PEE WEE help? Cox_ba12
PEE WEE help? Pixel
PEE WEE help? Empty
PEE WEE help?
PEE WEE help? Empty PEE WEE help?
Post  shell shock Tue Oct 11, 2011 7:31 am
hey guys. just wondering, i just won an auction for a .020 pee wee, 2 extra glow heads and a wrench. i payed 20$! is there anything (besides cleaning) that i should do? anything i should replace? thanks guys! i dont want to ruin this classic engine.
thanks in advance
SS Futaba Radio
http://www.ebay.ca/itm/290616635587?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
shell shock
shell shock
PEE WEE help? Empty Re: PEE WEE help?
Post  Kim Tue Oct 11, 2011 7:47 am
If you're going to use it as a "daily runner", you might try just bolting it to a stand, fueling it up, and seeing if it will run. It may have a little old fuel inside that will take a bit of time to run through, or it may just take off like a little hornet!
Assuming good fuel and glow, the reed and gaskets are the first choice to help an old engine run, but I don't like to take them apart unless there's an actual need, and there's a chance that you may have a "runner" right out of the package.
These little guys are more robust than they're often credited, and you won't hurt it just trying to get it to run. DO be sure and get a good quality, properly fitting screwdriver for the backplate screws if you do disassemble it...I've bought several with gouged-out backplate holes.
You can heat it up with a hairdryer to get the gaskets loose, scrubbing them with a toothbrush and model fuel to clean the mating surfaces.
Post  shell shock Tue Oct 11, 2011 7:51 am
You know.. I never considered that XP as foolish as it sounds. Im really happy with my purchase if anything, the guy seemed to know exactly what he was selling. it even has one of the 3rd party 1/4 inch glow plug adapters! next up to buy is a testing stand and mounting bolts. im tired of the board i have my .049 bolted to (quite frankly is scares the... well you know).
SS
shell shock
shell shock
Post  SuperDave Tue Oct 11, 2011 8:26 am
SS:
Since a .020 in no "powerhouse" a test stand may be easy made from something as basic as a 2"X4" with properly fitting screws to attach the engine's four radial mounting lugs.
Try running the engine "as is" and, based on it's performance, make any needed repairs.
"If it ain't broke don't fix it" was never more appropriate in this situation.
SuperDave
SuperDave
Post  shell shock Tue Oct 11, 2011 8:29 am
ha ah, usually go by "if it aint broke, fix it till it is" (i joke) does the .020 use the same mounting bolts as the .049?
shell shock
shell shock
Post  Kim Tue Oct 11, 2011 8:32 am
Nope, they're different, smaller size, but will still take a #2 wood screw.. mocrofasteners has socket head screws that are great for saving you from putting "tool marks" on the tank.
Post  shell shock Tue Oct 11, 2011 8:35 am
shoulda seen that one XP smaller engine, smaller screws. thanks all
SS
shell shock
shell shock
Post  SuperDave Tue Oct 11, 2011 8:42 am
If used, the engine MAY have enlarged mounting lugs to accomodate more common screw sizes. Better check and see before you buy screws. DON"T ream out the holes to a larger size than you have!
IIRC, size #52 is standard for the .020.
SuperDave
SuperDave
Post  SuperDave Tue Oct 11, 2011 8:59 am
shell shock wrote:ha ah, usually go by "if it aint broke, fix it till it is" (i joke)
U R a masochist then. U must enjoy self-abuse. lol!
Yeah self abuse looks to both sides nervously Smile
SuperDave
SuperDave
Post  Cz10 Tue Oct 11, 2011 9:07 am
#52 is the standard WHAT size? Drill size for the holes in the back plate?
I have read that it may not run well with that glow head adapter. The volume of the combustion chamber is larger because of the area around threads of the glow plug not sealing until the copper ring at the top of the head.
Without the starter spring it will be a crap shoot which direction it is running when it starts. They are just as happy running backwards as forward.
Cz10
Cz10
Post  SuperDave Tue Oct 11, 2011 9:18 am
Quite charactertic of "reedy" Coxes generally. One should always check prop rational direction before launching.
Embrassing things have been know to happen. Don't ask me ghow I know. Embarassed
SuperDave
SuperDave
Post  GermanBeez Tue Oct 11, 2011 9:53 am
If it runs in the wrong direction, have a towel ready that you can throw onto the prop.
that will cause it to stop immediately
GermanBeez
GermanBeez
Post  andrew Tue Oct 11, 2011 10:08 am
That is the most commonly assumed reason for lower performance with the adapter heads, but (swimming uphill here) I think the cause lies elsewhere.
If the plug and adapter threads were coated with a heavy oil, such as castor, before inserting the plug, any volume loss would be filled with a non-compressible liquid right to the bottom of the plug eliminating a change in compression ratio.
I believe performance loss can be tied to three factors not associated with the glowplug seal. First, the filament hole size in a standard plug has a higher volume than the COX heads. Secondly, unless the adapter is machined to allow the bottom of the plug to lie perfectly flush with the bottom of the head, cylinder displacement can be increased if the plug does not completely reach the bottom of the adapter. Certainly, the converse would hold if the plug extended into the chamber. Thirdly, COX heads have a smooth dome or trumpet shaped chamber. The adapter heads have the surface broken by the bottom of the standard plug. Flame propagation rate is impacted by both the shape and surface roughness of the head. When all factors are considered, the impact may be only 2%, but in a 14K engine, you're looking at 280 rpm.
With a PeeWee having such a tiny displacement, any volume or shape change turns into a major factor.
Just my thoughts.
Post  nitroairplane Tue Oct 11, 2011 10:33 am
And one of those extra glow heads is for a .010 engine.
nitroairplane
nitroairplane
Post  SuperDave Tue Oct 11, 2011 10:44 am
I run an adapter head with specialized glo on my throttled Surestart/Lil swamp Buggy combo. The plug fits into the head exactly as it should and the engine runs/performs to my satisfaction.
The purpose of the head/glo combo is to reduce engine RPM at idle. The throttle allows me to "kill" the engine with the Tx anytime I desire.
Sweet set up!
SuperDave
SuperDave
Post  nitroairplane Tue Oct 11, 2011 10:46 am
SuperDave wrote:I run an adapter head with specialized glo on my throttled Surestart/Lil swamp Buggy combo. The plug fits into the head exactly as it should and the engine runs/performs to my satisfaction.
Sweet set up!
And it also means spare glow plugs are only about 3.95
nitroairplane
nitroairplane
Post  SuperDave Tue Oct 11, 2011 11:03 am
Nitro:
And even free! When I first received the glo/head combo from Bernie the threads didn't match up. I explained this to Bernie and he sent me a replacement plug gratis and told me to keep the misthreaded plug.
I eventually ran a die over the threads to clean them. I now have TWO properly fitting glos for the same head.
What would we EVER do with conscienious vendors? Thanks again, Bernie.
SuperDave
SuperDave
Post  nitroairplane Tue Oct 11, 2011 11:09 am
SuperDave wrote:Nitro:
And even free! When I first received the glo/head combo from Beriie the threads didn't match up. I explained this to Bernie and he sent me a replacement plug gratis and told me to keep the mistreaded plug.
What would we EVER do with conscienious vendors? Thaks again, Bernie.
I know right these guys really keep the hobby alive.
Thanks fellas.
nitroairplane
nitroairplane
Post  shell shock Tue Oct 11, 2011 12:50 pm
@nitroairplane:
That would explain the smaller size XP
@Cz10:
I have read that too. I just think its a cool add on
@GermanBeez
Would pinching the fuel line cause damage to the engine instead of throwing a towel on it? also, no damage can come from running the engine backwards is there?
Also, i have a .020 spring and a few other things en rout
shell shock
shell shock
Post  microflitedude Tue Oct 11, 2011 12:53 pm
shell shock wrote:@nitroairplane:
@Cz10:
@GermanBeez
No, pinching is fine. I've found it stops the motor almost instantly. Unless you have a brass drive plate, running the engine so that it's pushing air will wear out the drive plate.
microflitedude
microflitedude
Post  shell shock Tue Oct 11, 2011 12:55 pm
Now i know
And knowing is half the battle!
shell shock
shell shock
Post  microflitedude Tue Oct 11, 2011 1:12 pm
Of course there is no fuel line to pinch on the PeeWee. Very Happy
Yes there is a small fuel line, you can't pinch it.
microflitedude
microflitedude
Post  shell shock Tue Oct 11, 2011 1:32 pm
>.< is true.
shell shock
shell shock
Post  SuperDave Tue Oct 11, 2011 1:47 pm
If anyone is interested a have OEM .049 snap starter for CCW rotation. It was mistakenly purchased by a friend and then passed on to me.
Their most common application is in twin-engine planes where two engine running in the same direction creates torque problems.
SuperDave
SuperDave
Post  nitroairplane Tue Oct 11, 2011 1:50 pm
microflitedude wrote:Of course there is no fuel line to pinch on the PeeWee. Very Happy
An easy way ive found to stop an engine is to pinch the spinner but cannot reccomend this because you could get cut of undo the prop screw.
so when doing things like this you require a bit of common sense as to when to stop,try ETC.
nitroairplane
nitroairplane
