Cox TD helldiver Cox_ba12
Cox TD helldiver Pixel
by TD ABUSER Today at 2:30 am
Cox TD helldiver Empty
Cox TD helldiver
Cox TD helldiver Empty Cox TD helldiver
Post  ramflames73 Sat Jan 15, 2022 8:19 pm
I was given a Helldiver for Christmas from one of my sons. The engine did not turn over. It was gummed up. I took it apart and cleaned the engine thoroughly. I also, cleaned out the needle valve. Unfortunately, the fuel tank, which is not attached to the engine, is damaged. Not sure what to do here. I can't find one. It also needs the foam wheels and the decals replaced. Does anyone know where I can find these parts if at all? I have been searching Ebay with no luck.
Cox TD helldiver 304810
ramflames73
ramflames73
Moderate Poster
Moderate Poster
Cox TD helldiver Empty Re: Cox TD helldiver
Post  Coxfledgling Sun Jan 16, 2022 4:04 am
Hi redflames,
You know of exmodelengines, Cox international and mecoa ?
Here in the UK, dens model supplies stocks 049 engine parts ( no td09 parts sadly ), from Cox international I think.
Good luck with your search.
Coxfledgling
Coxfledgling
Post  getback Sun Jan 16, 2022 5:33 am
Decals should bee no prob. got a printer / print ur own on water slide paper treat them and appl or buy on the bay https://www.ebay.com/itm/234297109349?hash=item368d322b65:g:gFkAAOSwsrphmYLL the tank could bee a problem , if it were me i would contact this person he does reproduction / or if you know someone with a 3d print but i can't find a parts illustration 1960-1966 https://www.ebay.com/itm/294660462297?hash=item449b21d6d9:g:FBoAAOSwNNVbK6nK The wheel you will just try and compare ones to work ... Very Happy
Post  Propfan Sun Jan 16, 2022 9:32 am
Hi, Contact 94cobra26 on Ebay. I bought a couple Helldiver tanks from him.
Propfan
Propfan
Moderate Poster
Moderate Poster
Post  ramflames73 Sun Jan 16, 2022 12:20 pm
So, have been busy cleaning and polishing. I freed up the motor. Replaced the tires using the stock rims. I have new decals coming. Now I just need a replacement fuel tank.
Cox TD helldiver 20220111
Cox TD helldiver 20220112
Cox TD helldiver 20220110
Cox TD helldiver 20220113
ramflames73
ramflames73
Moderate Poster
Moderate Poster
Post  getback Sun Jan 16, 2022 12:37 pm
Cool , Looking Good did you contact the propfan said to in the post above ? Small Cox Logo
Post  ramflames73 Sun Jan 16, 2022 1:24 pm
getback wrote:Cool , Looking Good did you contact the propfan said to in the post above ? Small Cox Logo
I looked on Ebay. I put the name in the search. Nothing. What should I look for to find a person?
ramflames73
ramflames73
Moderate Poster
Moderate Poster
Post  fredvon4 Sun Jan 16, 2022 6:28 pm
https://www.ebay.com/itm/324990492119
Post  ramflames73 Sun Jan 16, 2022 6:47 pm
Fredvon4 Thank you. I sent a message to him.
ramflames73
ramflames73
Moderate Poster
Moderate Poster
Post  Propfan Sun Jan 16, 2022 9:04 pm
Looks great. What do you use for polish?
Propfan
Propfan
Moderate Poster
Moderate Poster
Post  ramflames73 Sun Jan 16, 2022 9:10 pm
Propfan wrote:Looks great. What do you use for polish?
Mothers Plastic headlight polisher/cleaner.
ramflames73
ramflames73
Moderate Poster
Moderate Poster
Post  ramflames73 Mon Jan 17, 2022 9:44 am
ramflames73 wrote:Fredvon4 Thank you. I sent a message to him.
He is out of them. Crying or Very sad Thank you for trying to help me.
ramflames73
ramflames73
Moderate Poster
Moderate Poster
Post  944_Jim Mon Jan 17, 2022 12:24 pm
Can you post a picture of the tank, and fuselage halves with respect to the tank area? According to the other post pointing to a breakdown of the airplane, this is a cylinder-style tank with mounting ears that slip into the fuselage halves.
Unconventional repairs will most likely follow one of two paths...reconstruct the tank's fragments, and then epoxy-coat the outside with fuel proof epoxy, or scratch-build one from .005" K&S sheet stock. Neither option will be particularly impossible. Both options will require a bit of skill, with scratch-building being the most difficult.
The bonus is once completed, the only tell for the home-brew will be the pipes sticking up. An additional goody may be the ability to make the tank as deep as you can before getting into other bits inside.
Cox TD helldiver Empty Its look soo clean, love it, i would love to get mine cleaned like that! what do you use to clean it? Just the polish? Thanks!
Post  Steelfox Fri Aug 26, 2022 9:51 pm
ramflames73 wrote:So, have been busy cleaning and polishing. I freed up the motor. Replaced the tires using the stock rims. I have new decals coming. Now I just need a replacement fuel tank.
Steelfox
Steelfox
Beginner Poster
Beginner Poster
Cox TD helldiver Empty Helldiver cleaning tools? Detergent? Thanks!
Post  Steelfox Sat Aug 27, 2022 3:06 am
Steelfox
Steelfox
Beginner Poster
Beginner Poster
Post  Jerry Wed Oct 12, 2022 3:24 pm
Where did you find replacement tires for stock rims?
Jerry
Jerry
Bronze Member
Bronze Member
