Crank VS Crankcase Help Needed Please
Im sorting out my spares and such for my TD 049 engines. The cranks for the TD 049 I believe are hardened and I assume the crankcase they are running in is a reasonably vanilla Aluminum. My assumption therefore is that the crankcase will wear, get sloppy, etc. well before the Crankshaft does. I am guessing if this happens you could most likely put the crank into a new crankcase and use the carb body, backplate, collet, etc. from the old crankcase on the new one and all should be good again?
Has anybody had any experience with this, or need to do it at all? Have they had a TD crankcase wear a lot but the crankshaft was ok and could be re-housed on a new crankcase?
Thoughts and experience with this greatly appreciated.
Yabby
Yabby
Yabby- Platinum Member
Re: Crank VS Crankcase Help Needed Please
Yes the cases will wear. Even faster if using an electric starter. However, if taken care of they last a really long time. The aluminum is anodized and a little harder than usual. It still wears though.
What you propose on doing with swapping parts to a new case would be perfectly feasible. Honestly though you would be better off just buying cheap used TD’s clean them and they will be fine most of the time. This will also allow you to have more spares.
Thanks Cribbsy
Looks like it time for this old bloke to learn to use Ebay. 60 years and I have avoided it but I guess the time comes to us all.
Yabby
Do you have any RC clubs around you? They tend to hold annual flea markets and such. Good place to find cheap treasures.
That was a clever trick Ron!!! I couldnt work out how that got into the post. Lol. I just worked out that somehow you have injected the question straight into the post to muck with my old mind. Lol. I live in Adelaide South Australia and there are a number of RC clubs but they are VERY spread over the state with a lot of distance between them and I dont think they have very big numbers. Large state by area, very small population. The one RC club near me is nearly all electric as Ive gone out there to watch. Im not sure the clubs are on the scale where they have swap meets or flea markets themselves. But we do have general flea markets (junk markets) around the place and once covid restrictions are gone i will start haunting these places for things. Never know. I also travel a bit up north out if Adelaide to my shack and there are lots of little towns (farming) and they have all sorts of junk shops (my wife calls them antique shops hahaha), Im going to start looking in these also, as they often have old stuff and bits and pieces of things in boxes etc. Maybe I will strike it lucky one day!
Yabby
Yabby
Yabby
Have a TD051 with near 300 hours on its clock and it has not worn its case out. With properly balanced props and steel washer between the prop drive plate and the case it will outlive the cylinder and piston..if you buy pre-owned TeeDee-s destined to your spares stock, pay attention to the No.2 punched into the left mounting bar, these have longitudinal geometries inside slightly different than older cranks without the No.2. The crank web on later TeeDees-s was thickened for improved strength, and it necessitated the shortening of crank interior to keep the crankpin flush with cylinder centerline.
One other thing.
If you are good at anodizing you can clean the old case up and re-anodize it?
Working at Cat. we would get worn out plungers and barrels from the Cat dealers (core parts) and either phosphate, nitrite,
or re-anodize the old parts if they were not that worn out.
The phosphate, nitrite, or anodizing would add some material back onto the part you are coating ( the plunger / barrel)
The nitrite coating would add on to the surface anywhere from 0.005mm to 0.10mm
The phosphate coating would add to the surface 0.003mm to 0.006mm
The anodizing would add 0.002mm to 0.005mm
The thickness depended on how many times it was done and for how long.
After they were recoated, Cat. would sell the "used/reconditioned" parts as Remanufactured.
sosam117- Diamond Member
Thanks Sosam! I recall David put together an awesome thread in CEF on how he does anodizing of all kinds of things and different parts, that was quite lengthy and detailed. It makes sense as its not a lot between sloppy and good with overall diameter.
I have also taken on-board Cribbsys comment about keeping my props balanced! Guilty......... That reminded me last night and I spent a while balancing and re-checking some of my props. All the props fitted on engines are now either balanced or re-balanced. And I have a plastic bag with some take flying props for my toolbox that I have balanced and written on the bag with a sharpie pen so i know they are balanced. (plus you can see the evidence afterwards. but..........)
It seems if I look after my engines which I believe I do, I should have plenty of engines and spares already to take me well into the future. The engine I use on my Lads plane is a surestart that has been hammered and it seems to have almost no compression left at all, so I put a Kamtechnics head from Greg and a turbo plug on it and it goes like a stuck pig.
Thanks everyone. I love all the different little ideas and ways people have of getting life out of these engines or looking after them whilst using them lots such that they perform well for a very long time. I fly at least one day, often two days a week and my engines really get some use. Hence my interest in the little things that help them last whilst still being used heavily. i am perfectly happy to spend money and buy parts, but if doing little things can keep them going all the better!
Yabby
Yabby
» Looking for RR1 crankcase and crank
» cox .010 crank stuck in crankcase
» Need help identifying a TD .049 crank / crankcase
» Crank case prints needed
» My crank said No!
» My crank said No!
