What Engine does this Cylinder/piston belong to Cox_ba12
What Engine does this Cylinder/piston belong to Pixel
by batjac Yesterday at 8:05 pm
by gkamysz Yesterday at 7:29 pm
by roddie Yesterday at 7:22 pm
by rsv1cox Yesterday at 1:38 pm
by GallopingGhostler Yesterday at 1:04 pm
by 1/2A Nut Yesterday at 12:43 pm
by roddie Yesterday at 11:13 am
by sosam117 Yesterday at 9:32 am
by rdw777 Yesterday at 7:24 am
by rsv1cox Wed Nov 20, 2024 1:21 pm
by 1975 control line guy Wed Nov 20, 2024 6:17 am
by rsv1cox Tue Nov 19, 2024 4:35 pm
What Engine does this Cylinder/piston belong to Empty
What Engine does this Cylinder/piston belong to Empty What Engine does this Cylinder/piston belong to
Post  getback Sat Apr 09, 2016 2:24 pm
Thanks for any Help its a .049 size What Engine does this Cylinder/piston belong to Unknow10 What Engine does this Cylinder/piston belong to Unknow11 ERic Huh...
What Engine does this Cylinder/piston belong to Empty Re: What Engine does this Cylinder/piston belong to
Post  roddie Sat Apr 09, 2016 3:19 pm
W.A.G..... (wild guess...)
What Engine does this Cylinder/piston belong to Baby_m10
Post  TDbandit Sat Apr 09, 2016 5:12 pm
Looks to me to be an OK cub cylinder. (Bandit)
TDbandit
TDbandit
Post  Admin Sat Apr 09, 2016 5:23 pm
TDbandit wrote:Looks to me to be an OK cub cylinder. (Bandit)
I agree, looks like an OK Cub cylinder.
What Engine does this Cylinder/piston belong to Cub049A
image from: http://beseenontheinternet.com/VAHS/engines_and_engine_accessories.htm
Post  roddie Sat Apr 09, 2016 6:33 pm
I don't see a land below the exhaust-port on Eric's cylinder like there is on the Cub. If Eric's has dual ports.. than my guess is wrong.
What Engine does this Cylinder/piston belong to Ok-cub10
The engine below is a McCoy .049 "Baby-Mac" which looks to have it's cylinder more like a liner set-into the case.
What Engine does this Cylinder/piston belong to Mccoy_10
It's really hard to tell from Eric's photo.. but it appears to me that the port is below the fins.
Eric.. is the piston free in the bore (not seized)?
Post  TDbandit Sat Apr 09, 2016 7:12 pm
The OK as you probably know has three small intake holes 120 deg apart that exit in between the exhaust slits (the other two would be out of sight) It is very hard to see but the exhaust groove is there you have to carefully look to the right side just above where the port hole is using the table wood as a background and you can just see it, it appears as a wide gap between the cooling fins and the lower most fin. The piston being at TDC doesn't help with seeing the port. (Bandit)
TDbandit
TDbandit
Post  batjac Sat Apr 09, 2016 10:00 pm
"What Engine does this Cylinder/piston belong to"
Mine..  Please, drop it in an envelope and send it airmail....    Laughing
The Facetious Mark
Post  Oldenginerod Sun Apr 10, 2016 4:09 am
TDbandit wrote:The OK as you probably know has three small intake holes 120 deg apart that exit in between the exhaust slits (the other two would be out of sight) It is very hard to see but the exhaust groove is there you have to carefully look to the right side just above where the port hole is using the table wood as a background and you can just see it, it appears as a wide gap between the cooling fins and the lower most fin. The piston being at TDC doesn't help with seeing the port. (Bandit)
I fully agree. Confident that it's OK Cub by the look of the round intake port below the land. Piston crown looks right too.
Rod
Post  getback Sun Apr 10, 2016 5:26 am
Sorry it was a long day and a short night ,, It does have 3 what appears to be intake holes below three exhaust ports , and yes it is seized or pushed too far to the top of the liner .. Eric
