EX model engine 0.020 lower assembly questions Cox_ba12
EX model engine 0.020 lower assembly questions Pixel
by TD ABUSER Today at 2:30 am
EX model engine 0.020 lower assembly questions Empty
EX model engine 0.020 lower assembly questions Empty EX model engine 0.020 lower assembly questions
Post  aungmyatoo Sun Jul 14, 2019 3:34 am
I got 0.020 really damage to crank case so bought lower assembly form EX model engine.
I close the ventury with finger and flip the propeller to draw the fuel. But fuel are not drawing to carb, after close inspection, there is gap between carb body and needle valve body.
EX model engine 0.020 lower assembly questions Screen12
aungmyatoo
aungmyatoo
EX model engine 0.020 lower assembly questions Empty Re: EX model engine 0.020 lower assembly questions
Post  aungmyatoo Sun Jul 14, 2019 3:38 am
The surface of carb body where hole for ventury, the needle valve body rest is curve. I think it should be flat but it is not.
So the question is how do we make these gap fill and prevent air leak?
I don't want to use sealant, any gasket??
EX model engine 0.020 lower assembly questions Screen13
aungmyatoo
aungmyatoo
Post  1/2A Nut Sun Jul 14, 2019 4:19 am
I see two issues:
The needle valve is leaking you need to add some fuel tube to help seal the threads
Add a nylon washer to help make a seal. I fabricated one using the lid material from a coffee can.
That thickness is suitable. You can use some 000 size steel wool and clean up that corroded venturi.
As an alternative:
You have a carb body design that requires modification, flat file that arch down level.
I bought two like that and it's the best solution. You will have to remove the carb body
and rinse it out well after you are satisfied of a flat surface.
I seal everything with after run oil when assembling to help reduce air leaks and
for fighting off corrosion / helpful when you take it apart later down the road.
Small Cox Logo Thumbs Up
Post  Surfer_kris Sun Jul 14, 2019 6:33 am
The carb body from EX model is not made correctly and it has been discussed elsewhere on this forum or possibly on RCgroups.
You need to flatten the sealing surface or simply get a proper carb body from Coxinternational instead: https://coxengines.ca/cox-.020-carburetor-body-red.html
EX model engine 0.020 lower assembly questions Cox%20020%20Tee%20Dee%20Carb%20Body%20Red%201
Surfer_kris
Surfer_kris
