» WenMac 049 - Glow Plug & Head Gasket replacements?by Ken Cook Today at 3:17 pm
» audio-tach anyone?
by roddie Today at 2:58 pm
by roddie Today at 2:54 pm
by rsv1cox Today at 2:43 pm
by 1/2A Nut Today at 1:58 pm
by Admin Today at 1:11 pm
by rsv1cox Today at 10:26 am
by rsv1cox Today at 7:32 am
line matrial question
AM looking to try another kind of line material besides the common cox dracon string.
One name i see a lot refers to "spider wire" .
A quick check showed its a company making fishing lines.
So there are many diferent versions of "spiderwire"
Could somone recomend ONE EXACT version (a link to the uk amazon site would be perfect) used with cox powerd models.
Thanks
Thanks
cmulder- Gold Member
Re: line matrial question
While yes, many use SpiderWire, and there are many varieties of it, I have switched from dacron to the following: (click on AliExpress Fishing Line link below)
I use the yellow (for visibility) and the strength is 114M-0.16mm-20LB here for my 1/2a planes and it is working just fine. As well, it is very cheap. I am thinking it is also available to you in the UK.
Bee sure not to get the monofilament line ! i use this made by Dyneema co. 12-14 lb. is enough for 1/2A with out to much drag . https://www.berkley-fishing.com/products/nanofil-1248502?variant=34171077689483 Amazon https://www.amazon.com/Berkley-NF1508-CM-NanoFil/dp/B0053X8A0G/ref=asc_df_B0053X88W6/?tag=hyprod-20&linkCode=df0&hvadid=312134190667&hvpos=&hvnetw=g&hvrand=1878344220345608565&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9009605&hvtargid=pla-434798325743&th=1
» Control line question
» control line 1/2 a question
» FUEL LINE QUESTION
» Instant Control Line Flying! T-38 Talon Whip-Line from 2/70 M.A.N.
» fishing line to use for control line
