» Wen Mac Aeromite/Challengerby rsv1cox Today at 6:38 pm
by rsv1cox Today at 5:22 pm
by Admin Today at 3:59 pm
by GallopingGhostler Today at 12:31 pm
» Modelsmodels
by Coxfledgling Today at 1:33 am
» 010 head stops glowing
by balogh Today at 12:26 am
» WILLY NILLY
by MANDALAY Yesterday at 9:52 pm
by TD ABUSER Yesterday at 4:07 pm
» Ignition Points for Ohlsson 23
by crankbndr Yesterday at 2:29 pm
by Cox International Wed Sep 18, 2024 10:35 pm
» Unique Foxie partzie. Potential fishing line/paper weight or something else.
by rsv1cox Wed Sep 18, 2024 2:48 pm
» Cox P-40 Clone Project - I just can’t leave well enough alone.
by akjgardner Wed Sep 18, 2024 10:32 am
off topic air foils
off topic air foils
which airfoil creates the most lift at slow air speeds
cjuliano- Bronze Member
Re: off topic air foils
can you show me a picture of that wing
nitroairplane wrote:cjuliano wrote:can you show me a picture of that wing
there ya go.
Good stuff to memorize.
thanks
how do i post images
WingingIt74 wrote:There also is a KFm airfoil. It's wild that it actually works.
Those are crazy I have to use them one day!
i did this
https://3756310061492422105-a-1802744773732722657-s-sites.googlegroups.com/site/fmjehufsamtgpeyi05320/home/IMG_1075.JPG?attachauth=ANoY7crElwPFRn7V7xw-2-LEHOi3LebV8GUilelH-LROL5DLw9XsNyHjgRva9ygddeZNv1RZVM-M0v0TV5ojqlHUwEEZSrJaeUX67Wl3lbGEeHnJBiy72yHHdJP8Mn6kFXhm4OPceErVZl-ilE18y1MYyPBHIMmV1t-wI4O72SsSMlj4MxdMEmq6AfkeyF7HAIFNjc4Reisyi6h2WVZomj-ZHXZxUzWEeg%3D%3D&attredirects=0
think it will work well
any one
I think you need to give the motor a fair bit of down thrust, it'll just keep looping otherwise.
Besta luck
Besta luck
John Goddard- Diamond Member
John Goddard wrote:I think you need to give the motor a fair bit of down thrust, it'll just keep looping otherwise.
John's made a very valid point.
If your motor is mounted as shown in the picture, the plane will be uncontrollable. Downthrust, or having the motor pointed downward relative to the angle of attack (the relative angle of the wing as the plane moves thru the air), is necessary to keep the aircraft from continually trying to climb, especially with high lift airfoils. Within a specific speed range, lift is related to the square of the velocity, so it goes up quickly as the speed increases. Before RC, freeflight planes had to be trimmed to fly on their own without pilot input. Downthrust was used as one of the trimming components. When under power and flying faster, the downthrust worked against the lift generated by the wing to keep the plane from ballooning or pitching up. It would be adjusted so the plane would fly in a slight climb. When the motor quit, the speed dropped off, as did the lift. But without the motor trying to pull the nose downward, the plane would be set up to fly in a fairly flat glide.
Downthrust is still used today on planes with lifting airfoils --- partially to compensate for lift to velocity squared relationship. When looking at your plane from the side, with the fuselage sitting as you think it will be angled in the air, the motor should be pointed slightly downward.
400g AUW is fairly light and the Surestart will haul it around quite well.
andrw
[quote="nitroairplane"]
there ya go.[/quot
YEA !!!!!! for UNDER-CAMBER!!!!-----"Like Flying with Your Brakes On!"
there ya go.[/quot
[quote="WingingIt74"]There also is a KFm airfoil. It's wild that it actually works.
Thanks a LOT, Travis. Just what I needed....something ELSE I got to try !!!!!
Cool! I'll have to check it out on the airport's WiFi.
Also, I wasn't challenging the performance claims..learned along time ago to keep my criticism to my self 'till I've got a little knowledge !
Wonder how easy this would be to apply to a slab balsa airfoil???? Looks like a little laminating and kazoom ! Off to the races !
Kim wrote:Wonder how easy this would be to apply to a slab balsa airfoil???? Looks like a little laminating and kazoom ! Off to the races !
The KFm airfoils are really quite interesting. Of course, the supporters love them and the detractors say the efficiency claims are bogus. I've built several electric foamys that use the KFm1 and KFm2 foils and they do work fairly well, particularly at the slower speeds we fly.
I build using Dollar Tree Readiboard with the paper peeled off, so with a little care, the leading edges can be nicely rounded. In the attached pic, I use Scotch storage tape across the area 1-2, then roll the panel over toward the beveled side. What's left of the bevel crushes and the LE with tape is round. The "step" is usually 3/16" or 1/4" square balsa and also serves as a spar. Two pieces of foam, one balsa spar, a little glue and a strip of tape --> your done. Ta-da: you have a wing for 50 cents.
andrew wrote:Kim wrote:Wonder how easy this would be to apply to a slab balsa airfoil???? Looks like a little laminating and kazoom ! Off to the races !
Well... cool....Item # 37,320 on "Kim Lists of Projects to Try/Complete Before He Croaks" .... !!!!!!!!!!!!!!!!!
» flat botom air foils
» micro Servo substitute=musclewire
» Way off topic...
» Very off topic
» Way off topic
» Way off topic...
» Very off topic
» Way off topic
