Varnished Cylinder  Cox_ba12
Varnished Cylinder  Pixel
Varnished Cylinder  Empty
Varnished Cylinder
Varnished Cylinder  Empty Varnished Cylinder
Post  rdw777 Fri Aug 05, 2022 6:02 am
I recently won a Pee Wee .020 RC …. It was free to turn when I got it but pretty gummy from old castor …. It came apart easily and I cleaned the upper cylinder assembly with ISO alcohol then installed on a Tee Dee lower end…. Hard to start and could only get about 15K with 4.5 x 2 Cox prop…Took it apart and paid more attention and thought it may be varnished due to the dry piston/cylinder fit so I soaked it Hoppe’s #9 for about 30 min and scrubbed gently with a round nylon brush (that doesn’t fit the bore tightly)…Cleaned, reassembled, ran with about the same result…Needle adjustment seemed very narrow and acted like it was on the verge of too lean the whole time…
Maybe the photo will show the brownish tinge above the exhaust ports…
Varnished Cylinder  39169210
Piston goes in about this far before resistance is felt (dry)
Varnished Cylinder  D848ab10
Do I have it diagnosed right?…. I don’t see any evidence of a burr….. Maybe I need to soak longer?…. I have acetone as well… I can get other stuff as needed…. Opinions appreciated…
Varnished Cylinder  Empty Re: Varnished Cylinder
Post  GallopingGhostler Fri Aug 05, 2022 8:52 am
To removed baked on Castor grime, I resorted to fine steel wool. It is able to gently scrub off that, I think you'll find a different fit result when you remove the last of the Castor.
Post  balogh Fri Aug 05, 2022 9:11 am
I use cold degreaser spray - same as cleaing fry pans in the kitchen- to losen up the varnish, then a cotton swab to remove it.
If your piston is a bit tight near the TDC, that may be due to taper cylinder bore that was common with old stock thin wall and even some stepped wall cylinders. This will not compromise engine rpm rhough.
If the piston firmly sticks halfway up, then there may be a burr near the exhaust ports..though the flats on the top fin allows the safe use of a wrench, so a wrench inflicted burr in the exhaust port is not a probable cause of power loss.
What backplate do you use on this engine? Check that all mating surfaces should fit airtight, because the narrow needle valve range and lean run indicate there may be some unwanted air leakege somewhere.
Post  GallopingGhostler Fri Aug 05, 2022 11:22 am
I have VERY CAREFULLY used a small round file to remove such burrs caused by wrenching a (now old, been a while Wink ) thin wall cylinder off that didn't have wrenching flats like the later ones. If one is VEHWY VEHWY CAREFUL (saying this in an Elmer Fudd voice after a silly wabbit Laughing ), they can save the cylinder. Very Happy  Since fit is measured in tens of thousands of an inch, it is also possible to damage the cylinder beyond saving. Sad
Because of the now rarity of .020 cylinder / piston assemblies,Shh  It is almost like disarming a time bomb. Shocked  (Thinking of a Hogan's Heroes episode) Surprised  You have two wires, white and black. You clip one, the clock stops. Cool  You clip the other, you are immediately blown up. Affraid or WOW!
Nonetheless, it is not too hard to imagine that Bob @rsv1cox, Broussard Mud Dabber @Kim, and @Ken Cook, (and @Admin Jacob - the kitchen heirloom fluorescent ceiling lamp) have been down this path with tails to tell. sunny Hand Shake Beer Cheers
The thing today is, if we don't experiment with our methods to redeem a lost cause, then we serve no purpose to benefit. If we happen to ruin it, all is not lost, just another tale to tell on CEF.
lol! I Love This Forum!
Post  rdw777 Fri Aug 05, 2022 3:15 pm
Thank you Balogh, George…I’ll go the chemical route first and check the feel again… I have other Pee Wee’s and Tee Dee’s that are good runners to compare fit-feel with…
Backplate was Kamtechnik with the O-ring seal… I leveled the back of the case anyway…I did not however have a fuel line seal on the needle valve… Will add that next time..
Yes, It’s too bad they are getting more scarce… I bought a few PW and TD 020 the last year or so… I think my favorite size..
I’ll report back on how well it ran ….Or asking more help!!!!
Thanks again Very Happy
Post  GallopingGhostler Fri Aug 05, 2022 4:57 pm
I started out with the Pee Wee for R/C, it is an excellent hard working and reliable engine, may be not as prestigious as the equivalent in power .010 Tee Dee, but a little powerhouse to its own. I still have a remnant from the 1980's, an Ace R/C Littlest Stick. Was on Ace Adams Baby Twin actuator and single channel R/C, but now that I have 6 gram servos, can make it a rudder and elevator plane.
Varnished Cylinder  Ace_rc10
I drilled a hole in the tank and plumbed it to a larger capacity Perfect tank. All is not lost, if need be, I could restore the tank with a non-anodized production engine tank from my parts engine.
Varnished Cylinder  Ace_rc11
I recently renewed my MADS R/C club membership, hope this Fall to do some flying.Very Happy  (Don't mind the obsolete and now unsafe Top Flite 5.25x3 white nylon prop, I will replace with a good prop prior to flights.) Smile
Post  rsv1cox Fri Aug 05, 2022 5:39 pm
GallopingGhostler wrote:I have VERY CAREFULLY used a small round file to remove such burrs caused by wrenching a (now old, been a while Wink ) thin wall cylinder off that didn't have wrenching flats like the later ones. If one is VEHWY VEHWY CAREFUL (saying this in an Elmer Fudd voice after a silly wabbit Laughing ), they can save the cylinder. Very Happy  Since fit is measured in tens of thousands of an inch, it is also possible to damage the cylinder beyond saving. Sad
Yes, I have shelved all other cleaning methods.  Berryman's is now my go-to forsaking alcohol, crock pot, Simple Green, and all other crazy cleaning methods that I have ever tried.  I'm talking over 500 model engines cleaned and restored.
The latest, and one I reported here was this very early Babe Bee.  It had a severe varnish drag when I got it.  Surprised me as the exteror was quite clean.  But as we all know, it's what inside that counts.  A 30 minute Berryman's soak followed by a soapy warm water rinse, followed again by a clear water rinse, a compressed air blow-out and Remoil.  No effort at all was made to wipe the inside of the bore.  Nada.  Reassembled and perfect function was restored.
I really have no idea as to why anyone would use anything else.
Varnished Cylinder  P1013744
Varnished Cylinder  P1013743
Varnished Cylinder  P1013742
The fuel pick-up tube gives some indication of how gummed up the interior of this engine was. It was black when I started and full of goo as was the NVA.
The bore is the thing, the more you fool with it the worse it gets.
Post  rdw777 Fri Aug 05, 2022 5:59 pm
Thanks Bob, I’m just moving slow and cautious to minimize risk of injury to the cylinder…. Really looking forward to see if I can make it throttle …. Course then I have to build something for it Small Cox Logo Small Cox Logo
Love the Littlest Stick George… I have a survivor from the 80’s as well…. Started life with a Pee Wee and one Ace servo…I never really got that good at rudder only back then…It’s on its second set of electronics and motors as three channel now…Totally rebuilt a couple of years ago… It got a new rudder and stab at that time..I know we have talked about small planes flying in the wind from time to time… This is my go to for that…Pretty stable for a small, light plane….Hope you get some good flying in this fall…Varnished Cylinder  D97dec10
Varnished Cylinder  60c32910
Post  rsv1cox Fri Aug 05, 2022 6:12 pm
rdw777 wrote:Thanks Bob, I’m just moving slow and cautious to minimize risk of injury to the cylinder…. Really looking forward to see if I can make it throttle …. Course then I have to build something for it Small Cox Logo Small Cox Logo
I probably shouldn't be so forcefully opinionated about this, but seriously "500 engines" is an understatement closer to 600 engines would be more accuraate and I have learned from my mistakes. I posted many of my "worst of the worst" engines here, until it got old. But I never stopped. These two beauties should be here this weekend. Yup, Berryman's.
Varnished Cylinder  Wm_thr10
Varnished Cylinder  Wen_ma18
Think they might be varnished up.
Post  rdw777 Fri Aug 05, 2022 6:31 pm
That Bee did shine up really well….I’m enjoying to learn these new tricks of the trade…Throws a little spice back into the hobby Very Happy
Post  GallopingGhostler Fri Aug 05, 2022 8:41 pm
rsv1cox wrote:I really have no idea as to why anyone would use anything else.
Familiarity with methods at the time, familiarity, Bob. Reason why I use fine steel wool is because that was the method described in the Cox engine instructions, IMO. Following is stated in the Cox Pee Wee instructions that came with the engine. Apparently these are the more recent instructions, as it includes the Pee Wee R/C with exhaust throttle ring.
Cox .020 Pee Wee Instructions wrote:Varnish - If the engine gets tight it is not frozen up. Do not send to factory. A new engine will sometimes tighten up a few times, especially after slow runs. Certain kinds of weather, especially warm, humid (sticky) weather will cause excessive shellacking in a new cylinder. The smoother the fit the more susceptible is the engine to this trouble. Do not run it tight. The tightness is caused by a shellac-like deposit on the cylinder wall. Screw the head off. Remove the cylinder and scour the inside wall very lightly with a bit of fine or medium steel wool. Wash, oil, and replace. The engine will then turn over freely and run properly. Never use sandpaper, emery cloth, or abrasives of any kind, or scrapers. Such methods will ruin the cylinder. Steel wool, will not harm the bore.
This is why for right, wrong, or indifferent tongue I have always used steel wool on all my Cox engines, to devarnish the cylinder bore. So far, I have not encountered any problems with the methodology. And, I have further used it on other steel bore engines as well.
However, I do listen to the alternative methods, nothing is cast in stone. Your method of using Berryman, which I am familiar in using on car and motorcycle carburetors and small parts, has caught my attention. They changed the formulation, didn't know how well the newer stuff works.
rdw777 wrote:TLove the Littlest Stick George… I have a survivor from the 80’s as well…. Started life with a Pee Wee and one Ace servo…I never really got that good at rudder only back then…It’s on its second set of electronics and motors as three channel now…Totally rebuilt a couple of years ago… It got a new rudder and stab at that time..I know we have talked about small planes flying in the wind from time to time… This is my go to for that…Pretty stable for a small, light plane….Hope you get some good flying in this fall…
Thanks, sharp looking Littlest Stick, Robert, and good conversion to electric. I started out on R/O and got to where I could dead stick within 10 feet of me consistently, plus learned how to kick the rudder, so I could get the plane to flair for landing. True R/O flight is a real blast of fun.
Post  rsv1cox Sat Aug 06, 2022 7:03 am
medium steel wool. ?  I hesitate to use fine steel wool or any abrasive inside the bore except in extreme cases where rust/corrison is evident.  At that point your not going to lose much anyway.  There are those (here on the forum) that would argue that varnish is necessary and should not be removed.  There is reason on some bores that may be true.
The bottom line is that whatever works for you is best for you, and I would not change that.
Post  GallopingGhostler Sat Aug 06, 2022 8:14 am
rsv1cox wrote:medium steel wool. ?  I hesitate to use fine steel wool or any abrasive inside the bore except in extreme cases where rust/corrosion is evident.  At that point your not going to lose much anyway.
OEM instructions stated to go "lightly". For me, it only took a couple swipes. I suppose if one can't chew gum and walk, then may be they shouldn't. Very Happy  However, if you really think about it, when those instructions were published, they didn't have all the miracle chemicals of today and modellers didn't have the patience to do a "proper" and complete tear down. Steel wool was abundantly available and its methodology worked as long as you didn't abuse it. Surprised
rsv1cox wrote:There are those (here on the forum) that would argue that varnish is necessary and should not be removed.  There is reason on some bores that may be true.
On the older engines that lost compression due to wear and tear, the Castor acted as a seal. Think of it as the J.C. Whitney "Engine Overhaul in a Can" of the 1960's and 1970's, with the wax pellets you put a handful in each cylinder through the spark plug hole and poured their pint of "Liquid Plate" oil additive into the engine oil. It was guaranteed 10,000 miles of smoke free oil less burning mileage with restored compression. Laughing
Ken showed a photo of a Fox .35 stunt that was totally engrossed in Castor stating that this is how a Fox should look. Shocked  It was humorous, I'd never seen such a grossly greasy thing in my life before. Doh!  Was searching for a photo of that on both CEF and Stunt Hangar without luck. Sad
The larger slag iron piston on steel cylinder engines that were badly worn out, they still ran fine if one didn't dink with the baked on Castor coating. That was mostly on control line aircraft. Removing such an engine off a favored aircraft was like:
Varnished Cylinder  Peanut10
Peanuts cartoon by late Charles Shultz
If it works, don't fix it seemed to be the motto of the day. lol!
However, I have an Enya .15-III TV with very weak compression. A shot of heavy oil to temporarily restore compression, once fired up, seemed to run well regardless. It would benefit from all Castor fuel. Very Happy However, I have enough of these .15's that it sits as a parts engine. Laughing
Post  getback Sat Aug 06, 2022 8:51 am
I use oil and a pistol nylon barrel brush for the cyl. I can find it now but there was a discussion about if a Pee Wee and TD share the same piston / cyl. . Do They ? Very Happy
Post  GallopingGhostler Sat Aug 06, 2022 10:34 am
getback [Inquisitive Eric] wrote:I can['t] find it now but there was a discussion about if a Pee Wee and TD share the same piston / cyl. . Do They ? Very Happy
ANSWER: https://www.coxengineforum.com/t11396-cox-020-pee-wee-tee-dee-question#145027
Jason_WI on Dec 09, 2017 wrote:Cylinders are all the same for the .020. The only difference is thin walled, stepped wall, thick walled, mesh, and slotted screen. Nothing affected the ports on these variants. Early .020 TD pistons were tapered. This was phased out in '72.
I looked at the engine articles on Sceptre Flight. Peter Chinn gave the exact same description of both the Pee Wee and the Tee Dee cylinders.
Hijacked
The .020 Tee Dee is a more powerful engine due to its freer flowing inlet fuel charge design and timing differences. Its power rated at 0.055 BHP at 23,000 RPM on 30% nitro according to the graphs approaches that of a Babe Bee. (H.R. Warring's earlier 1962 test used 20% nitro and as such, obtained lower power of 0.0304 BHP at 20,500 RPM. The Tee Dee is most happy on higher nitro fuels.) In comparison, Peter in his 1976 test rated the Pee Wee at 0.035 BHP at 18,500 RPM on 25% nitro fuel.
With dual intake bypass ports, the Pee Wee is more like a miniature Black Widow, Very Happy which may explain for its amazing power output in the latter 1950's when it debuted, in some cases exceeding the power of a few earlier .049's. Cool Both are amazing engines. Perhaps that is why they remain popular even today.
Back To Topic I Love This Forum! Stereo
Post  rdw777 Wed Aug 10, 2022 11:39 am
Got it going… Kitchen degreaser (Formula 409) got all the brown goo …. Put it back in its native PeeWee block and tried again…. Still wasn’t there so apart again…. I think I knocked a small burr out of the way when I inserted the piston skirt first and gently pushed up the bore…. After that a dry piston would drop to the top of the cylinder and stop right at the landing for the head …. Runs and throttles good now…. Thanks for the advices!!!!
Robert
Varnished Cylinder  2501c910
