» Feed Station Zebra.. Spring 2024by roddie Yesterday at 8:30 pm
by balogh Yesterday at 5:17 pm
by GallopingGhostler Yesterday at 3:12 pm
by cstatman Yesterday at 1:59 pm
by cstatman Yesterday at 1:41 pm
by Myk Mon May 27, 2024 10:26 pm
» Scientific Gulfhawk
by roddie Mon May 27, 2024 8:59 pm
» Memorial Day 2024
by roddie Mon May 27, 2024 8:48 pm
by rsv1cox Mon May 27, 2024 5:31 pm
Perfect Brand Replacement Needle Valves
I acquired a box of odds and ends recently and there was a big pile of Perfect brand hardware, and included some replacement after market needles. These replace stock needle I'm guessing on OK, Spitzy, Royal and K&B engines I skimmed the forum a bit looking to see of anyone was messing with these, so I'll just post this list of what I have. Again, these are just needles, NOT complete needle valve assemblies with spray bar.
1) #240 1/2A Flex Needle Valve for OK .039, .049,.074,.099 Qty= 1 SOLD!!
2) #241 1/2A Flex Needle Valve for Spitzy .045, Royal Spitfire .065 Qty= 5
3) #244 1/2A Rigid Needle Valve for OK .039, .049, .074, .099 Qty=5 SOLD OUT!!
4) #245 1/2A Rigid Needle Valve for Spitzy .045, Royal Spotfire .065 Qty=5
5) #247 1/2A Rigid Needle Valve for KB .020, .035 Qty= 4
These are all new in package. This was the old cellophane bag with paste board header card and grommet. The cellophane is getting crisp and brittle and some I have held together with scotch tape. A couple are missing springs that should be easy to replace. These are either brass or brass plated. I'll post some pictures in the morning.. Because the packaging is so fragile, I would say these should be used if you have engines that are missing needles. They may fit other engines also. I have some Spitzy engines and a Spitfire and I need to check those. I'm thinking $5 each plus postage??
Type at you later,
Dan McEntee
Type at you later,
Dan McEntee
Last edited by DanMc on Sat Apr 01, 2023 12:50 pm; edited 3 times in total (Reason for editing : Add information and pictures)
DanMc- Gold Member
» Reed Valves For .049
» Cox Reed Valves
» consultation: valves (Cox Pee Wee 020)
» Killer Bee needle valves are available again
» Cox Reed Valves
