» Feed Station Zebra.. Spring 2024by roddie Today at 5:53 pm
by balogh Today at 5:17 pm
by cstatman Today at 1:59 pm
by cstatman Today at 1:41 pm
by Myk Yesterday at 10:26 pm
» Scientific Gulfhawk
» Memorial Day 2024
Running some O&R engines
I ran these today on both glow and ignition. I have a Larry Davidson solid state ignition setup and a lithium pack. The red .33 was the only one I had run on glow and no ignition because the spring steel in the timer is too long. I need to trim it as it's holding the points closed. Almost every one of these on glow were practically one flip starts. I truly enjoy running these engines. While many are quite anemic, they're really enjoyable to run. The Mite .049 is one of my favorite little engines. At a glance, it seems like nothing, but up close, these are fascinating little engines.
I've tried to obtain the different colors.
.19's, .29's, .33
.19's, .29's, .33
Re: Running some O&R engines
Those are nice engines Ken, Just something intriguing about sparkers…..I’ve kinna looked at it but just never pulled the trigger…..I used to have a Maytag washer engine that was fun to run just because…..I “get it” on simply taking the time to bench run….. My fav’s for that are a couple of OK Cubs and few simple bees…
rdw777- Diamond Member
Keep in mind, you don't need to run them on ignition. Just put a glow plug in and feed them lots of castor, equally as enjoyable. You can also run the ignition with glow fuel or gasoline mix. I prefer Walmart white gas and oil.
» Cleaning your engines after running
» Running some marine engines: OS MAX-S 30 RC
» Blizzard check-in
» Running Engines in winter
» Cranking and running Norvel engines
» Blizzard check-in
