question: gas powered cox or other 1/2a engines using the OS G5 plug
Page 3 of 3
Page 3 of 3 • 1, 2, 3
davidll1984- Diamond Member
Re: question: gas powered cox or other 1/2a engines using the OS G5 plug
Y dont no if the plug nead To exit the tip inside head its firt time y use them y have To start from the lowest compression posible. Y wil made litle test vidéo
After test result Not so Good low performance y dont tink its wort try this y wil try wat ever y can To make run faster tink it need very large ventury y use cox smaler cars tank ventury tink need larger and oil tink is To mutch oil in m'y mix y change the mix litle and now its worst harder To start once engine hot hard To start nitro is best for cox engine using gaz wil reduce rpm of like 35% y have the video coming
Ok y tink y have Good mix les oil les klotz nitro aded gaz Line and. Mutch gaz now no chim it have spi y stop the engine m'y hand To cold is lots of gaz left in the tank andthroughout the test the rc ring is Activate very difficult to endure the cold coming from the propeller it is very cold its wy y try To slow him down y adjust neadle Not mutch just litle 3 To 4 time
sounds a bit rich doesnt it
its the gas
the needle almost gets to sensitive
its the gas
robot797- Platinum Member
Yes it is very sensitive cant lean To mutch engine wil stop
Y tink its posible To fly Somting wit a cars wil run wit no doubt on gaz wit the plug
Y try the mix in m'y litle bugy 4x4 tee dee powered it work Not Perfect les power it work somhow
wow nice david! im glad you got it to run. would a different octane of gas make a difference?
Lukemiester- Gold Member
Y have no idea I didn't try with more
octane
octane
If you mounted it your fingers wouldn’t get cold...
Anyway, cool that it runs. May need to play with compression, I would buy a couple liters of Sunoco race fuel if they still have them up your way. I know in Ontario they stupidly merged with Petro-Canada.
VP sells a good octane booster in 1qt cans. Should be available at Canadian Tire or Princess Auto.
» Fox .15 Glow Plug Question
» Cox Glow Plug Clip Question
» Another Glow Plug CLip Question
» glow plug adapter for cox .15 engines
Page 3 of 3
