Cox Eliminator Dragster Cox_ba12
Cox Eliminator Dragster Pixel
by roddie Today at 1:12 pm
» Tatone EM-7
by GallopingGhostler Today at 12:16 pm
» L4 Grasshopper
by roddie Today at 12:16 pm
by Ken Cook Today at 11:59 am
» COX .020 POWERED SPEEDSTER
by gkamysz Today at 11:51 am
by roddie Today at 11:34 am
by balogh Today at 8:18 am
» K&B .09 Torpedo Engine
by Ken Cook Today at 6:42 am
by roddie Yesterday at 7:50 pm
by TD ABUSER Yesterday at 4:44 pm
» Ultrasonic Cleaners??
by MauricioB Yesterday at 3:32 pm
» Dodge Viper - What a waste but brilliant marketing
by rsv1cox Yesterday at 7:47 am
Cox Eliminator Dragster Empty
Cox Eliminator Dragster Empty Cox Eliminator Dragster
Post  Propfan Wed Sep 08, 2021 8:08 am
Hi,
I picked up this cool Cox Eliminator to restore. I found some repo stickers and am looking for the dummy engine, parachute cover and parachute. Does anyone have any of those parts for sale or know of anyone making repo parts for these?
Propfan
Propfan
Moderate Poster
Moderate Poster
Cox Eliminator Dragster Empty Re: Cox Eliminator Dragster
Post  Lukemiester Wed Sep 08, 2021 9:05 am
Propfan wrote:Hi,
Take a look on eBay. There may be at least some of the parts there
Lukemiester
Lukemiester
Post  Cribbs74 Wed Sep 08, 2021 9:12 am
The dummy engines pop up once and a while. Chute cover is available as a repop.
https://www.ebay.com/itm/Cox-Parachute-Cover-Reproduction-Pinto-Vega-Funny-Car-Dragsters-/224088895452?mkcid=16&mkevt=1&_trksid=p2349624.m2548.l6249&mkrid=711-127632-2357-0
Chute itself I haven’t seen, but should be real easy to make. I don’t have a dragster so I don’t look for stuff, just what I have seen here and there.
Post  Propfan Wed Sep 08, 2021 11:27 am
Thanks. I was wondering of the Pinto and Vega covers would fit.
Propfan
Propfan
Moderate Poster
Moderate Poster
Post  crankbndr Thu Sep 30, 2021 6:47 am
Engine
https://www.ebay.com/itm/274958617177?hash=item4004cf8a59:g:vqoAAOSw7uhhTOYC
Cox Eliminator Dragster Screen28
parachute
https://www.ebay.com/itm/274958618417?hash=item4004cf8f31:g:hyAAAOSw8M9hTOb3
Post  FlipStart Thu Sep 30, 2021 8:54 pm
That's funny, when I saw this post I was thinking, Cox didn't make the Eliminator, but I was thinking of a different one. Apparently Cox did make an Eliminator. I was thinking of the Russkit slot car dragster.
http://slotblog.net/topic/95464-about-the-russkit-dragster/
FlipStart
FlipStart
Post  Propfan Sun Oct 03, 2021 12:53 pm
Thanks. Found a dumy engine. Now looking for the parachute cover.
Propfan
Propfan
Moderate Poster
Moderate Poster
Post  Davenz13 Sun Oct 03, 2021 5:10 pm
Did you get this one.
Expensive but these are very hard to find, especially nos.
Sometimes the bargain is not what you paid for it, it's obtaining it Eyebrows
https://www.ebay.com/itm/274958617177?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Same seller also had this, also expensive and hard to come by.
https://www.ebay.com/itm/274958618417?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Chute covers genuine are hard to find but repro ones are plentiful
https://www.ebay.com/itm/224088895452?hash=item342cbd2fdc:g:h~cAAOSwjLFfFvgk
Here's a bit more info on the chutes and covers
Regarding the difference between the chute covers the Pinto and Vega’s take the same part number chute kit 6573.
The Eliminator II - A/A Fueler have chute kit 6173. Not only are the release mechanisms different the chute covers are too.
Here’s the two kits I have.
Eliminator- A/A Fueler chute kit
Cox Eliminator Dragster Cox_ch10
Cox Eliminator Dragster Cox_ch12
Eliminator- A/A Fueler chute and  Vega/ Pinto  kits. Vega/ Pinto kit is on the right.
Cox Eliminator Dragster Cox_ch11
Looking closely, you can see there are quite a few differences between the two covers.
Cox Eliminator Dragster Cox_ch14
The black cover (Vega/Pinto) has a small raised piece which has a hole in it for attaching a short piece of string ending with a loop which is where the chute would be attached to. All the sides of the cover are equal. The cover has quite square corners.
Cox Eliminator Dragster Cox_ch13
The white cover (Eliminator- A/A Fueler) has two small rectangles cut out of opposite sides, one of which has a cutaway to it.
Cox Eliminator Dragster Cox_ch15
There are two small holes in the cover, one in the centre of the back and one in the side that has a small rectangular hole but is not cutaway. The chute string passing from inside the cover through the hole in the centre of the back and running outside the cover then through the hole in the side where it is knotted sufficiently to prevent it pulling out. This cover has quite rounded corners to it.
Cox Eliminator Dragster Cox_ch16
Looking at these, the repro cover listed above is for Vega/Pinto’s but not correct for the Eliminator- A/A Fueler  although it may, or be made, to fit.
Dave
Davenz13
Davenz13
Post  Propfan Mon Oct 04, 2021 7:19 am
This is great info. Thank Dave. Hopefully someone makes an accurate repo of these someday.
Propfan
Propfan
Moderate Poster
Moderate Poster
Post  Dougad50 Fri Oct 28, 2022 9:56 pm
Cribbs74 wrote:The dummy engines pop up once and a while. Chute cover is available as a repop.
If you get those on eBay’s you will need to use loctite plastic epoxy about 1/8 inch thick inside each corner and after dry file the outside if each corner with a round profit to fix into the hole of the dragster. Wind pain semi glass white. The funny car they fit fine but the square corners won’t fit dragster unless modified
Dougad50
Dougad50
Bronze Member
Bronze Member
