cleaning up a old glowhead
Re: cleaning up a old glowhead
Looks good. Another way is to spray with eagle 1 etching formulaa mag wheel cleaner,,let it set for a few minutes,,then rinse with water, buff by hand with your method or just a terry cloth.
Looks great! I have a friend who said he cleans up his heads and other engine parts with a Scotch Brite green scrubby.
I was just talking to him and he said he got sick after cleaning a huge amount of aluminum parts. He went to the doctor and said it was from breathing aluminum oxide powder probably created when cleaning the parts and not wearing a approved mask.
A "scrubby" highly abrasive and destructive to soft surfaces like aluminum, plastic etc.
A better cleaning element would be a solvent that would soften "crud" allowing to be wiped or brushed away without damaging the surface.
SuperDave- Rest In Peace
Admin wrote:Looks great! I have a friend who said he cleans up his heads and other engine parts with a Scotch Brite green scrubby.
Good point. Don't know about the rest of you guys, but I can get caught up in the work at hand and forget that a single speck of flying metal, or dust cloud launched from a tool can really mess up your day. Keep a pair of good, clear safety glasses handy, along with a stack of paint masks....stored in a zip-lock bag. They're all relatively cheap, but still won't help if you don't use them.
The little nylon or steel bristles off of a dremel wire type wheel can make the eye water, if one dislodges at high speed and bounces off of the eyeball, not to mention poking out a eye. Even if your eyes are out of the plane of the spinning tool, it can still happen.
I had a dremel carbide grinding bit shatter once and pepper me with shrapnel. The really thin brown cutoff wheels are notorious for that, so much that I stopped using them.
SuperDave wrote:A "scrubby" highly abrasive and destructive to soft surfaces like aluminum, plastic etc.
Well, he is one that doesn't care about the actual cosmetic condition of the engine parts. I have only tried the green scrubby on a few glow heads myself and absolutely nothing else. The glow heads were just average 1990s-2000s heads that just needed a quick cleanup. Although they really don't look bad after a quick cleaning, you can see it looks slightly rounded on the edges.
PV Pilot wrote:...... The really thin brown cutoff wheels are notorious for that, so much that I stopped using them.
I really like the cutoff wheels and use them for any number of jobs.
However, you're absolutely correct --- apply any side load and they will break into multiple pieces. When using them, I practice the same rule that I do with running propellors: Stay out of the failure zone!! If the wheel breaks up or a prop throws a blade, I don't want to be in the trajectory.
I carefully use fine sandpaper to remove the aluminum oxidation as it does a nice job of recreating the machined finish and does not round edges, use the Dremel nylon brush for final touch-ups and remember to used a small screwdriver to straighten any bent fins prior to cleaning. The tape on the wrench reduces the chance of marring the glowhead
Wow, didn't know this one! It works great, I applied this treatment to a Car engine on both the glow head and the flywheel, and it looks just like new!
nitroairplane wrote:Thanks Mark just in time for my space hopper.
Oh? So your mystery engine did turn out to be a Space Hopper then?
@all
to clean my airsoft/engines/motorized bike (2stroke), i simply use this stuff:
http://www.chemicalguys.com/Extreme_Orange_AllPurpose_Cleaner_Degreasers_p/cld_106.htm
SS
shell shock- Gold Member
PV Pilot wrote:The little nylon or steel bristles off of a dremel wire type wheel can make the eye water, if one dislodges at high speed and bounces off of the eyeball, not to mention poking out a eye. Even if your eyes are out of the plane of the spinning tool, it can still happen.
Mine shatter a lot i think its just because they are old i only have 2 left.
nitroairplane wrote:PV Pilot wrote:The little nylon or steel bristles off of a dremel wire type wheel can make the eye water, if one dislodges at high speed and bounces off of the eyeball, not to mention poking out a eye. Even if your eyes are out of the plane of the spinning tool, it can still happen.
Black and Decker have a .025 cutoff wheel which is supposedly a bit more durable than the brown Dremel .025 brown wheels. The brown Dremel emery wheels CANNOT be sideloaded at all,,not a bit,, or they fly apart. They have always been that way for years,,just to delicate for anything but very small diameter wire or the like and a very steady hand. One thing that does help is to shape them down to about 1/2 size with the Dremel dressing stone, then they are slightly more durable.
http://www.dremel.com/en-au/Accessories/Pages/ProductDetail.aspx?pid=415
Mark, can you show also in images how you clean up the cylinder and the crankcase? I imagine it's a little more trickier to clean those up without damaging them...
Thanks, Manu
Thanks, Manu
PV Pilot wrote:nitroairplane wrote:PV Pilot wrote:The little nylon or steel bristles off of a dremel wire type wheel can make the eye water, if one dislodges at high speed and bounces off of the eyeball, not to mention poking out a eye. Even if your eyes are out of the plane of the spinning tool, it can still happen.
Thanks for that PV i'll be sure to check those out.
