Lightening a piston using common tools
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Lightening a piston using common tools
It's still available $12.95
I don't think any cox piston will stand 28k.
When I mistakenly ran mine on 60% with the standard prop bolt
it was spinning at 22+ on the ground..... When the inevitable happened,
ie the front of the crank/prop bolt sheared and the prop left the plane
behind in the air the engine briefly (a second perhaps) went into hyper
speed, there wasn't much left of that piston once the con rod went
through the crown. If memory serves it was an unlightened TD piston.
John Goddard- Diamond Member
He has 297 of them according to the quantity dropdown list. If that's his SKU49cyspi product.getback wrote:
WOW I am sure that cant be gotten anymore, never seed that before.
I'd like to compare the performance of one of those on a Tee Dee against his Old style SPI Tee Dee P/C with the full size piston. I wonder if the heavier piston achieves more torque due to inertia, meaning less slowing in high gee maneuvers.
I have a crankchaft that broke while fling because of a bolt too short to fix the propeller With an rc plane I landed but the engine is running full blast I remember the amazing crazy sound Me the internal components of my engine survived except the crank We can see the mark left by the rotation of the conecting rod on the tank valve Area no valve damage I use this part even if it is damaged on out side its a black widow fuel tank one wit circlip
davidll1984- Diamond Member
davidll1984 wrote:I have a crankchaft that broke while fling because of a bolt too short to fix the propeller With an rc plane I landed but the engine is running full blast I remember the amazing crazy sound Me the internal components of my engine survived except the crank We can see the mark left by the rotation of the conecting rod on the tank valve Area no valve damage I use this part even if it is damaged on out side its a black widow fuel tank one wit circlip
Yeah, that's what we call a "shaft run". Hearing the little things run at their extreme limit with no load is a scary thing. I had a Gilbert do it. Never heard one of those go anywhere near that fast before, and it survived.
Had the same experience with a TeeDee020 that threw off a 3 bladed drone prop that had its hub split..obviously IC engines generate repetitive dynamic load peaks that props designed for smoothly running electric motors will not endure for long.
The poor thing whined at a very high pitch before I reached to the forced landing site of the RC plane with no prop, but it survived the unloaded- and uncooled- run without any notable damage and continues its service in the nose of my Roaring 20 balsa RC plane..
most of the time when this happens the crankshaft goes back into the crankcase But a perfectly tuned engine can survive By survive I mean piston cylinder crankcase.The outer part of the valve should retain the motor connecting rod on the crankshaft pin Results the connecting rod can continue to rotate freely in the path inside the crankcase I used to do this modification with several of my bee engines Often I find the spec too much space between the outside of the valve and the crank pin To check remove the cylinder press the connecting rod check that the connecting rod fits well on the perimeter of the valve and can turn freely without catching Outside the path inside the crankcase The seat of the path retaining clip valve will eventually be too worn out will interfere with the connecting rod The plastic model wears out quickly but remains a good option can be changed more often to prevent a sudden damage
Page 2 of 2 • 1, 2
» 049 piston lightening
» shortening and lightening a piston
» Cox 09 and 15 piston reset tool.
Page 2 of 2
