CA cement: Is it REALLY fuel-proof...........................
and how do you know?
Thanks for you responses.
SuperDave- Rest In Peace
Re: CA cement: Is it REALLY fuel-proof...........................
Well i sue it and i run 25% nitro and never had a model fall apart.
nitroairplane wrote:Well i sue it and i run 25% nitro and never had a model fall apart.
How about softening so as to weaken or distort the airframe?
SuperDave wrote:nitroairplane wrote:Well i sue it and i run 25% nitro and never had a model fall apart.
Well when exposed to actual fuel for a long period of time it f=goes white and semi sticky (like whet hard candy)
But it is fine with fuel vapours and castor oil.
what thickness would you use?
nitroairplane wrote:SuperDave wrote:nitroairplane wrote:Well i sue it and i run 25% nitro and never had a model fall apart.
Well when exposed to actual fuel for a long period of time it goes white and semi sticky (like whet hard candy)
Most often CA+ medium.
I have one of my old stunters built with Ambroid in 1962 and it may still be safety flown to this day although it would require re-covering to do so. The papering has badly deteriorated but the airframe is still solid..
If I ever get so motivated I would strip it away and replace it with modern synthetic covering.
BTW, it's a Kenhi "Cougar" with Veco .35 power and never crashed
SuperDave wrote:Most often CA+ medium.
You should be good what do you usually use?
It's my understanding that nitromethane is the active ingredient in CA debonder. That said, I've never seen or heard of glue joints failing due to fuel soakage in actual use.
tubebass- Silver Member
Nitromethane is listed as the primary base in many CA solvent/debonders and is capable of dissolving cured CA.
See the following link: http://www.ca-plus.com/ca_acc_dec.html
MSDS Sheet for another commercial debonder: http://www.tedpella.com/msds_html/19920msds.htm
Third commercial debonder (at bottom of page): http://www.resinlab.com/adhesive/cyanoacrylate.html
The question becomes whether it is effective in the concentrations we use. However, prolonged or continuous exposure to > 25% nitro fuels may have a tendency to weaken joints over time.
andrew wrote:Nitromethane is listed as the primary base in many CA solvent/debonders and is capable of dissolving cured CA.
It's good for me and I run 20-35% nitro.
But just keep a rag handy to wipe it as soon as you land it.
In most applications there is some kind of finish or covering between the CA and the high nitro fuel.
Are you planning an application where CA will be diretly exposed to fuel? If so, I would strongly suggest you switch to another adhesive, such as epoxy, for that application.
Although there are other debonders, mine is nitromethane. Fuel has never penetrated my planes and caused debonding...so far.
gcb- Platinum Member
Nitromethane is quite volatile (in an evaporative sense), so spilled fuel is probably going to be the biggest culprit. A quick wipe should help keep most of the solvent off. The residue after flying is oil -- which can contribute its own damage.
I like to use epoxy where ever there is likely to be direct contact with either fuel or oil residue and always apply a thin coating of epoxy to the firewall and surrounding joints.
However, I've found dirt to be the quickest and most effective debonder; I've had several planes debond completely when they hit the ground.
andrew wrote:...However, I've found dirt to be the quickest and most effective debonder; I've had several planes debond completely when they hit the ground.
AMEN!
I think just about all nitro kit plans reccommend a CA during assembly, so it stand to reason that it is fuel proof, to an extent. Sig and all the rest are hanging it out on the line to reccommend that type of glue/cement. Of course they also reccommend a dope fuel proof or iron-on to make the model last, but I am sure that they are certain that the CA that is used during assembly will encounter nitro fuel at one point in time.
High percentage nitro will soften and dissolve it over time.
CA mediums here also.
Regular gasoline is a excellent CA debonder.
Wherever direct exposure to nitro is a concern I prefer to use "Sig-ment" rather than CA adhesive. "Sig-ment" sells for a little less than $7/ 4 oz. tube. Four ounces goes a long way and is much easier to remove from hands/clothes than CA.
SuperDave wrote:Wherever direct exposure to nitro is a concern I prefer to use "Sig-ment" rather than CA adhesive. "Sig-ment" sells for a little less than $7/ 4 oz. tube. Four ounces goes a long way and is much easier to remove from hands/clothes than CA.
I like CA because it is so quick for those little misshaps at the field you can be up and flying again in less than 5mins.
» Varnish Fuel Proof?
» What is the most oil and nitro resistant covering?
» fuel proof paint, with lead in it
» S.A.D Open for Membership
» Building tip: CA cement and eye irritation
