pinion gear removal
pinion gear removal
Need pointers or advice in easy way to remove pinion gear from Cox/Cameron TD engines. Is there a special tool available? Don't want to ruin engine by doing it the wrong way
Thank you in advance
DWRODZ
DWRODZ
DWRODZ- Beginner Poster
Re: pinion gear removal
Can you post a photo?
So I can see "IF" a std. gear puller would work?
I have some that are "C" shaped, and "box" shaped for many "hobby" uses.
sosam117- Diamond Member
Mudhen- Gold Member
pinion gear removal
Thank you I will give that a try. In the interim I ordered a miniature hobby gear puller anticipating it will work.
Again thank you all in advance for your suggestions
DWRODZ
DWRODZ
Pinion Gear Removal
Thank you I was able to remove the pinion gears easily following all the advice, a little penetrating oil and a cutting blade utilizing the cutting edge as a wedge to apply slight outward pressure and off they came....no special tools or puller just good old advice from those that have been there. Thanks again
DWRODS
DWRODS
» NO pliers, but how do I get it off?
» Paint removal
» Spray bar removal
» Flats on top cylinder fin for COX wrench - DIY
» Removing QRC muffler
» Paint removal
» Spray bar removal
