me an offer of $40 that I must ignore. I don't have the heart to tell him that it's worth $20 or less as a parts engine. But if anyone would like it, just send him an offer of $40.
Yes, agreed. I'd rather buy a Tee Dee or Medallion .09 in good used condition for that amount of money (which are light and more powerful) than for that parts engine, as you say.
There are other engines in the same displacement class would also work, too.
» K & B Greenhead's
» K&B greenhead Torpedo 19/23 prop driver
» Wanted K&B Torpedo .35 greenhead thrust washer
