» A choke-tube with velocity-stack configured Beeby roddie Today at 8:23 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
Sullivan Starter Insert #S634 OK to use on 1/2A spinner nut?
Dave Rigotti- Beginner Poster
Re: Sullivan Starter Insert #S634 OK to use on 1/2A spinner nut?
Hi Dave, I haven't.. and am not familiar with any of the Sullivan electric starters.. but many of our members here on the forum have mentioned using the Sullivan 1/2A starter.
My advice for using any electric-assist starter for 1/2A would be to go easy. Resist the temptation to crank until you here combustion. Squirt a few drops of light-oil between the propeller drive-plate and crankcase.. prior to applying any force to the spinner. Doing so will prevent the "premature" wear on the front of the crankcase.. as well as other eventual internal engine wear. I generally apply short/quick "bursts" when engaging the starter Dave. Not too much more than a good healthy "spring-starter" would yield. This helps to avoid any user-induced friction on the engine.
I personally use an electric-starter for my Cox .049 reed-valve engines.. but my starter is a homemade one. I use a little "540" (brushed) can-motor to drive a short (1" long) pc. of 3/8" rubber automotive fuel-tubing.. which faces-up perfectly with the Cox .049 Tee Dee-style aluminum spinner.
A few short-bursts on my elec. starter usually gets them going.. providing the glow-head is lit.
It's great to talk about this stuff. We need to keep the IC model engine torch lit fella's.
Roddie,
I never said it was a COX engine.
Still looking for feedback from anyone who has used this insert......
Yes, I think it looks like the one I use. Not sure what number it is. I wore out the hole years ago and used polyurethane glue to hold in some heater hose that was the right size. Maybe 3/8" or whatever. Then I run up the starter and took a die grinder with a burr and made a taper to fit the nut. I use it on everything, even .51s. Made a couple hundred acorn nuts out of 3/4" hex stock and some smaller ones. I hate spinners, always left stranded at the field when the prop breaks. For sleeve bearing engines, just a quick bump is good after a few hand flips to make sure it is not over primed. I give maybe 20 hand flips before I go to the starter. Long starter runs are hard on the piston cylinder too if it is dry, and if it is too wet, it normally fires only for a second or so.
aspeed- Platinum Member
Thank You for the informative reply. Yes just quick bumps and hand turn over is the procedure. One on order.
aspeed wrote:Yes, I think it looks like the one I use. Not sure what number it is. I wore out the hole years ago and used polyurethane glue to hold in some heater hose that was the right size. Maybe 3/8" or whatever. Then I run up the starter and took a die grinder with a burr and made a taper to fit the nut. I use it on everything, even .51s. Made a couple hundred acorn nuts out of 3/4" hex stock and some smaller ones. I hate spinners, always left stranded at the field when the prop breaks. For sleeve bearing engines, just a quick bump is good after a few hand flips to make sure it is not over primed. I give maybe 20 hand flips before I go to the starter. Long starter runs are hard on the piston cylinder too if it is dry, and if it is too wet, it normally fires only for a second or so.
Hey Dave , Are you building a started? If not what happen to the one on the starter ? No Good just wondering
I just flip my standard one around and have at it. Then I learned that a small engine could easily be damaged by such, so no longer use an electric finger on my 1/2a stuff.
» Sullivan Hornet 1/2A Starter.
» Electric starter Insert for 1/2A Question
» Sullivan Cables
» Sullivan CL Handles
» Hornet Sullivan ... what experience do they have?
» Sullivan Cables
