» Help Pee Wee tank cap .020by MauricioB Yesterday at 10:11 pm
by F4D Phantom II Yesterday at 8:33 pm
» Post your Older books
by rsv1cox Yesterday at 7:09 pm
» I break for Turtles....
by Ken Cook Yesterday at 6:27 pm
» Ball - Socket Joints
» A little nostalgia…
by grant.symes Yesterday at 3:29 am
by GallopingGhostler Yesterday at 12:09 am
[solved]most Efficent Glowhead Clip for Norvel Engine
Page 3 of 3
Page 3 of 3 • 1, 2, 3
Re: [solved]most Efficent Glowhead Clip for Norvel Engine
Started to hook wire to the clip and so far the clip has stumped me on assembly. Do you have a good closeup of the finished clip so I can figure out how to assemble it?
fargophil- Bronze Member
Levent Suberk- Diamond Member
It isn't same in shape. It is for bigger engines. However assembly is similar.
Successfully assembled it Phil?
had time to download the picture you sent and print it , much better than the instruction on the back of the card which I finally noticed. off to dialysis this morning so will assemble when I get back. I have a Lil Stinker plane I want to start the engine on.
Watch for momentary shorts!
Guys,
I also picked up the big brother. And it IS bigger! I'll try to submit a picture of this little one on a Medallion .15 along with the bigger Dubro clip later this weekend. This little one may take some tweeking to fit a Pee Wee or Tee Dee .020 so it can clamp on the head. As is, it touches the .020 cylinder just below the head. Does the black conduct electricity?
When you wire up your clip, be aware of the area where shorts can occur. The 90 degree bend is so the sliding contact ring terminal doesn't short against the fixed one. The bent one needs to come off the side of the clip so as it goes in and out with the terminal.
Levent, I'll PM you later tonight or tomorrow.
Thanks.
A piece of heat shrink tubing on short fixed terminal can solve the short circuit problem.
Got a green thumb from me...
Good for you, Phil!
When I checked it on my PeeWee, I didn't like the "hold." I wanted to check the fixed side to see if flipping it over in the body would get it on the head instead of the cylinder. But then, I do have a habit of over-thinking things.
Does it grab and release.in a way that you are confident using it? Have you tried it on a small Norvel?
Another confirmation for .020….I haven’t cranked an engine with it but seems like it’s easiest to grip it like a syringe to install and release….. To get it off cleanly depress the spring with the thumb and roll the back end up just a bit and it will release from the tip of the plug cleanly without hanging….. Classy little clip!!!
rdw777- Diamond Member
i am reasonably confident it will stay on. Ran the engine for a full tank with the clip on, just to see how vibration effected it an it stayed on. Haven't tried a small Norvel yet, tomorrows project. Can only take so many fumes in the shop in one day. To cold to run it in the garage or outdoors.
Thats good to know , Thanks Phil for bearing the fumes and cold !
Is there one more clip in Santa's bag?
Hello Jim,
I'm the new old guy and haven't made the required number of posts in order to send you a PM.
Do you think it would be okay (safe) to post my P.O. Box #?
Wingman
Wingman
Wingman- New Member
Mr. Wingman,
I recommend NEVER posting email addresses/physical addresses/phone numbers in any website's publicly viewable threads. These threads can be viewed without logging on. The information then can become tools for identity theft. PM's on CEF however, are not publicly viewable. I won't make that last claim for ALL websites.
Your wish is my command...I'll have it packaged within the 24 hours. I may hold off on mailing yours (and Gary's/Russ's) until after Christmas. Sorry Gary and Russ, I arrived at our local PO this weekend to find a line out the door. Needless to say, I wasn't waiting two hours for a couple of glow clips. Maybe you'll have the clips before you take down the tree. Feel free to take a picture of the clip hanging in the tree (no obligation to keep the tree up)...chuckles! I may try purchasing/labelling at the house tonight so I can drop them off in a street-side mailbox tomorrow. My packaging is light, and no bigger than an envelope. It shouldn't take very long to get there.
Please reach out to me via "reply to PM," since I just sent you one. Or hit me up via off-site email (in the PM). I have two (mentioned above) to take to the PO, so I can add yours to the stack before I go. If I don't hear back in the next day or two, do not fear I'll run out of these. Yours will be packaged and waiting until we can PM or email.
Sincerely,
Jimxxxxx@xxxxx.xxx
Sincerely,
Jimxxxxx@xxxxx.xxx
Re: [solved]most Efficient Glowhead Clip for Norvel Engine
Jim,
Many thanks, for the advice and your generosity in offering these Kwik-Klips. I was one of the lucky ones who responded to your offer. My Klip arrived today.
Thanks again,'
Wingman
Thanks again,'
Wingman
Wingman- New Member
Ok...I know. Bad form to drag one out of the past. This is for Juan in PR and Dave Nyce from SH.
I sent a few more off with a recommendation to make removing these tiny clips from engines much easier. Imagine the tooth pick in the following images is a screw or really small all-thread (squint if you must).
The screw that clamps the two halves together should be replaced with a 1.25" (30 mm) long screw. Use a nut on both sides. This makes the clip easier to squeeze/release using index and middle fingers on the screw while pinching with your thumb:
944_Jim wrote:Ok...I know. Bad form to drag one out of the past. This is for Juan in PR and Dave Nyce from SH.
Hello Jim
I want to thank you for the 1/2A glow clip and the idea on how to make it easier to remove. I started the assembly after I saw your mod. I clamped both sides and using a 4-40 tap I tapped the hole that holds both sides together all the way . Then on assembly I used a 4-40 stainless steel cap screw, placed a small 4-40 nut on the recess that one side has and after adding the sliding part I screwed them together. Even without nuts to hold the screw in it went in a little tight and I don`t think it will back off. I did like rdw777 and didn`t use any terminals just wrapped the wire around the screws and tightened both. I really like this small clip it works real good on my Wen Mac .049 R/C engine. I had to be very careful with the big clips not to stick a terminal inside the exhaust port. Thanks again. here are some pics.
Juan
F4D Phantom II- Gold Member
Why didn't I think of that? I have a couple of these clips, but they're a pain to pull off of a running engine, especially a .09 or .15 engine. That long screw solves my problem.
The Lightbulb Mark
The Lightbulb Mark
batjac- Diamond Member
» Compact Glowhead Clip
» Cox Glowhead Starter Clip Question
» "Weird Veco Engine" Mystery Solved
» Reed valve engine video clip
» Researching a Norvel .061 Engine
Page 3 of 3
