» A choke-tube with velocity-stack configured Beeby roddie Today at 6:12 am
by cstatman Yesterday at 6:56 pm
» Looking For Comet Tri-Pacer
Engine mount ? Hardwood
I'm going to be scratch building my first S1 R/M. I have a piece of 1/4" red oak. This should work for making my mounts out of for the S1, right?
oldguy- Gold Member
Re: Engine mount ? Hardwood
Oak likes to split along the grain. I would use birch, beech, or maple. Something closed grain. Spruce would work too in a pinch.
Jason_WI- Top Poster
The Sterling S-1 A ( Sheeted leading edge ) used poplar for the mounts. Engine mounts should be 3/8"x 1/2" for a .35 size engine. The box didn't lie, it said hardwood mounts. Poplar is a hardwood due to it's species but the wood itself is far from being hard enough to use for it's designated purpose. A&J Free Flight kitted The YAK and F-51 Mustang in the 80's based exactly on the Sterling Kits using the Sterling's instruction sheets. They used red oak for engine mounts. While it wouldn't be my choice if I was building one today, I wouldn't hesitate to use it. I've had my A&J planes flying since 1987 and they're still flying today. Just let me mention though that a Sterling nose is very poorly designed. The engine bearers are 2" long and only encapsulated between the 2 doublers which prevents the doublers from being squeezed together but doesn't do much for stiffening the nose from vibrations. Running the engine bearers back into the fuse offers a much stronger front end. The doublers on a stock Ring only extend to the back of the leading edge. Very very poor which sets up a stress riser allowing the nose to break off directly in front of the wing. Reduce the stock 1/8" doublers to 3/32" 5 ply not 3 ply birch and extend the doublers to the high point of the wing and you won't regret it.
I would personally use maple Jim... and 1/4" is NOT thick enough.
My S1 fuse is 1/2" balsa. If I were to re-make beams/bearers for it.. I would cut them to a 1/2" x 3/8" dimension. The 3/8" dimension is what would be drilled-through for the machine-screws to mount the engine. Note Ken Cook's advice on the "length" of the beams..
Actually... you might want to go with 1/2" x 1/2" if you opt for installing threaded-inserts.
In any case; the plywood nose-doublers are used to cap-off the beams. Note Ken Cook's advice on the grade of plywood.. and extending them back further than noted on the plan.
See if you can find an old maple bureau that's being thrown out. Seriously.. one solid-maple drawer-panel would have enough square-inches of stock to make beams for dozens of models. Ripping strips on a table-saw is not difficult.
Ken, Robbie.
I meant to say I would double the 1/4" redwood. And looking at the plans I see what you are talking about, running the engine bearers and doublers back further over the wing. I will take your advice on that, and use the thinner 3/32 doublers. And Yes the fuse is 1/2".
oldguy- Gold Member
Hard maple, not any of the soft maple varieties. Order through Brodak, or find a plank, old chair, locker room bench and go to town with a table saw.
Yes i said chair, maple kitchen and dining sets are almost exclusively hard maple and a broken chair has a lifetime of wood in it.
Since this is a contest plane that may not fly much oak might be fine. White oak would be better.
Well I went ahead and ordered up some maple 1/2 x 1/2 from Brodak. I will be mounting a McCoy .35 on the nose of this R/M. I'm also debating with myself, whether to order a set of ribs or make myself. I have always made them myself but nut for a .35 size plane.
oldguy- Gold Member
Bigger ribs are easier than small ones. Dont sweat it.
pkrankow wrote:Bigger ribs are easier than small ones. Dont sweat it.
Hey thanks for that.
oldguy- Gold Member
I'm glad you went ahead and got the Maple.
You know oak has tiny xylem tubes through its length. Pick up an oak dowel and suck or blow into the end grain. It will pass air like a soda straw. I expect that betrays some undesireable weakness.
RknRusty wrote:I'm glad you went ahead and got the Maple.
Only red oak does that. They make whiskey barrels out of white oak. White oak has tyloses which seals the ends of the pores. red oak does not.
I can tell you from experience, red oak works just fine . It wouldn't be my first choice but it does the job. I've used it on several combat foamies and have stuffed them into the ground without failure. In addition, it's far stronger than the rice wood used in the ARF models that use larger engines than the Ringmaster. Your only trying to keep the doublers from squeezing. The nose of a Ringmaster in it's entirety is far weaker than the wood bearers themselves. In other words, the nose is going to break at the wing's leading edge before the mounts can be broken.
Hickory is the hardest wood we have in the US as far as I know. I have a bunch of it at my disposal. Luckily hard rock Maple is stockpiled at my home.
Cribbs74 wrote:Hickory is the hardest wood we have in the US as far as I know. I have a bunch of it at my disposal. Luckily hard rock Maple is stockpiled at my home.
Hickory is pretty hard stuff and available most anywhere. We have trees that grow around here called ironwood. Some kind of hornbeam. We use it for wood bearings. I cut some on my bandmill into boards to be used in the bottom of an auger bunk feeder that the auger rides on. It threw sparks off my saw blade when cutting it. It wears better than uhmw plastic.
engine mounts
I know there might be laughs over this, but I have since the 70's, used new popsicle sticks for beam engine mounts. They are made from White Popular, I epoxy between the layers and clamp together. For the .35 size engine, I use six sticks which will give a 1/2 inch width for the mount. For a .15 engine, I will use five sticks, it will give a 3/8 mount. And for 1/2 A, only 3 sticks are needed for a 1/4 mount. In years past when I flew some combat, a scratch built from plans, I still used this method for engine mounts. Simple and easy, an in all honesty no problems at all. If you have a Hobby Lobby near, a box of 1,000 popsicle sticks goes for under $5.00.
Eddy- Silver Member
Eddy wrote:I know there might be laughs over this, but I have since the 70's, used new popsicle sticks for beam engine mounts. They are made from White Popular, I epoxy between the layers and clamp together. For the .35 size engine, I use six sticks which will give a 1/2 inch width for the mount.
Eddy, I'd say instead perhaps you had the last laugh. Basically you were making plywood. Even though the grain was going more or less in the same direction, the Epoxy was imparting strength to the layers, and also strengthening the wood by soaking into the pores.
Plus, you've given me thoughts on how I can manufacture engine mount beams and other aircraft uses. One of the oldest hobby shops in Amarillo Texas closed a couple years ago. Another in Lubbock did too. All that's left is the one hobby store in Amarillo that sells mostly R/C car fuel and related, not much aircraft stuff.
Eddy wrote:I know there might be laughs over this, but I have since the 70's, used new popsicle sticks for beam engine mounts. They are made from White Popular, I epoxy between the layers and clamp together. For the .35 size engine, I use six sticks which will give a 1/2 inch width for the mount. For a .15 engine, I will use five sticks, it will give a 3/8 mount. And for 1/2 A, only 3 sticks are needed for a 1/4 mount. In years past when I flew some combat, a scratch built from plans, I still used this method for engine mounts. Simple and easy, an in all honesty no problems at all. If you have a Hobby Lobby near, a box of 1,000 popsicle sticks goes for under $5.00.
Hey Eddie, no laughs from me as a guy who just mostly scratch builds and fly's for fun i'm always looking for ways to do things out of the norm.I'm going to try your idea on my next build what ever that turns out to be.
Thanks eddie
oldguy- Gold Member
Forget about using poplar or birch, or popsickle sticks for a model that is powered by a Cox TD [or more].
New Hampshire "ROCK MAPLE" was what my LHS sold for mount material and there was a good reason why.
Some years later the maple became lighter, softer and not as good because the selection of the best OLD GROWTH WOOD was getting more scarce.
Maple is still your best bet..but you might need to order from a hardwood specialist to find you some of the good stuff..
TD ABUSER- Gold Member
There's been some good advice on how to use any of the hardwood choices for engine bearers posted in this thread. What I've taken from those is; to build the profile-style nose of your model airplane with engine bearers that are beefy-enough for the recommended engine screws.. and long-enough to transfer some vibration rearward, to be absorbed closer to the central structure of the model. Hacking-up a kit-fuse is not for the faint of heart.. and many modelers won't do it.. but you can make new extended plywood doublers to hide the hacking!
Avoid having a "diving-board" nose on that profile model-airplane! Vibrations can come from a poorly or non-balanced propeller.. as well as harmonic-vibrations that may come from the engine... when it's running in its sweet-spot. Fuel can get foamy.. a less-than quality needle-valve could drift.. wheel-collars can loosen.. as well as other fasteners..
There's been an old desk on the side of the road on my work commute. It's a big-oL wooden desk with 6 drawers.. looks like it came out of a courthouse. I've ogled it.. and imagined what type of wood it was made of. It would be a sin to remove a drawer for it's hardwood (no doubt it would have dovetail joinery) I imagined it as "my desk".. in "my workshop".. but it would take four strong young adults to move it into a home and down a set of stairs. It's been there more than a week and i really hope that someone rescues it.
Hi All,
The fuelproof/wing/fuselage joint is the most important.
A nice Cox engine will erode any wood, over time...
Good Rock Maple is very nice.
Same density as aluminum, but easier to glue...
Transferring the power of a Cox to wood,
Is the challenge.
Someone will do it...
One day,
Dave
Is the challenge.
One day,
Dave
HalfaDave- Platinum Member
I used maple for some engine bearers on the F2D combat planes for a while. It was much lighter than the aluminum that is commonly used. I revealed this knowledge breakthrough to the local combat guys and they like aluminum better because it bends and doesn't break. That would lose a match. For me, that is not an issue, but it is more trouble to fuel proof it so I use aluminum now anyway. I still will use the maple on other stuff though. I found a nice knot free straight grained piece of flooring at a Lowes store that made a lifetime supply. Some stores would not sell single pieces, but that one was by the sq. ft. so I got a long piece and used the table saw and the milling machine to get it to size because the table saw has a lot of slop, being a $5 garage sale item. Had my eye on some bamboo stock. It is very hard and strong but kind of heavy.
aspeed- Platinum Member
Why can't I ever get away with doing stuff like this...?Eddy wrote:I know there might be laughs over this, but I have since the 70's, used new popsicle sticks for beam engine mounts. They are made from White Popular, I epoxy between the layers and clamp together. For the .35 size engine, I use six sticks which will give a 1/2 inch width for the mount. For a .15 engine, I will use five sticks, it will give a 3/8 mount. And for 1/2 A, only 3 sticks are needed for a 1/4 mount. In years past when I flew some combat, a scratch built from plans, I still used this method for engine mounts. Simple and easy, an in all honesty no problems at all. If you have a Hobby Lobby near, a box of 1,000 popsicle sticks goes for under $5.00.
Are you wood screwing / sheetmetal screwing a Cox TD .049 to 3 plys of popsickle sticks...?
Back in the day some TD .049 Combat Planes used 5 ply 1/4" thick aircraft plywood..and that didn't work real good.
The screws would loosen before the plane ran out of fuel.
» Cox pt19 engine mount
» Engine mount
» Tee Dee Engine Mount
» new 2.0 rc 1/16 049 powered bugy upgrade tee dee
» Another proposed design by Roddie
» Engine mount
