by roddie Today at 10:48 am
by rsv1cox Today at 10:26 am
by getback Today at 9:55 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
DC Merlin .76 cc
Page 2 of 2
Page 2 of 2 • 1, 2
Runner
Rumour has it this engine now runs on its tank ?
Coxfledgling- Gold Member
Re: DC Merlin .76 cc
quote="Coxfledgling"]Rumour has it this engine now runs on its tank ?[/quote]
True, ran for a few secs after priming i.e. injecting a few drops in ex. port. Now trying to make it run continuous.
kendias- Moderate Poster
kendias wrote:Sent pics.Coxfledgling wrote:Nice one Roddie, oe tank, starter spring and ans silencer too !
Mine had a none anodised cylinder back in the day.
Perhaps a "warm air gun" rather than a naked flame pre warmer...less of a fire risk. Sometimes i "held" the cylinder to warm it with body heat for reluctant starters buy from memory had no problems with my DC's.
May I ask, on yours, was the back plate pre drilled and threaded for the centre tank screw ?
Also, the spray bar, two jet holes or just the one ?
If mixture needle unscrewed a bit and an aerosols sprayed into the fuel pipe stubs, the spray will be seen ?
Anyways, waiting for ken's picture of the spray bar.....
The starter spring - do you actually use it to start the engine?
Hey.... The DC Merlin that I pictured.. was given to me by CEF member IAN1954. It's the only compression ignition model engine that I own.. and I have not tried to run it. I thought it important to source the fuel components... for when the opportunity presented itself.
DC merlin
Hi Roddie,
Nice one, they are good little engines and run well being good starters when in good condition.
Could you establish if yours has two fuel jet holes in the spray bar ?
All the spray bars in my DC spares box have two fuel jet holes...
Ken, when your "blurps" into life is there fuel all the way up to the spray bar ?
The finger over the Venturi and say 3 prop revolutions will/should make this happen...
With fuel all the way up to the spray bar and it burps into life, any air bubbles in fuel pipe and any bubbles around back plate ?
Yes, there is but a small bubble at start which disappears when I prime. Just tried with 3 prop revs as you said and it ran twice for about 10 secs. Like to send a video but need someone to take the video as I try to start. Not sure if any other way.Coxfledgling wrote:Hi Roddie,
DC merlin
Hi ken,
Internet really poor here...
So engine starts and runs for ten seconds or so, a good sign, but why does it stop running ?
Fuel supply ?
Is tank vented and tank full ?
Engine going tight ?
Ten seconds or so is a long time to run on fuel ingested via priming etc., So the two caused mentioned need checking out...
Is tank full ( good amount of fuel in tank, your tank looks quiet big and quite a large diameter ) ?
Bubbles seen in fuel pipe close to end of ten second run and engine seems to surge a few times then stops ?
Engine goes tight, does it go tight ?
Suggest a better tank set up. Smaller diameter and taller tank which is vented.
Over to you...
Fuel supply ?
Over to you...
Tank is vented i.e. the lid of tank in prev pic is left open. Bubbles don't surge i.e. before start I try to ensure no bubbles.Coxfledgling wrote:Hi ken,
Fuel supply ?
Over to you...
Tank dia is @ 1.75 in.
Engine seems to lose speed after starting, runs for few secs and stops. Now, will try after adding a little more ether.
kendias wrote:Tank is vented i.e. the lid of tank in prev pic is left open. Bubbles don't surge i.e. before start I try to ensure no bubbles.Coxfledgling wrote:Hi ken,
Fuel supply ?
As you suggested, using a smaller dia tank per pic attached. Will make sure the jevel of fuel in the tank is above the engine intake. Will try it and see.
Over to you...
DC merlin
Do you like mulberry wine ?
No, do not have fuel level above spray bar, which had been stated earlier...
What's happened to the compression screw "*Tommy bar " ???
It is in the pic i.e. the black bar on topCoxfledgling wrote:Do you like mulberry wine ?
Fuel air mix spray nozzle is at center? Nozzle exactly looking down?
Levent Suberk- Diamond Member
Not sure what you mean? The spray nozzle goes into the mounting hole of the engine. Will recheck if nozzle exactly looking downLevent Suberk wrote:Fuel air mix spray nozzle is at center? Nozzle exactly looking down?
I see that spray nozzle is in center, but spray nozzle need to look down, at least I know.
Engine seems old. Disassemble and clean it and examine what is wrong inside especially compression screw.
Fuel supply ?
Over to you...
Is having a smaller dia better? I did try with smaller dia as in pic, had some improvement but no dice.kendias wrote:Coxfledgling wrote:Hi ken,
Fuel supply ?
Over to you...
When I prime i.e. block air intake, fuel comes to the needle valve, when I stop, it goes back
Page 2 of 2 • 1, 2
» DC Merlin 0,75 cc
» Merlin inserts?
» Merlin / Al Kelly - He will be missed :(
» Merlin Glow Head Test Run
» Merlin Head and Glow Plug Inconsistent Running
» Merlin inserts?
Page 2 of 2
