Scrouging mysteries Cox_ba12
Scrouging mysteries Pixel
by TD ABUSER Today at 2:30 am
Scrouging mysteries Empty
Scrouging mysteries
Scrouging mysteries Empty Scrouging mysteries
Post  SuperDave Thu Sep 15, 2011 11:00 am
I've come up with two parts for Coxes:
- a Kardan (German) tank extender for a BW
- a white nylon cylindrical tank tank that apprently fits onto some sort of backplate
Need any information on your experiences with them, pleez.
SD
SuperDave
SuperDave
Scrouging mysteries Empty Re: Scrouging mysteries
Post  GermanBeez Thu Sep 15, 2011 11:06 am
hmmmm, i think i know that cylindrical tank.
is it this one?
http://www.exmodelengines.com/product.php?productid=17732&cat=262&page=1
i know the company kavan. they make all sorts of stuff for model airplanes and boats.
GermanBeez
GermanBeez
Post  SuperDave Thu Sep 15, 2011 11:19 am
beez:
Yes that's the cylindical nylon tank. I am undertain of the engine application or how it attaches however. Ideas?
The Kardan BW tank extender is self-explantory. I'd like to know if they are any good in actual useage: do they leak or cause other problems? Being in Germany, you may have has some experiences with them.
SD
SuperDave
SuperDave
Post  GermanBeez Thu Sep 15, 2011 11:25 am
actually, kavan is pretty high quality and rather expensive at times, so it should fit perfectly and not leak at all.
as to the nylon tank, it probably is meant to be used in hollow fuselage airplanes (do they call it that?), and you
basically just stick it in there. it "snaps" right in.
GermanBeez
GermanBeez
Post  SuperDave Thu Sep 15, 2011 11:48 am
GermanBeez wrote:actually, kavan is pretty high quality and rather expensive at times, so it should fit perfectly and not leak at all.
beez:
The Blackhawk model series feature a "hollow" fuse aka "hollow log". Seems to me a "snap in" tank would be prone to leak causing nitro saturation within the fuse.
SD
SuperDave
SuperDave
Post  nitroairplane Thu Sep 15, 2011 12:31 pm
tank extenders are known to leak a bit but i am sure they are good products.
nitroairplane
nitroairplane
Post  SuperDave Thu Sep 15, 2011 1:09 pm
nitroairplane wrote:tank extenders are known to leak a bit but i am sure they are good products.
nitro:
I have no such certainly until proven in actual useage by others) . Cool
SD
SuperDave
SuperDave
Post  EXModelEngines Thu Sep 15, 2011 1:58 pm
SuperDave wrote:beez:
SD
The white plastic tanks were used on the many of the Cox plastic RTF C/L airplanes. These include the PT-19, EZ Fyler series, and Texan...there are many more. You would have to custom fabricate a top for it to be useful outside of the OEM application.
In regards to the Kavan tank extenders, they are good, but they do leak. I would suggest that you put a bead of silicone around the tank where it matches if you are going to use it. Also, do not over-tighten the screws that Kavan provides. They are notorious for breaking since the material they are made from is not very strong.
Regards, Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  SuperDave Thu Sep 15, 2011 3:19 pm
Matt:
Yes I've considered 'coning the tank to seal it but, until I find a use for the tank, I'll defer the 'coning.
I believe there are more suitable tanks for my current applications.
Thanks for your response.
SD
SuperDave
SuperDave
Post  EXModelEngines Thu Sep 15, 2011 3:40 pm
SuperDave wrote:Matt:
SD
Yeah, it should work, but pretty much any other external tank would probably be easier.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  RknRusty Thu Sep 15, 2011 8:41 pm
Regards, Matt
I have sealed tanks with oil resistant black Permatex from the auto parts store. It will stay sealed until you find some reason to disassemble the piece. I use it between BW crankcases and the 8cc tanks which I have had leak on a couple of engines.
Post  microflitedude Thu Sep 15, 2011 9:05 pm
Regards, Matt
+1 on that, it's great stuff.
microflitedude
microflitedude
