by TD ABUSER Today at 2:30 am
Norvel Engines Some Used but Mostly NIB, and Parts!
Page 2 of 2
Page 2 of 2 • 1, 2
Paypal
Would need your PayPal address please thanks
astroturf3040- New Member
My PayPal email address
pm sent
Scotty68- Silver Member
Re: Norvel Engines Some Used but Mostly NIB, and Parts!
Outbox shows messages you have sent out. Sent box shows the messages have been read by the intended recipient.
Messages will stay in the outbox until the recipient has read them and then they will disappear.
It is a little confusing, but it’s the quirks we have to deal with for a free service.
Thank you very much for this info, I was very confused there for a moment, even more than usual.Cribbs74 wrote:Outbox shows messages you have sent out. Sent box shows the messages have been read by the intended recipient.
Scotty68
Scotty68 wrote:Yes I do, are you looking for the AME or BigMig models?
AME, RC type, I believe. Whichever have RC carbs. I thought BigMig meant CL, but you could explain better I'm sure.
Chris...
stuntflyr- Gold Member
Chris, Yes RC designates the engine as a "carbed" or more accurately a "throttled" engine. As for the CL or RC labels they signify just that. RC stands for "remote control" meaning you can adjust the engine remotely and CL stands for "Control Line" which has no throttle so you can't adjust the engine while flying. I didn't/don't mean for that explanation to come across as condescending as it did. As far as the"BigMig" "AME" "AMA" and "AMD" labels are concerned I can only tell you that these are NOT the same. To my understanding, the Big Mig is a sport flying engine, where the AM? labelled engines are the high performance engines. I can't offer an explanation to the "Revlite" moniker. I could be wrong about part of this or even all of this but I am sure that someone on this site will chime in with a correction if I am wrong, there are some VERY knowledgeable individuals on here. (944_Jim where are you?)stuntflyr wrote:Scotty68 wrote:Yes I do, are you looking for the AME or BigMig models?
Chris...
So by your original response to my question I am led to believe that the engine you are interested in is the Throttled or RC version? Do you want the BigMig (sport) or the AMA (high performance) engine?
Scotty68
Last edited by Scotty68 on Thu Jun 27, 2019 4:58 pm; edited 1 time in total (Reason for editing : incorrect information)
Scott, you are making me blush!
I'm no expert in Norvels by any stretch, but really do enjoy them. I think Ken Cook may be able to supply additional details, or corrections. My time with my 2nd gen Big Migs is all I have for personal experience. The rest is gleaned from lots of study/observation.
There are basically two versions of these engines, across two releases/builds or generations.
Consider them related by family and intent. The versions are related much like Medallions and Tee Dees are.
Like Medallions, Big Migs are lower output sport engines. They have three transfer ports, and draw fuel well without demanding special fuel system considerations. They are most easilly identified by the Norvel symbol on the muffler side of the block, and the displacement cast as raised markings on the opposite side. The larger .15 engines actually say Big Mig on the edge of the left mounting lug. I suspect the .25s will also.
The second variant is the AMx (AMA/AMD/AME). These engines are very similar to the Big Migs,.and look identical from outside the cases. The heads need to be removed to identify 5 transfer ports. Another tell is the AMx.series usually has AMx on the case, and the displacement "written" or etched on the side. It usually looks like it is done freehand with a sharpie. Another indicator is these usually have what appears to be a serial number on the case also.
Then there are two distinct generations of these engines. The earlier one has a round base venturi or carb opening in the case, and the venturi or carb is glued in. I seem to remember glue peeking out of what could be screw holes, so these may he able to swap/replace the intake and have it retained by more traditional screws.
The later generation has the "bathtub" opening in the case. And it is referred.to as the bathtub because the shape looks like an old cast iron bathtub. The venturi or carb sits in the bathtub, and is retained by screws. I noted that my venturies have fine-mesh screens. The few carbs I've seen didn't have screens.
Revlite is the coating technology that is touted on the side of the box. I suspect the later generation engines are all Revlite, but I could just as easily be wrong. I feel like I read that is truly a ceramic coating, but won't confirm it. I will say it marks the exhaust in grey color as the engine breaks in. One of the tells to the engine's break-in time is that once broken in, the exhaust will look fairly clean. The coating reminded.me.of the special.coarings I had sprayed/baked onto my Sport bike engine. Like the bike coating, Revlite appears to hold oil into the moving parts.for superior lubrication. I base this on what I observed during the very careful break-in I observed on two Big Mig .074s and a pair of Big Mig .061s. The coating looks.like graphite on the piston, and while minimally dry spinning the engines across BDC, they felt "grainy," or coarse.
There is one more subset of these engines. Norvel also made engines with additional tabs on the front of the crankcase. These engines were typically installed in helicopters. There is a thread over on StuntHanger with instructions/hints on how to make prop drive plates. These sold for peanuts. I suspect the price drop was due to the extra work involved in repurposing them.
These engines are known, or villified, by their considerable top end pinch. A lot of the pinch goes away with proper break in. Then they have stiff compression at TDC with little bleed down. Mine will actually finger-start now.
I hope this helps others. And I'm open for corrections if I have some things mis-understood.
The Norvel engine line can be very confusing. One thing for certain is that the Big Mig and AME are not the same engine. The early engines prior to Norvel were named the AME Zeus. These engines looked very familiar to the Norvel but the case was shorter in the nose. Norvel later designated their porting style as AME. To designate the difference, remove the head and note the cylinder porting. Outside, both engines appear to be identical. The other confusing factor here is that it confused the manufacturers equally and they installed Big Mig engines in AME boxes and vice versa. I was fortunate enough when this happened to obtain these mismatched boxed engines for $25 a piece directly from Norvel. To identify a Big Mig, remove the head and the engines will have 5 ports cut into the cylinder, the AME will have 3 large ports.
While the Big Mig is considered the sport engine, it's no slouch by any means. The Big Mig will run on suction without issue while the AME has a larger venturi and requires pressure, via muffler, case pressure, or bladder pressure. All of the engine cases uses a oval bathtub casting in the case. The earlier Norvel engines used the glued in venturi which is round but where it enters the case, it's oval.
Thanks Ken,
It looks like I have my port count backwards!
I never cracked a case open to count ports.
I will add this to my inferior memory banks.
I will say that I have been pretty consistent staying away from AMxs by looking for what appears to be hand-scribed alphanumeric characters on both sides.
And I believe I've gotten only Big Migs based on the displacement as a raised casting on the port side, and the Norvel raised casting on starboard.
The hand inked scribing pre dates the latest releases of engines. It's nothing to be concerned about. I have dozens of them from the early 90's and most of them have the ink smearing off. It was just how they did it. Some cases have the displacement cast into the case, others are stamped, some are inked. I can also add that the D in AMD only appeared when NV took the engine line over. I also wondered what it meant. The original AME engines were built by students. You either had a turd or a decent running engine. There were more turds then good engines.
Hello, I'd like to buy some parts for my Norvel engines 049/061.
1) 2 Needle valve screws(long/short)
2) 3 Spring starters
3) 1 Cover plate
4) 3 Mufflers
5) 2 Muffler springs
Do you have them all? Hope to hear from you soon. Thanks!
3) 1 Cover plate
4) 3 Mufflers
lskz918- New Member
• NOTE: This listing is located in the For Sale/Wanted ARCHIVES as it is greater than 90 days old.
• Items listed here MAY NO LONGER BE AVAILABLE.
• If this is your listing and your item is still available, or you still haven't found a wanted item, please create a new listing in the For Sale/Wanted section.
• Before replying to any listing, please read through all the rules and guidelines.
Scotty68 bio has this Latest topic : Wed May 08 2019, 22:47
lskz918 FIRST....WELCOME TO CEF...we all love to help
please go introduce yourself and start a want ad in the appropriate area
this listing is relatively old and the Original Poster has not posted again since /May 8 a year ago...
alternatively you may click the icon link under Scotty68's screen name a send a PM...He might get a e-mail notice of your private message
trying to purchase items
I need these norvel pats:
100102
100148
102105
100137
110131 Thanks West1944
230131
100102
100148
102105
100137
230131
west1944- New Member
west1944 wrote:I need these norvel pats:
100102
100148
102105
100137
230131
west1944,
I am unsure if you are aware of this but Norvel part numbers are less than reliable or even consistent. I am going to need more than just Part Numbers. How about a part description and engine it is intended for?
Scotty68
Scotty68,
Long time, no hear!
This sure is a long-running thread.
I'm glad you still have NV parts. I need to run through my stash for holes. I know for sure I need a glowplug adapter for a recently acquired Big Mig. I just can't remember if it was a .15, or .25. The price was too good to pass up, but it was due to no interest at large in an incomplete engine. I'll email over the weekend.
Be well, Friend.
Long time, no hear!
Be well, Friend.
944_Jim wrote:Scotty68,
Long time, no hear!
Be well, Friend.
Hey Jim, good to hear from you. I don't have near the parts that I used to but still have a few odds and ends. Get a hold of me this weekend.
Take care,
Scotty68
Parts
All for a .049. 100102 spinner; 100148 head adapter for regular glow plug; 102105 spring starter; 100137 propeller screw; 110131 head; 230131 head wrench. Thanks Mitch
west1944 wrote:All for a .049. 100102 spinner; 100148 head adapter for regular glow plug; 102105 spring starter; 100137 propeller screw; 110131 head; 230131 head wrench. Thanks Mitch
Don’t know if you have tried the original source of NV engines? My last order was way way back in 2017, but I did receive the parts I ordered. The web page seems to still be active and my username and password still work!
http://www.nvengines.com/
Send them email and see if they respond
Page 2 of 2 • 1, 2
» Parts for Norvel engines 049/061
» OS 10 engines and parts -SOLD-
» Refurbished Engines & OEM Cox Parts
» fine thread needle on Norvel's and similar engines
Page 2 of 2
