Davis diesel head improvement - Page 2 Cox_ba12
Davis diesel head improvement - Page 2 Pixel
by Ken Cook Today at 5:09 am
by TD ABUSER Today at 2:30 am
Davis diesel head improvement - Page 2 Empty
Page 2 of 2 Previous  1, 2
Davis diesel head improvement - Page 2 Empty Ever considered using seal machined from PEEK?
Post  AllSoldOut Sat Nov 24, 2018 1:56 pm
All,
This is probably a stupid idea, but I would consider getting a seal machined from unfilled PEEK for what is (almost) static sealing application. I appreciate that you might need to change your seal housing design in order to fit it and ten give it the desired 'squeeze'.
If this idea is worth a light and can possibly done, make sure you buy the good stuff - i.e. use a reputable supplier of a manufacturer that processes the bar stock correctly. Back here in the UK I always specify Quadrant Plastics.
AllSoldOut
AllSoldOut
Beginner Poster
Beginner Poster
Davis diesel head improvement - Page 2 Empty Re: Davis diesel head improvement
Post  robot797 Sat Nov 24, 2018 2:03 pm
could you explain this in diverent words?
i dont realy understand what you mean
robot797
robot797
Post  fredvon4 Sun Nov 25, 2018 11:41 am
Had to Google
PEEK or Polyetheretherketone refers to a semi-crystalline organic polymer thermoplastic exhibiting a highly stable chemical structure, which gives it an edge over other materials
Post  smooth_bill Sun Nov 25, 2018 7:58 pm
Don't forget plumbing shop O-rings, as the standard rings last much longer than the original McCoy soft rubber rings. I've been using them in my McCoy .049 diesels for years. Mine use the size 10 rings which are an easy stretch over the McCoy contra pistons, but snap right into the groove, seal very well, and last a long time.
I bought my first McCoy .049 diesel in 1953, and I don't remember seeing O-rings used on any US diesel engines before then. The rings used were soft white rubber and shredded in just a few runs, so the head and contra piston had to be removed regularly to flush out the mush. I called McCoy to order more rings, but they insisted they would send me some just for the asking. The bag they sent lasted far longer than the engine was in my possession.
Bought several McCoy .049 diesels in later years, and haven't worn out any plumbing rings yet.
One precaution I would recommend for any diesel engine, is using care when installing the contra and new ring, so the ring is not damaged during installation.
Bill
smooth_bill
smooth_bill
Post  robot797 Tue Dec 04, 2018 10:42 am
okey i got my hardend shaft today
and i ran a engine on a 120ml tank
took over 40 min to drain it
it ran great
and it starts great
i have to change one or 2 things on the drawing and then i am calling it finished
robot797
robot797
Post  robot797 Tue Dec 01, 2020 2:34 pm
I dont like the latest version of the head
I have been running it for a while now
but there are things I want to improve
wider oring groove
and the concave inside does make the engine run better
so back to the drawing board
robot797
robot797
Post  atesus Tue Sep 28, 2021 5:27 am
Any updates on this project?
atesus
atesus
Moderate Poster
Moderate Poster
Post  robot797 Sun Oct 03, 2021 4:09 pm
atesus wrote:Any updates on this project?
due to personal problems most of my projects were put on hold
I hope I will be able to start some back up (again)
robot797
robot797
Post  atesus Mon Oct 04, 2021 2:25 am
I hope you resolve your problems quickly and get back to your projects.
atesus
atesus
Moderate Poster
Moderate Poster
Davis diesel head improvement - Page 2 Empty Brass disk cutting
Post  Dave Lofthouse Thu Dec 01, 2022 12:37 pm
I am reading this thread with interest and noted the references to a brass disk instead of teflon for the Davis set up. How are you cutting the disk? It would seem some level of precision is needed to achieve a proper seal. I am totally new to the diesel scene and nobody around me is into it so all advice is appreciated.
Dave Lofthouse
Dave Lofthouse
New Member
New Member
Post  robot797 Thu Dec 01, 2022 2:51 pm
I use pop cans myself
and a good paper punch works great
robot797
robot797
Post  atesus Thu Dec 01, 2022 3:08 pm
I use this set:
https://www.amazon.com/gp/product/B0002T87E0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I used it for 049 and 020 engines. There's an exact size for one of them, the other one needs a bit of sanding, not sure now which one is which though.
Aluminum cans also work fine, though shorter lived.
In any event, I suggest to consider diesel conversion heads from Mecoa which are O-ring based. I had much better luck with them.
--Atesus
atesus
atesus
Moderate Poster
Moderate Poster
Post  robot797 Thu Dec 01, 2022 3:15 pm
https://www.amazon.com/EK-Tools-Circle-Punch-0-50-Inch/dp/B0090JVDNA/ref=sr_1_5?crid=2N8D271TCYCWN&keywords=paper+punch+0.5&qid=1669929286&sprefix=paper+punch+0.5%2Caps%2C244&sr=8-5
something like this is what I use XD
robot797
robot797
Davis diesel head improvement - Page 2 Empty Good stuff
Post  Dave Lofthouse Mon Dec 05, 2022 3:52 pm
Thanks for the ideas all. I have quality vintage punch set (Enco I think). I was unsure that the edge might deform enough to cause problems. I suppose that with enough torque, the head will squash it back into shape. Thinking out loud. I will look into the o-ring type heads available on aftermarket but since I have the Davis heads in hand, I wanted to give it a try.
Dave Lofthouse
Dave Lofthouse
New Member
New Member
Post  ffkiwi Tue Dec 06, 2022 5:05 am
Oldenginerod wrote:As far as I know, most European diesels never ran an o-ring to seal the contra-piston. The piston was just a very tight machine-fit.  It looks like the o-ring is an American idea, as I've only seen them in OK Cub diesels and the RJL conversion heads.  Certainly of the dozen diesels I have, none use an o-ring.  Australian, British, Russian, Chinese, Indian.  All have a machined-fit contra-piston.  The only real disadvantage is that it's common for the contra-piston to stick, particularly if someone unwittingly screws the comp screw down too far onto part of the bore which has carbon build-up. It can be very hard to budge a stuck contra and many diesels have been damaged by the owners trying.  Generally, the first time the engine fires it will shoot the conta back against the comp screw.
Actually the 1957 Frog 80 Mk1 used an o-ring sealed contra....probably inspired by the McCoy 049 and 09 diesels-or the small OK diesel Cubs.....it (the O-ring comtra) was not well received by UK and Commonwealth users, though there was nothing wrong with the engine overall- and the Mk2 version of 1961 reverted to the traditional lapped contra....and so things remained until Bob Davis hove into public view around 1979....
ChrisM
ffkiwi
ffkiwi
