» Feed Station Zebra.. Spring 2024by roddie Today at 8:30 pm
by balogh Today at 5:17 pm
by cstatman Today at 1:59 pm
by cstatman Today at 1:41 pm
by Myk Yesterday at 10:26 pm
» Scientific Gulfhawk
» Memorial Day 2024
Home Made Foam cutter
akjgardner- Diamond Member
Re: Home Made Foam cutter
That's great looking AK. I like the "self-tensioner."
Oh Jerry....where are you?
Jerry built a micro foam cutter for making his Typhoon wings. I think I saw the video on Facebook. I doubt it was over 10 inches across. After all, Typhoon wing panels are only about 6.5 inches (four sections in total).
I seem to remember he used an N-scale model train transformer to power his. A quick eBay shows the bottom entry at about $13...but I'd stay away from N-scale transformers based on the size of your particular "unit." If I had an HO one, I'd send it just to see if it could power yours.
I used an MRC Throttle pack… an HO transformer… I hooked the foam cutter to the track leads so the rheostat could be used to adjust the current.
Jerry- Bronze Member
Here are pics of my bow and associated power supply. I use a commercial DC power supply rated at 13.8v driving a DIY PWM heat controller. The cutting wire is .018 stainless spring steel. When cutting cores, I use a spreader about 3" inches up from the wire to insure the wire remains very taut -- the end spring takes up any stretch as the wire heats up.
There are several AC hot wire designs on the interweb, but I've found that AC can sometimes set up harmonics in the wire that causes a wavy surface cut.
We had someone sign up a couple of years back who was making foam cutters and offering them commercially. I don't recall the name.
Here it is Rod > https://www.coxengineforum.com/t14602-precision-foam-cutting-bows-titanium-wire-adjustable-tension?highlight=making+foam+cutters Nice looking set up starting to come together there Joe . Andrew, you got it going on sure it does a good job for you .
» Home made Texaco
» home made battery box
» Home made 049 buggy
» Home made air filter for COX TeeDee09
» Can a .049 piston be repaired?
