Another proposed design by Roddie - Page 2 Cox_ba12
Another proposed design by Roddie - Page 2 Pixel
by roddie Today at 10:43 am
by rsv1cox Today at 9:00 am
by rsv1cox Today at 7:35 am
Another proposed design by Roddie - Page 2 Empty
Page 2 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Thinking Re: Another proposed design by Roddie
Post  akjgardner Thu Feb 07, 2019 1:50 pm
Looking Good Roddie, Got a Fire lit under me to Start Building Again Too,Thanks
Post  roddie Thu Feb 07, 2019 2:25 pm
akjgardner wrote:Looking Good Roddie, Got a Fire lit under me to Start Building Again Too,Thanks
Thank You Joe! Thumbs Up What's x-tra cool about your interest, is that this design was somewhat inspired by two of the Goldberg 1/2A C/L kits. The models' "areas" are a cross between the Swordsman 18 and the Stuntman 23 models, of which I have both examples. Somebody that we know.. recently built a pair of Stuntman 23's.. one with a hybrid cardboard-wing.. having a diamond-airfoil.  Cool
Another proposed design by Roddie - Page 2 0221110
Another proposed design by Roddie - Page 2 Cardbo10
I liked those models a LOT.. and I'm glad to be a catalyst to get you inspired to build again! Thumbs Up Thumbs Up
Thinking engine-mount/nose-reinforcement
Post  roddie Thu Feb 07, 2019 3:58 pm
Trying to K.I.S. here.. but I'm also designing on the fly.. using materials that I have in stock. I need to provide some space for an external fuel-supply (tank) for the Cox .049 product-engine option. The "cheek-blocks" found in some traditional 1/2A profile kit-designs for reed-valve engines prohibit this. As in my previous designs, I use the vertical hardwood-blocks combined with plywood nose-doublers to form a rigid "T" engine-mounting which leaves some room behind the mounting, for a hard-tank.
Another proposed design by Roddie - Page 2 Nose_c10
I'm marking-up the drawing as I go.. and will compile a "stock-list" on completion.
Thinking Engine-mount/nose-reinforcement
Post  roddie Thu Feb 07, 2019 7:43 pm
The engine-mounts' screw-blocks are now fitted to the wings' L/E with the wing located into its' slot in the fuse.
Another proposed design by Roddie - Page 2 Nose_c11
Another proposed design by Roddie - Page 2 Nose_c12
It's not a "simple" matter to fit these parts together.. but it "is" most satisfying when it goes together as planned.
Post  NEW222 Thu Feb 07, 2019 7:57 pm
Its getting assembled!!!! Looking good. So if I am not mistaking, it is a 1/4" fuselage with 1/16" doublers on the sides? I now understand the 'ridgid t' as mentioned earlier. Looks good and strong up there.
Post  roddie Fri Feb 08, 2019 7:21 pm
NEW222 wrote:Its getting assembled!!!! Looking good. So if I am not mistaking, it is a 1/4" fuselage with 1/16" doublers on the sides? I now understand the 'ridgid t' as mentioned earlier. Looks good and strong up there.
Yes it is! Thanks again Chancey!! The fuse is actually 3/16" (4.76mm) thickness balsa. It's relatively dense-wood though.. or else I would have chosen thicker stock. It's a combination of "B and C-grain".. which is what you'd want to use where strength is a consideration.. but not overkill/hard-grade wood.. which can be heavy. The nose-doublers are listed on my drawing as 1/16" plywood.. but I actually used a "single-ply" of .055" (1.4mm) Baltic-Birch.. as an experimental material. You won't find it for sale anywhere though. The material is "scrap".. procured from a CNC machining-process where I work. If you desire some of this stock, I have plenty that I could mail to you. It is also the stock that I am using (laminating x2 thicknesses; cross-grain) for the firewall.
The "rigid T"...  Smile I'm glad that you picked-up on that. It's not the most attractive design-element that I've ever applied.. but it will hopefully contain the engine to the airframe, if the model meets terra firma in a "less than graceful manner"..  Laughing
Post  NEW222 Fri Feb 08, 2019 8:35 pm
roddie wrote: but it will hopefully contain the engine to the airframe, if the model meets terra firma in a "less than graceful manner"..  Laughing
Hi again roddie. I am in no way saying to do this, but just an idea I have used before. I cannot say or guarantee that it does work 100%, but does add strength to the engine mounts. Where the light blue 'X' is, drill a hole of proper size right through the upright engine mounts (this includes through the fuselage as well). From there, insert your choice of bracing (red line in picture above the 'X;'). I have used both hard wood toothpicks as well as bamboo skewers (this is why I said drill accordingly). I fill the hole with either epoxy or wood glue, then insert my brace of choice and allow to dry. When dry, just cut off the ends and sand flush. To me, it is extra security for holding things to the fuselage. I would do one brace above the wing, and one brace below the wing. This is just my $.02. Very Happy
Thinking fuse-contouring using the French-curve
Post  roddie Fri Feb 08, 2019 8:42 pm
Here's an example of what I came up with for adding contours to the fuse, using a French-curve.
Another proposed design by Roddie - Page 2 Fuse_c10
The top-side of the nose; fairing back-into the canopy, needs a little attention.. but I'm satisfied with the general shape so far. There's still the fin/rudder to draw-out. I'm leaning toward a Ringmaster-shape.
Choosing belly/canopy contours takes no time at all.. nor does drawing (tracing) them onto the wood. "  Cutting-out and sanding" the parts takes a little more time.. but that's modeling..  Smile
Post  roddie Fri Feb 08, 2019 8:44 pm
I LIKE that idea Chancey! I will definitely consider it! Thumbs Up
Thinking more contouring, cutting and sanding..
Post  roddie Sat Feb 09, 2019 5:23 pm
Another proposed design by Roddie - Page 2 Fuse_c11
Another proposed design by Roddie - Page 2 Final_10
I keep adding details to my drawing.. once I make them to the physical model. As you can see.. it's getting cluttered. I will probably re-draw the whole design using a larger pc. of paper. I use a good quality "graph-paper" because it holds-up to repeated "erasing".. and helps with measuring and squaring-up outlines. I use Scotch (Magic-Tape) on the backside-seams when using multiple sheets. Sometimes the sheet-edge(s) need to be "trimmed" so that the 1/4" grid-patterns intersect accurately. This is important when using the grid to measure across multiple sheets.
Another proposed design by Roddie - Page 2 Fulcru11
Thinking A second fit-up
Post  roddie Sat Feb 09, 2019 9:38 pm
I decided to make the landing gear today.. and the struts are a little too long.. but better than too short. I had a remnant-length of .062" music-wire which made the struts. There is still plenty leftover for a pushrod and tail-skid/gear.
Another proposed design by Roddie - Page 2 2nd_fi10
Another proposed design by Roddie - Page 2 2nd_fi11
Another proposed design by Roddie - Page 2 2nd_fi12
Post  getback Sun Feb 10, 2019 8:34 am
What the heck is up with all the added fuse material ? I have a stunt man 23 and it dont look nothing like that , what is the weight. Sorry butt it was looking good till (well)  Another proposed design by Roddie - Page 2 00410
Post  roddie Sun Feb 10, 2019 9:31 am
getback wrote:What the heck is up with all the added fuse material ? I have a stunt man 23 and it dont look nothing like that , what is the weight. Sorry butt it was looking good till (well)
Shocked... Does it look that bad? The added fuse material is what I call contouring. I figured I'd give it some style.. rather than boring/boxy straight-lines. I never claimed that this model would look anything like a Stuntman 23. I was aiming for a design with proportions somewhere between the Stuntman 23 and the smaller Swordsman 18.
The weight (less wheels and paint) is 4.5 oz.
Another proposed design by Roddie - Page 2 Weight10
It's difficult to see in the above photo, but there's a 16+ inch piece of .062" music-wire on the scale which weighs .2 oz. I included it because the elev. pushrod will be made from it.. but at "half" that length.
I appreciate your honesty Eric.
Post  rsv1cox Sun Feb 10, 2019 10:55 am
Eric, you are precious.  Bet you have never been told that.  Me neither.  You ever leave the forum I'm following you out the door.
roddie I like your design but the horizontal stab doesn't come close to matching the wing.  But, beauty is in the eye.  I love the notations, I would be tempted to clear gloss them over and keep them.  Adds uniqueness and charm.
Keep at it, you have never made a dud yet.
PS: Eric, the paint scheme on your plane is just plain awful. Smile
Post  NEW222 Sun Feb 10, 2019 11:12 am
Oooooh. Added body parts! I like the thought, and changes. I wish I had the mindset to do something like that. Now as I see it with your added cut-outs, to me, it screams to me that it is like a cartoon type plane. I do like the shorter chubby style fuselage design, and that is where I see the 'cartoon' in it. Keep up teh good work, I'm enjoying it! I really like every little twist along the way.
Post  KariFS Sun Feb 10, 2019 11:17 am
Roddie, your design looks to me like a Brewster Buffalo turned into a Reno racer Cool
I like it, quite unusual “as usual” when it comes to your designs Very Happy
Here’s a 3-view of the Buffalo:
Another proposed design by Roddie - Page 2 5ec5aa10
Post  rsv1cox Sun Feb 10, 2019 12:04 pm
Kari, I think you have it.
Just add a little positive inboard taper to the wing and it fits, even carries out roddies oval horz stab.
The Brewster Buffalo, has been a favorite of mine. Seems it saw action early WW2. Clearly out classed though by fighters of the period.
Post  KariFS Sun Feb 10, 2019 12:36 pm
The Buffalo is one of my favourites too. Its world-wide signifigance is not very big, but it is the fighter that saved Finland in the beginning of the Continuation War against the Soviets. They did pretty good actually, of course the Soviets did not have their best and most experienced forces at our front.
Here’s one of the Aces, Hans Wind (yes, that’s his real name although it sounds like a some kind of a superhero nickname) with his Buffalo, note the kill markings on the tail.
Another proposed design by Roddie - Page 2 Sakuva_lg_165769
Post  getback Sun Feb 10, 2019 12:54 pm
rsv1cox wrote:Eric, you are precious.  Bet you have never been told that.  Me neither.  You ever leave the forum I'm following you out the door.
  lol! lol! lol!  OK i did say i was SORRY ! Hold on and i will take another look Another proposed design by Roddie - Page 2 Passit11  There thats alot better  . Just saying I know i built and painted ? that 23 when i was like 15 Its still in one piece . Roddie you the Man Whatever you decide is fine with me Popcorn
Post  rsv1cox Sun Feb 10, 2019 1:16 pm
Smile Smile
roddie, back to you.
Post  roddie Sun Feb 10, 2019 1:20 pm
Thank You "all" for commenting. I appreciate it very much. Yes.. I tend to apply some unorthodox styling-cues and unconventional construction techniques to my models. There's often challenges along the way.. but there's always a way around them. Solving problems is something that I find enjoyable.. rather than getting frustrated. It does take patience.. of which I have a lot of.
Post  roddie Sun Feb 10, 2019 1:23 pm
Laughing yes.. you are sorry.. Laughing tongue
Thinking .... hinging the stab./elev.
Post  roddie Sun Feb 10, 2019 2:16 pm
Most of you have seen me use this technique for CA-hinges before.. but I'll reiterate/post photos for those who haven't.
My control-surfaces to be hinged are 1/8" balsa. I layout the hinge-points using a scale.. prior to separating (cutting) the stab./elev. apart into two separate pieces. This assures that the hinge-points line-up on both parts.
Another proposed design by Roddie - Page 2 Hingin10
I like the "Sig Manufacturing" brand Easy Hinges. They are inserted into a "slot" in the control-surface and held secure with thin CA-glue. Each hinge measures 3/4" x 1" for larger models.. so I cut them into 1/4" x 3/4" pieces for my 1/2A airplanes. I use an x-acto #17 chisel-blade to cut the hinge-slots.
Another proposed design by Roddie - Page 2 Hingin11
After cutting the hinges to 1/4" x 3/4" I "nibble" the corners diagonally with clippers. This makes the hinge easier to install into the slot.
Another proposed design by Roddie - Page 2 Hingin12
For slotting 1/8" thickness control-surfaces, I use a half-thickness (1/16") strip of material. It could be 1/16" plywood.. or anything else.. as long as it's half the thickness of the control surfaces to be hinged. The #17 chisel-blade is laid-flat against the strip and up against the edge of the control-surface, which centers the blade for cutting the slot. It helps to clamp the workpiece close to the edge of a tabletop for better control of the tool.. and cutting-depth.
Another proposed design by Roddie - Page 2 Hingin13
Then the hinges are "dry-fitted" (no glue yet!!!)
Another proposed design by Roddie - Page 2 Hingin15
Another proposed design by Roddie - Page 2 Hingin16
Another proposed design by Roddie - Page 2 Hingin17
Once the dry-fitting is done, the hinges are removed and the surfaces get "beveled" (sanded) to a feathered-edge.
Post  NEW222 Sun Feb 10, 2019 2:51 pm
Wow roddie. That looks great. I love the hinging method. I have used them in the past but they were almost never straight into the surface. Sometimes even poking through the surface. A nice and easy idea. Thanks. However, I have to ask. Do you feel the control surface is too stiff? I used to use strips of them as you, but thought they were too stiff for my liking. I have heard of old computer floppy disks, but never tried them. All the best!
Post  roddie Sun Feb 10, 2019 6:32 pm
Chancey, I used to use the sm. size Dubro pinned-hinges.. and cut the slots for them using the Dubro "Kwik-Hinge Slotter" tool. The pinned-hinges are nice.. but digging-out the slots for them is a wicked PIA. My first four designs from back in the 1990's have them. It's a wonder that I built any more models after that.. Laughing By the fourth one.. I had gotten better at it.. (my flapped orange plane has ten Dubro sm. pinned-hinges..) but once I tried the Sig CA hinges.. I never looked back.
I've wanted to try the "stitched-hinge".. and probably should have with this design.. but I'm used to the technique that I've developed with the CA type. Yea.. they're stiffer but I don't think it's a big deal. I fly control-line.. and I actually like the feedback at the handle.. if that makes sense. A 1/2A RC flyer might be concerned about the stresses that stiffer hinges might place on small/nano-servos.. but in reality; poorly-configured (binding) control-linkages pose more of a threat to a servo. IMHO.. Smile
Thanks again for your support!
