» A choke-tube with velocity-stack configured Beeby roddie Today at 8:23 am
by Ken Cook Today at 8:06 am
by rsv1cox Today at 7:32 am
» Looking For Comet Tri-Pacer
2019 CEF Run What YA Brung UNLIMITED speed contest Build Log by 944_Jim
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: 2019 CEF Run What YA Brung UNLIMITED speed contest Build Log by 944_Jim
In order to inset the engine into the wing, I had to carve out a good chunk of "leading edge." The rib is to add stiffness to the wing, like another fuselage would on an F-82. That outboard edge was awfully floppy until it was added.
Ok. Fixed mine...that's all anyone could come up with? Oh, and I did chuckle.
944_Jim wrote:Ok. Fixed mine...that's all anyone could come up with? Oh, and I did chuckle.
A picture's worth a thousand words!!
The only word that comes to me is YEEHAA!
Dave P.- Gold Member
That is one mean looking Model !!
Looks good, the plane that is, The weiner tank is suspect.
That wiener tank (giggle) is the "housing" for the JATO. I hope to have video of this. I may be able to stay upright for about 6 laps. If I make the whole ten, I'll consider this a success! The engine needs to be benchrun to find out how much fuel for 45-65 seconds. I hope that should be about 13 laps or so.
Can you tell me how does that dolly work , those holes in the wing look pretty tight for the plane to get out of ?
Hi Eric,
Just tonight the holes were enlarged and a bit of plastic control rod sheath/tube was super glued into each hole. The plastic tube should slide/release smoothly (I hope). I admit there will be no development time, nor desire to fine-tune...it flies, bores a hole in the ground or burns. No other options wanted or needed. One time flight only!
The uprights or pegs sit tilted back just a bit. I hope as long as neutral elevator is applied that the model will sit "under" the rearward tilt. Once UP is commanded, then the model will (hopefully) pivot on the back edge of the wing, this bringing the front off the pegs.
Elevator was sewn tonight too. Hopefully paint goes on tomorrow. Still need to make up a set of lines, find a rocket engine, complete my fuel cell/balloon cork.
Getting closer...inspired to completion by Paul Gs SR-71!
944_Jim wrote: I hope to find my son's water balloons.
Water balloons are designed to bust. Too thin. Use a regular balloon.
Ok. Clock is ticking and time is almost out. But I will.co timue, even if I miss entry.
I mentioned earlier that I used Deft Sanding Sealer to seal the wood. I was concerned about AeroGloss over Deft. This morning's test sealed it! I will continue to use Deft in the front end of a build with a topcoat of AeroGloss...at least until I run into problems.
Here is a teaser. I hope to be able to see the blue against the trees:
Jim , Did you find the rocket engine U wanted for it ? I take it were the paint pole is , is where the rocket engine will go .
Hi Eric,
I have to look in the BOTTOM box of childhood toys. ISTR a spare B6-x engine in there, and being too concerned about overhead traffic. I have an Air Base several miles north, and I'm under one of the corridors for the local airport.
Yes, the engine will go where the paint pole is. Both recip and chem engines have a smidge of down thrust and right thrust. I hope my SWAGs are good enough.
The stooge may need some bracing, and I have to rig a line path past the rocket nozzle. The intent is the rocket will burn through the "launch line" to release from the stooge.
Getting closer:
Getting closer:
Ok...taking this one to the very end. Let's just say "Life has been busy!"
I plan on trying the release line around the front of the rocket pod, and behind the exhaust nozzle. The idea is the string burns through releasing the model and dolly from a stooge.
Here is the concept run:
https://youtu.be/UmOdwS4m2bQ
COOL was the simulated landing
» 2019 CEF Run What Ya Brung Unlimited Speed Contest Build Log
» duaneh's 2023 CEF Run What Ya Brung Unlimited Speed Contest Build Log
» 2023 Run What YA BRUNG UNLIMITED SPEED Contest
» 2018 to 2019 CEF Run What YA Brung UNLIMITED speed contes (CLOSED)
» Roddie's CEF 2019 R.W.Y.B. Speed Contest prep..
Page 2 of 3
