» A choke-tube with velocity-stack configured Beeby roddie Today at 6:12 am
by cstatman Yesterday at 6:56 pm
» Looking For Comet Tri-Pacer
Tim Stagg's 32" 1/2A Tsunami for .061 Big Mig
Gents,
I came across this one today...it flat dropped my jaw!
Deep ribs, 32" WS, profile fuselage. It is a builder's model for sure. I do have the designer's OK to distribute as long as I give him credit.
StuntHanger requires membership:
https://stunthanger.com/smf/open-forum/12a-tsunami-plans/msg622880/#msg622880
Admin, I'd love it if we could keep a copy here in "Instruction Sheets." The PDF is small. The JPG of the PDF isn't
Meet the Tsunami:
Meet the Tsunami:
Re: Tim Stagg's 32" 1/2A Tsunami for .061 Big Mig
This is a fantastic looking ship.
layback209- Gold Member
Not a big fan of the finish, all the lines are distracting, overall though a nice shape. I would like to see the plans.
Last edited by 944_Jim on Wed Oct 06, 2021 4:42 pm; edited 1 time in total (Reason for editing : added jpg)
Tim is a great guy. I saw him 2 weeks ago at my local r/c field. Typically I see him at some of the contests. Tim has a larger version of this which is electric. Really a neat plane.
Is that a .51 on the nose ? It is a pretty big plane and should make for fling easy .
The first time I saw it, I thought "Big Mig," and asked what he thought.
Mr Stagg reported he designed and built his with a Norvel .061 Big Mig in the nose. The Norvel AME and Big Mugs 061/049 share the same built pattern as the Cox .049 front rotary valve engines, if I remember correctly.
The bolt pattern for the VA, AME, Stels, and Aero are all the same as a Cox TD. The spacing of the beams aren't. The Russian engines require the beams to opened up in between. If you want to use both, use pennies as a spacer in between your two beams and this will allow enough spacing for both. However, the case length is also different and the Cox is longer. Newer Revlite versions were pretty close to the same length whereas the others are shorter in length.
OhMyGosh, that's a really nice looking plane. I want one too. With the shiny look I wonder if it was covered with Micafilm. That light weight film was popular some years ago.
FlipStart- Gold Member
It does have decent lines. If I were to build it I would round the vert stab and horizontal stab and add curved wingtips.
Kevin's passion is painting as displayed on this Tsunami build. I just don't get it though, that's a ton of work. One bad landing and it's done, and it will happen. The plane wasn't even flying correctly. The water graphic on the tail is a masterpiece in itself. I don't have the time or the patience for that much painting and back masking. I recall talking to Tim about his larger Tsunami, he did a similar paint scheme. I believe he uses polyspan vs silkspan and paintwork is not a chore, I remember him saying that shading and inking was done very quickly.
[quote="fredvon4"]https://stunthanger.com/smf/12-a-building/lil-tsunami-build/
Hummana,hummana,hummana...I actually thought that was the plan I asked for. Then the fat ribs popped off the plansheet.
I'd love to see Mr. Tim's machine done in Kevin's livery! Both planes are well above my talents.
Where is that slack-jawed emoticon when you need it?
Funny topic now as Kevin is a local flier and in teh same control line club I was with. I have seen a few of his birds up close, and they are all amazing to see. The first I ever saw of both him and his planes was a Sig Chipmunk around 2000.
I was reading the SH article build and it went to a dead end before finishing ?!?! Kevin King i think That is wild that you know him Chancy
beautiful build, cool weather has got me in the mood to build. I love this season!!!
ChaseBanner- Gold Member
Lay it on us , what you building !!
u guys prob gonna laugh but i have a guillows bird dog I purchased in the spring for micro rc conversion in mind using parts from a hobbyzone champgetback wrote:Lay it on us , what you building !!
ChaseBanner wrote:u guys prob gonna laugh but i have a guillows bird dog I purchased in the spring for micro rc conversion in mind using parts from a hobbyzone champgetback wrote:Lay it on us , what you building !!
Actually sounds like a cool project! My little Champ is still thumping along, by will surely have its innards "harvested" when the time comes!!!!
Nothing funny about that, pretty cool actually.
Sounds like a fun little project. Keep us in the loop as you go along.
really the bird dog is more like a weekend build and was suppose to be a backup in case cold weather makes itself more prominent than a typical arkansas winter usually does. Still looking for a kit but havnt found anything that tickles my fancy at a reasonable price. really makes me miss the house of balsa schoolyard scale kits we were able to pick up for $50 or so bucks
TD ABUSER- Gold Member
