» Jim Walkers FireBee - This is going to be funby rsv1cox Today at 3:17 pm
» WenMac MkIII 049, Cox BabeBee, FOX 15X and 19 Prop Screw/Crank Threads
by mike in SC Today at 3:07 pm
» Cox Mustang repair
by duaneh Today at 3:02 pm
» Feed Station Zebra.. Spring 2024
by rsv1cox Today at 3:00 pm
by cstatman Today at 2:28 pm
by balogh Yesterday at 5:17 pm
by GallopingGhostler Yesterday at 3:12 pm
by cstatman Yesterday at 1:41 pm
by Myk Mon May 27, 2024 10:26 pm
» Scientific Gulfhawk
by roddie Mon May 27, 2024 8:59 pm
» Memorial Day 2024
by roddie Mon May 27, 2024 8:48 pm
TAPLIN TWIN 7ccm
TAPLIN TWIN 7ccm
Good day everybody,
I'm Michael from Germany. I am 64 years old and have been working with model diesel engines since my youth, especially Taifun engines, which I restore and anodize myself.
I am also building a Webra 4 cylinder inline engine which you can see on You Tube.
I ride and love English motorcycles. BSA B33 1951 and TRITON Pre Unit 1956.
My question:
I am currently restoring a TAPLIN TWIN 7cc boat engine.
What thread size is used in this motor? Maybe some experts can help me.
Best regards
Michael
My question:
Best regards
Michael
michaelherbst1- Moderate Poster
Re: TAPLIN TWIN 7ccm
Hello Michael,
welcome to COX Engine Forum.. (I am also 64 and from Hungary, and while I am a COX engine fan, back in my youth I also ran small diesels of Hungarian MOKI and similar. Plus I also ride a small Honda MSX 125 nowadays...so you will understand this is an international young-boy site )
I have no information about the thread sizes you ask, but you may be interested in reading this article of Spectreflight, about the engine you are working on:
http://www.sceptreflight.com/Model%20Engine%20Tests/Taplin%20Twin%207cc.html
I trust this helps, regards András from Budapest.
Try these people https://www.model-engineer.co.uk/ and there are interest here https://adriansmodelaeroengines.com/catalog/main.php?cat_id=3 you will have to dig for it , I looked on line with no luck for specs. There are a few people here that have this engine maybe they will chime in later so check back,, Welcome to the CEF
OVERLORD- Diamond Member
Thank you for the answers.
It must be a BA 6 thread.
I will post photos of my engines soon.
Thanks and best regards
Michael
Michael
I so hope to play with one of those one day!
robot797- Platinum Member
Good day to all model engine enthusiasts,
Attached are photos of my restored TAIFUN engines, KRATMO 10, Felgiebel Boxer 2 x 7.5 cc, which I built myself. Then the WEBRA 4 cylinder, 4 x 6.5 cc, with two 180° rotary valves, is running very well at the moment. The first run can be seen on YOUTUBE. Enter Webra 4 cylinders, or Webra 120.
More pictures will follow.
Best regards
Michael
Best regards
Michael
Twin
Hi Michael,
Lovely.....
You probably make your own screws etc. But may not know of "model fixings" a mail order supplier.
I will post later the exact web address later.
Please would you post a you tube link for your engine please.
Lovely.....
Coxfledgling- Gold Member
Hello,
Attached is a photo of the disassembled Taplin Twin, everything looks good and usable, the pistons have good compression. The main crankshaft does not need to be disassembled as the bearings run freely and easily. The front bearing and the cylinder head screws need to be replaced, I will make them new. a good solid basis to bring the legendary engine back to life.
I'll post reports about the restoration, it'll just take a while because I'm working on a lot of other projects.
Many greetings, Michael
Very Nice collection you have Michael , glad the engine look good on the inside so when completed should make some air flow . Good Day Sir
Ba
Modelfixings.co.uk
Good morning,
Thank you very much for the feedback and the tips.
Here is the headline for the 4 cylinder Webra on YOUTUBE:
WEBRA 4 Zylinder 160, Reihenmotor, Selbsbau RC mit 26ccm. RC model 4-cylinder in line 2-stroke
Best regards
Michael
Best regards
Michael
[quote="michaelherbst1"]Good morning,
Best regards
Michael
good morning
Best regards
Michael
good morning
You have a very nice and unusual collection of engine Michael , hope you don't mine i put your video up for easy viewing . The inline 4 cylinder engine is amazing you built and seems to run pretty good swinging a big prop .
good day everybody,
After dismantling I discovered that the ball bearings needed to be replaced.
these are the storage sizes:
Deep groove ball bearing inch R6 open
open version. without covers
Inside: 9.525mm
Outside: 22.225mm
Width: 5.558mm
greetings michael
Inside: 9.525mm
Outside: 22.225mm
Width: 5.558mm
greetings michael
That's easy to calculate. You need a 7/8 x 3/8 x 7/32 bearing.
I already ordered exactly yesterday.
Thank you
Thank you
Good day everybody,
The attached photos show the individual parts of the TAPLIN TWIN before processing and after processing. The ball bearings had to be replaced. I made new compression toggles and also had to replace some 6BA screws. The engine has good compression and the counter pistons work well. I have to say: a very good, precise construction of English engineering.
Best regards
Michael
Best regards
Michael
That looks great, Michael. How big is this engine dimension wise? I suppose the supporting bolt is an M5 or M6?
Hello OVERLORD,
yes it is M5 thread, above you can see a TAIFUN Hurricane 1.5 cc. The TAPLIN TWIN is very compact for a 7 cc twin engine.
Best regards
Michael
Best regards
Michael
That look Great ! So there are 4 bearing in the engine , front rear , 2 in the middle ??
Hello Eric,
There are 3 ball bearings, 2 for the crankshaft and one bearing for the front shaft where the flywheel or, in the aircraft engine, the propeller sits.
Greetings
Michael
Greetings
Michael
Thanks , its an interesting engine .
» Taplin Twin .49
» Taplin Twin .7cc
» taplin twin
» Cessna twin engines twin boom model
» Taplin Mk III RC
» Taplin Twin .7cc
» taplin twin
» Taplin Mk III RC
