What is the distiction between......................... Cox_ba12
What is the distiction between......................... Pixel
by TD ABUSER Today at 9:30
by batjac Today at 5:05
by gkamysz Today at 4:29
by roddie Today at 4:22
by GallopingGhostler Yesterday at 22:04
by 1/2A Nut Yesterday at 21:43
by roddie Yesterday at 20:13
by sosam117 Yesterday at 18:32
by rdw777 Yesterday at 16:24
by rsv1cox Wed 20 Nov 2024 - 22:21
by 1975 control line guy Wed 20 Nov 2024 - 15:17
by rsv1cox Wed 20 Nov 2024 - 1:35
What is the distiction between......................... Empty
What is the distiction between......................... Empty What is the distiction between.........................
Post  SuperDave Sat 27 Aug 2011 - 16:05
..........pre-'96 "Black Widows" and later? I have five of them that I know fall into that category because I either bought them myself or they were given me prior to '96. From discussion here I gather that the early model BW's are more desireable. Why?
To us "old timers" '96 wasn't all that long ago (or was it)? I don't remember. lol!
SuperDave
SuperDave
SuperDave
What is the distiction between......................... Empty Re: What is the distiction between.........................
Post  nitroairplane Sat 27 Aug 2011 - 16:12
post '96 black widows had a plastic backplate.
i think they also had a different cylinder but i am not 100% sure about the cylinders.
nitroairplane
nitroairplane
Post  Admin Sat 27 Aug 2011 - 17:35
(rare) 1973 engines have...
  • silver stunt tank
  • silver narrow crankcase
  • metal backplate
  • red driveplate
  • thin walled cylinder
  • high compression 1702 TD head
  • came with silver spinner
The pre 1996 engines have...
  • black or silver aluminum stunt tank
  • plastic (post '90) or metal backplate
  • black crankcase
  • hex drive snap starter or round (zero drag) with snap start cam or zero drag
  • #1 or slit cylinder (early 80s)
  • standard 325 head
  • early engines came with red rubber spinner, mid-later came mostly with red aluminum spinner with the silver spinners every so often
Post 1996 engines have...
  • black plastic 8cc (non stunt) tank
  • black plastic (non stunt) backplate
  • silver crankcase
  • #1 cylinder
  • standard 325 head
  • came with a silver spinner
Post  EXModelEngines Sat 27 Aug 2011 - 17:42
It is hard to be able to tell with the post 1996 Black Widow engines. I advertise things as post 1996 because that is when Cox was acquired by the Estes Corp.
After that, in the year or two after, most of them still had the 'stunt-style' tank and the correct cylinder. The only thing different was usually that the engine was no longer anodized black.
Around 1998 or later the engine lost the 'stunt-style' tank and moved to the regular 8cc plastic tank. Most of these featured the traditional black widow cylinder with the open exhaust, dual bypass and sub-induction. I believe that there were a few that were incorrectly packaged as black widows since they were basically a sure start with an aluminum spinner.
Regards, Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
http://www.exmodelengines.com
Oops a little late with my post!
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  Admin Sat 27 Aug 2011 - 17:52
EXModelEngines wrote:Oops a little late with my post!
No, your fine. Estes had to get rid of some of the good parts before they could cheap it up. So yeah, you'll find some original like black widows and other engines made after '96 but once the parts started to run out, your start to find mixed engines. I remember reading on RCU some time ago that someone bought a NIP black widow from the hobby shop, it had a plastic (non stunt) tank BUT it had a stunt backplate. Ho do you fuel it??? Either Estes had no idea on what they were doing or they just didn't care.
Post  SuperDave Sat 27 Aug 2011 - 17:56
[quote="Admin"]
  • black crankcase
  • standard 325 head
That describes all my BW engines with only few exceptions. They are great performers in the C/L circle but I have not tryed them in R/C application and I doubt if I ever will. I have engines better suited for that purpose most notably a G-mark (Japanese).061 R/C with muffler.
!/2A inverted C/L flight requires a strong engine and the "right" airplane. My fav is a Carl Goldberg "Lil' Toot" bipe w/BW for power.
SuperDave
SuperDave
SuperDave
Post  EXModelEngines Sat 27 Aug 2011 - 18:03
They didn't care. The people over at Estes had/have no idea about the Cox line whatsoever. I pulled a Sure Start one time that had a beryllium copper reed that must have been laying forever in a mixed parts bin. Also another with a .051 piston literally shoved into the .049 cylinder.
Matt
EXModelEngines
EXModelEngines
Official Cox Dealer
Post  nitroairplane Sat 27 Aug 2011 - 18:17
Matt
estes stuff is a bit TERRIBLE
i think we should have a thread for bashing estes
nitroairplane
nitroairplane
Post  Admin Sat 27 Aug 2011 - 18:23
EXModelEngines wrote:Also another with a .051 piston literally shoved into the .049 cylinder.
Matt
I think that is the best Estes blunder yet! With the copper reed, the engine would still run. By switching out the plate on that black widow I noted earlier, it would run. But the .049 cylinder and the .051 piston, that is NOT going to run!
I have also started a thread on Estes Blunders since this could probably go on forever.
