starting a sure start - Page 2 Cox_ba12
starting a sure start - Page 2 Pixel
by TD ABUSER Today at 2:30 am
starting a sure start - Page 2 Empty
Page 2 of 2 Previous  1, 2
starting a sure start - Page 2 Empty Re: starting a sure start
Post  G-Money Sun Aug 14, 2011 11:59 am
Sorry to interrupt your carburetor fight but I got the sure start to run! I went down to the local animal hospital to get a syringe so I don't have to take the glow plug off all the time. I removed the spring starter and after playing around with the needle, I got it to run. It only wanted to run backwards, no matter what way i turned it to start it but I'm happy because I did get it to run! Thank your for the help! Phil
Anonymous
G-Money
Guest
Post  nitroairplane Sun Aug 14, 2011 12:46 pm
I am lad you got it to run.
On the carb,venturi and throttle convo I pit an scalar throttle on a tee dee .020 an it's great
Here is the video
https://www.youtube.com/watch?nomobile=1&v=u_Jh8FT6yeM
nitroairplane
nitroairplane
Post  GermanBeez Sun Aug 14, 2011 1:17 pm
ok, so i don't get looked at the wrong way again, i'm now going to referr to carburetors/restrictors/whatever you want to call it
as FAMT (Fuel/Air mixing thingy). so now i can't possibly offend anyone (unless someone has a family member named famt Very Happy Very Happy Very Happy )
GermanBeez
GermanBeez
Post  gcb Sun Aug 14, 2011 5:00 pm
A big thumbs up for the FAMT! That 'bout covers it.
gcb
gcb
Post  nitroairplane Sun Aug 14, 2011 5:23 pm
I think I try and make a FAMT for the tee dee .010
nitroairplane
nitroairplane
Post  RknRusty Sun Aug 14, 2011 6:08 pm
Thingy is inaccurate.starting a sure start - Page 2 SmashfreakB It's supposed to be called a thingamajig.starting a sure start - Page 2 Icon10
Our first forum fight, wasn't that cute. And I started it. Sorry about that. And I agree, it is a carb, of course, I just nit-picked specifics and commonly accepted esoterica.
Good work, G-Money. Don't run it backwards on the test block too long. It might overheat without air blowing over it. You can get one of those one way spring starters that will kick it off the right way every time. Purists don't approve because it causes a slight bit of drag on the RPM. Makes things easy though.
Post  nitroairplane Sun Aug 14, 2011 6:41 pm
Ditto
nitroairplane
nitroairplane
Post  G-Money Sun Aug 14, 2011 7:47 pm
I put the spring starter back on it and I got it to run the correct way. I don't know much about engines so I can't comment on your carb fight. Thank you! Phil
Anonymous
G-Money
Guest
Post  nitroairplane Mon Aug 15, 2011 4:04 am
What prop where you running?
nitroairplane
nitroairplane
Post  GermanBeez Mon Aug 15, 2011 4:43 am
RknRusty wrote:Thingy is inaccurate.starting a sure start - Page 2 SmashfreakB It's supposed to be called a thingamajig.starting a sure start - Page 2 Icon10
oh come on, that wasn't a real fight, that was a mere active discussion Wink
GermanBeez
GermanBeez
Post  nitroairplane Mon Aug 15, 2011 6:07 am
It was a mere debate Smile
nitroairplane
nitroairplane
Post  gcb Mon Aug 15, 2011 8:07 am
G-Money wrote:I put the spring starter back on it and I got it to run the correct way. I don't know much about engines so I can't comment on your carb fight. Thank you! Phil
Phil,
I don't believe that anyone was fighting. We learn most of this stuff from folks around us, even incorrect slang. Some of us are so ancient we remember when a throttle was a two speed device consisting of a two needle valve setup to provide a rich low speed, a baffle with a hole in it that covered the intake also for a rich setting, or a device over the exhaust for back pressure to provide low speeds...very primative by today's standards, but quite innovative for the day.
One word of caution, you mentioned earlier that you were removing the glow plug to prime the engine. By doing so you are "work hardening" the copper gasket (or shim) between the glow head and the cylinder. Eventually it will not seal correctly. Some guys even replace the shim every time they remove the glow head. I'm not that picky, but I keep head removal to a minimum.
There are two types of spring starters...the type that engages a plastic piece behind the prop (like you have) and an older type that you physically had to move to engage the prop. If the spring bouncing against the plastic bothers you, you can either remove it or replace it with the older type.
Good luck with your Sure Start.
Edit: Forgot to mention...many years ago (~1955) it was common practice to prime a 1/2A engine with an eye dropper, so you might consider that as a PLAN B. Cool
gcb
gcb
