Fox .049 glow plugs
ddock- Beginner Poster
Re: Fox .049 glow plugs
Hey Denny, WELCOME TO THE FORUM!!
Check in with EX Model Engines. http://www.exmodelengines.com/product.php?productid=18321&page=1
Matt is a valued supplier of parts we all use. He just happens to have a stash of Fox gems.
dckrsn- Diamond Member
Hey, hang out. Lots of members with wide interests.
Let us all know what you're doing with that Fox. No
Cox snobbery here.
Cox snobbery here.
just curious if you know if these plugs are for the fox.07 too? ex engines listing only says for fox 049 but Im almost sure the fox 049 and .07 use the same crankcase just not certian. I have 2 .07's and thinking of putting one on my norvel vision(cox katydid copy) thanks for any input cant find much info on the .07dckrsn wrote:Hey Denny, WELCOME TO THE FORUM!!
ChaseBanner- Gold Member
Check these out >> https://www.rcgroups.com/forums/showthread.php?835007-Custom-Modified-FOX-07-GLOW-HEADS
The Fox .049 and .07 use the same plug. The problem with the Fox plugs is that they fail with regularity and are very undependable. I truly believe it's mainly due to Fox using the thinnest wire available. The plugs glow practically white. Now the weird thing is that I have knocked out the post on the stock Fox plugs. I drilled and tapped for a standard plug like the link that Eric shows on RC Groups. The engine ran better than the stock plug. After I tapped the plug hole, I took a cut on the top and sunk the plug so that the plug was flush with the combustion face. I truly believe this is why it works so well.
Bob Matte Free Flight Engine Rework can also provide you with a ring that threads into the Fox cylinder but utilizes Cox glow plugs. This would enable the use of Nelson head adapters or turbo head adapters as well. You have a fair amount of options. The next problem is when the crankshaft blows apart and then you have to find another.
» Long glow plugs, standard plugs, couple of questions
» tetors glow plugs
» Anyone ever go here for your glow plugs.....
» glow plugs
» tetors glow plugs
» glow plugs
