Nylon tubing Cox_ba12
Nylon tubing Pixel
by TD ABUSER Today at 2:30 am
Nylon tubing Empty
Nylon tubing
Nylon tubing Empty Nylon tubing
Post  jbanes1961 Wed Nov 20, 2019 12:45 pm
Hi all, does anyone have any tips for bending narrow diameter nylon tubing? I've read put a flexible cable inside and heat up tubing. I was thinking like some steel throttle cable inside then heat it up, if I can find any that small...
jbanes1961
jbanes1961
Bronze Member
Bronze Member
Nylon tubing Empty Re: Nylon tubing
Post  NEW222 Wed Nov 20, 2019 4:29 pm
That would be one way. ANother used is to fill with fine sand and bend. This at least works for small metal tubing. What application are you wanting to use it for? This may also help with replies.
Post  jbanes1961 Thu Nov 21, 2019 12:03 am
I have a Sullivan plastic external 1oz tank I'm going to be using. Instructions showing nylon, or brass tubing for the vent tube, angling upwards and sitting inside a little recessed area at the top of the tank. Thought I'd use the nylon tubing because it would be easier to bend, and from what I've been reading, is more resistant to nitromethane.
jbanes1961
jbanes1961
Bronze Member
Bronze Member
Post  Levent Suberk Thu Nov 21, 2019 1:30 am
I tightly wrap thin iron or copper wire around brass or aluminum tubing. Tightly wrapped wire, like as a spring prevents kinks. However I didn't try this with nylon tubing, perhaps it works.
Post  aspeed Thu Nov 21, 2019 7:49 am
Flex cable or weedwacker line if it is the right size. A bit of heat and you should be ok.
aspeed
aspeed
Post  jbanes1961 Thu Nov 21, 2019 11:05 pm
weedwacker line worked great.
jbanes1961
jbanes1961
Bronze Member
Bronze Member
