Cylinders Run Time & SPI Performance Cox_ba12
Cylinders Run Time & SPI Performance Pixel
Cylinders Run Time & SPI Performance Empty
Cylinders Run Time & SPI Performance Empty Cylinders Run Time & SPI Performance
Post  Iceberg Wed Jan 02, 2019 12:40 am
I have  .049 cylinders except the 0 cylinder never seen one. Does anyone have any actual stats that show if the SPI cylinders actually improve performance by what amount in RPM? Do any of the 0-8 cylinders last longer than others? Interested to know. What run time is reasonable? I've heard cylinder runnng life is roughly three hours?
Thanks
Iceberg
Iceberg
Iceberg
Cylinders Run Time & SPI Performance Empty Re: Cylinders Run Time & SPI Performance
Post  balogh Wed Jan 02, 2019 1:16 am
If kept clean and well lubricated, a COX engine will work for many hours. I read that a COX factory experiment put 400 hours on an engine that still could be started up afterwards, with an electric starter though. https://web.archive.org/web/20170410030959/http://www.mccookfieldfac.com/helpful-info/cox-engines.pdf ...see 2nd page, top right.
I have a COX TD051 with tapered bore cylinder that I counted to have run near 300 hours and still runs very fast. Remember that castor varnish that builds up on the cylinder wall of a used engine can partly make up for the wear of the mating surfaces.
In my experience SPI can add 500-1500 rpm depending on the type of cylinder and other particular conditions.
Post  MBT85 Wed Jan 02, 2019 2:19 am
I don’t want to sound silly but what is SPI Cylinder?
MBT85
MBT85
Silver Member
Silver Member
Post  balogh Wed Jan 02, 2019 2:25 am
SPI stands for sub- piston induction where the piston skirt bottom clears the exhaust ports when on top dead center, thus allowing a puff of extra air enter the crankcase and mix with the fresh charge that thus can also carry extra fuel in it = added engine power. On the parallel thread "SPI and free porting" you find more on this as well.
