» Fun Times Keeping Busy With Lead.....by getback Today at 8:44 am
» Feed Station Zebra.. Spring 2024
by roddie Yesterday at 8:30 pm
by balogh Yesterday at 5:17 pm
by GallopingGhostler Yesterday at 3:12 pm
by cstatman Yesterday at 1:41 pm
by Myk Mon May 27, 2024 10:26 pm
» Scientific Gulfhawk
by roddie Mon May 27, 2024 8:59 pm
» Memorial Day 2024
by roddie Mon May 27, 2024 8:48 pm
by rsv1cox Mon May 27, 2024 5:31 pm
esc ifor the bec only
Hi all just curious as if i can use an old esc in my cox powered airplane because of the weight of 4 AA"s (4 the rx) is double the weight of a 2s lipo. should just order a $12 bec to reduce rx voltage but why spend money there, im sure it will be better spent elsewhere. So has anyone done this? Is anyone doing this? Any possible problems plugging esc to aux port on rx?...thanks to all just dont want to destroy my equipment or plane, if my stuff gets destroyed it better be by pilot error, thanks again
ChrisFromKnoxville- New Member
Levent Suberk- Diamond Member
Re: esc ifor the bec only
Well Hey! WELCOME TO THE CEF!!
We're mostly Nitro Burnin', castor slinging BUT there are a few here who know how NOT to let the magic smoke out of the electric components.
I'm lucky if I get + and - correct in my flashlight batteries. My limited knowledge of ESC and BEC shouldn't lend any truth to the fact that I THINK the ESC is a speed controller and should be connected to the throttle port of the Rx.
Lets see if anyone jumps in,before you go all Johnny Knoxville on them electrons.
It work it is possible to connect in the same port as the gas if wanted use one y onector even two esc in the same port but one must have the positive wire in the center disconnect i sugest use 8v servo like the feather light futaba servo Take example on this boat with hibride system uses an esc with a servo motor in a simple two channel receiver the gas works with the esc the nitro motor is predominant in this system the two electric motor is a back to shore system that is fast and fun
davidll1984- Diamond Member
There are Electric Speed Controllers (ESC) that have Battery Elimination Circuitry (BEC) in them.
If you have a compatible ESC with BEC that runs on a 2 cell lipo poly pack, you can plug that ESC into the motor plug (#3) into the radio receiver.
If it has been programed correctly (the ESC with BEC) will run the receiver as well as the motor.
Until the voltage drops to the cutoff lever on the Esc (with Bec) and stop the motor from drawing any more power fro the 2 cell lipo pack.
But there is enough voltage in the 2-cell pack to keep the receive running to operate the servos for a limited amout of flying time for you to land.
I hope this helps you out on how an ESC with BEC works?
I tried to make the principal of how it works?
sosam117- Diamond Member
thanks, just dont see the need to spend $$$ if I dont have too, hopefully I wont be wishing later i wasnt so cheap, thanks againsosam117 wrote:There are Electric Speed Controllers (ESC) that have Battery Elimination Circuitry (BEC) in them.
Thank you for the linkLevent Suberk wrote:https://www.radiocontrolinfo.com/radio-gear/bec-voltage-regulator/
[quote="Marleysky"]thanks, haha no one likes that that kind of magic smoke
