I need something with more pulling power than a Black Widow. Suggestions? Cox_ba12
I need something with more pulling power than a Black Widow. Suggestions? Pixel
by Ken Cook Today at 5:09 am
by TD ABUSER Today at 2:30 am
I need something with more pulling power than a Black Widow. Suggestions? Empty
I need something with more pulling power than a Black Widow. Suggestions? Empty I need something with more pulling power than a Black Widow. Suggestions?
Post  RknRusty Sat Aug 20, 2011 9:36 pm
I have a Stuntman23 that is really fun to fly, but the .049 is at the minimum on the list for this plane. Due to 13 years of repairs, it's a little heavier than it used to be and I would like to speed it up. I know there are several Tee Dee sizes but I know nothing about them.
Can someone give me a rundown on their strengths and weaknesses, or recommend something else? I want to be able to get spare parts too.
Thanks,
I need something with more pulling power than a Black Widow. Suggestions? Empty Re: I need something with more pulling power than a Black Widow. Suggestions?
Post  Admin Sat Aug 20, 2011 9:45 pm
TD .049, TD .051, TD .09
I need something with more pulling power than a Black Widow. Suggestions? Td_pro10
If you get a complete engine, all the parts you should ever need would be replacement glow heads maybe a carb body since they can crack from age or from a crash. Those parts are still available.
Post  nitroairplane Sun Aug 21, 2011 2:57 am
If you are comfortable with diesel then you could get a paw .03 they make about as much thrust as a tee dee .049 or get a paw 049 or 061 they are all great engines.
But if you want a really high rpm engine your best bet is to get a certain Russian engine beginning with the letter "n" or just put a tee dee .09 on it or a thunder tiger tt .07 all the engines listed are more powerful than a blackwiddow.
There are other options like maybe a Shuriken .061 Smile only kidding they cost about 700$ and are competition engines but there are varios: Brodak,CS,MPjet,Asp,VA or valentine engines.
Ther are also lots of other Enlish diesels but they are rare and expensiv epitaphs the UK.
nitroairplane
nitroairplane
Post  GermanBeez Sun Aug 21, 2011 3:46 am
or get a venom. they go for a very good price, and they are abundant on ebay Very Happy Very Happy Very Happy Very Happy Very Happy
GermanBeez
GermanBeez
Post  nitroairplane Sun Aug 21, 2011 7:11 am
You know what's better than a black widow?
Two black widdows Smile
nitroairplane
nitroairplane
Post  GermanBeez Sun Aug 21, 2011 9:38 am
duh,you're SO correct!!!
GermanBeez
GermanBeez
Post  microflitedude Sun Aug 21, 2011 9:44 am
How bout three? Very Happy
microflitedude
microflitedude
Post  GermanBeez Sun Aug 21, 2011 9:49 am
or of course one with twenty tank extenders!
but, seriously,the tee dees are definitly the strongest bunch of the cox 049, except the
venom, which is the freak in the group. though there is another one, the killer bee,
from which the venom derived. it has spi and a balnced HP-Crank shaft.
it also has a high intake flow back plate. they might be a bit pricey (70$, but i could
be wrong) on ebay, but they definitly have more power than the black widow
GermanBeez
GermanBeez
Post  gcb Sun Aug 21, 2011 10:09 am
RknRusty wrote:I have a Stuntman23 that is really fun to fly, but the .049 is at the minimum on the list for this plane. Due to 13 years of repairs, it's a little heavier than it used to be and I would like to speed it up. I know there are several Tee Dee sizes but I know nothing about them.
Thanks,
First question is, are you getting all you can from your BW? Are you using a high performance glow head? Higher nitro, say 35%, how about different props...say an APC 6x2?
Otherwise, if you can score a NORVEL tank mount, the tank will fit in the same holes as your BW and a TeeDee .049 will mount in the same holes as the NORVEL .049/.061 so you can maintain your radial mount. Of course you could use a Cox mount but I don't know if you can plumb them for stunt.
Plan C would involve rebuilding the front end for a beam mounted engine. You could then use a TD .049/.051 or perhaps an .061 such as a PAW, NORVEL, or AP Wasp. The TD, NORVEL, and WASP all have the same mounting holes, although the crankcase is just a bit wider on the NORVEL and WASP. I don't have a PAW .061.
An .09 may have more power than you need for stunting, although with longer lines it may be OK.
Good luck whichever way you go.
gcb
gcb
Post  nitroairplane Sun Aug 21, 2011 10:15 am
A paw I think is your best bet they are easily available and extremely easybto stet and reliable.
nitroairplane
nitroairplane
Post  microflitedude Sun Aug 21, 2011 12:56 pm
Thanks,
Using over 25% nitro will wear your motor out prematurely. Diesels will give you more torque than flat out speed. I'd go with a bigger engine.
microflitedude
microflitedude
Post  GermanBeez Sun Aug 21, 2011 1:01 pm
ditto.
GermanBeez
GermanBeez
Post  nitroairplane Sun Aug 21, 2011 3:55 pm
Thanks,
I always run and alway have run 25% .010 and .020 engines do not like anything less.
nitroairplane
nitroairplane
Post  RknRusty Sun Aug 21, 2011 10:42 pm
Looks like the difference between a Venom and a BW is the piston, cylinder porting and the crank. The BW has deeper porting than all the rest of the Bees except for the Venom, as far as I can tell. I compared the depth on every dual ported cylinder I have with a dial caliper. I don't see a Venom for sale on eBay or anywhere I checked quickly before I typed this reply. I'd like to have one if I can afford it. I could build one if I could get the piston/cylinder pair and a Killer Bee crank. Is the crank the same as a Tee Dee?
I am getting all I can get out of my BWs with 25% fuel. I'm not going to run 35%. I have tried a 5-3, 5-4 and 6-3 prop. But I am using regular glow heads. The heads I bought from Bernie ran super fast for a few laps and fried. I was told to use 2 spacers to prevent that from happening. Right now I think I have old Cox made heads on them. They run really good fast and steady. Of the three BWs I own, one is significantly faster. I think it's just one of those diamonds in the rough. I use it on my Jumpin' Bean, but I might swap them between the two planes and see what happens. The oldest one, I bought in '93 has a mismatched piston in the cylinder(my screwup) but it seems to run fine on the rare occasion I use it. I suppose it would be a bad idea to put a new piston in it.
Post  GermanBeez Mon Aug 22, 2011 2:05 am
the thing with the venom was a joke Very Happy Very Happy
you should look at matt and bernie's custom engines which they sell in their shop. they sell
them for a very reasonable price and are quite pretty.
this one here even has a lightened piston:
http://www.exmodelengines.com/product.php?productid=17565&cat=256&page=2
but if you're looking for serious rpms, this one might just suit you:
http://coxengines.ca/product.php?productid=327&cat=37&page=1
that pretty much matches venom performance
GermanBeez
GermanBeez
Post  RknRusty Mon Aug 22, 2011 3:30 am
GermanBeez wrote:the thing with the venom was a joke Very Happy Very Happy
I need something with more pulling power than a Black Widow. Suggestions? Slaphead Doh!
GermanBeez wrote:...but if you're looking for serious rpms, this one might just suit you:
I put that red backplate on the back of a BW that I'm using on my Stuntman that I converted to an external tank. But I may be having fuel feed problems due to positioning. It's a work in progress. It ran fast on the test block but it sounded about like the stock BW. That package might be faster with the new style SPI. I've never tried one of those piston/cylinder sets. That might be the answer if i get it positioned correctly though. Thanks.
Post  GermanBeez Mon Aug 22, 2011 3:56 am
yeah, can understand that the BW would not perform much better with the high flow back plate, as its
stock tank already has a larger venturi diameter. you can also buy seperate crank shafts, milled
after the original killer bee ones, they're called "killer cranks"
both bernie and matt have em.
GermanBeez
GermanBeez
Post  RknRusty Mon Aug 22, 2011 11:45 am
Well at least it flies right now. I'm going to put the faster BW on it and move on to my next project. I'm starting my first scratch build. I want a speed demon of a stunt plane, and started to make a Little Devil to replace my old busted one with some mods. But everyone at RCG in the Builders Workshop says it's a dud. So I'm going to get bold and design it myself. A first for me.
I started a blog in my profile over there about building the Little Devil, so I guess I'll have to delete it and start another. You can see in the builders workshop where I was headed off from wasting balsa on a kludge. The thread is [bleep] "how to shape a hollow log" or something like that. But I thank all of you who took an interest in my thread. When I get the big money Rolling Eyes , I'll invest in a hot power plant for the Stuntman.
Post  gcb Mon Aug 22, 2011 7:05 pm
Don't be discouraged with the Scientific Little Devil. There may be better planes but look at the memories you have tied up in it.
I had one back in the mid fifties when they had the thicker (~3/16") airfoiled wings. Remember that those planes were mostly designed for the OK Cub and the tank was buried in the fuselage. Using something like a Black Widow will put the CG forward and cause it to be nose heavy. If you re-consider it, think "product" engine without a tank...perhaps a Sure Start, although you might consider removing the choke tube, or even use the older 290 (pre choke tube).
Mine used a Space Bug Jr. and it was a bit nose heavy.
BTW, what is RCG?
gcb
gcb
Post  andrew Mon Aug 22, 2011 8:17 pm
gcb wrote:
BTW, what is RCG?
George --
I think he's referring to the RC Groups forum.
Post  RknRusty Mon Aug 22, 2011 8:55 pm
gcb wrote:Don't be discouraged with the Scientific Little Devil. There may be better planes but look at the memories you have tied up in it.
BTW, what is RCG?
I have one of the large bore red backplates and a wedge tank to run with the front end of a Black Widow.
Like this:I need something with more pulling power than a Black Widow. Suggestions? Th_image
That was the plan. I think I'm going to go ahead and build it since I have the balsa block. But for my wild urges I'm also going to build a combat plane like a Li'l Satan, or a similar one a member at RC Groups suggested. I'll start calling it "RC Groups" instead of "RCG." A lot of us here at the Cox Engines Forum came from there.
Post  gcb Tue Aug 23, 2011 6:31 pm
Rusty,
Thanks. I checked out RCG...come to find out I had joined it in Sept 2008. My interest lies mostly in CL, although I still have three ancient RC sets. There was not much CL activity back then so I stopped going there. Think I'll start checking it again.
I came over here from another CL site. Seems to be some of the same folks on various sites. Very Happy
gcb
gcb
Post  nitroairplane Tue Aug 23, 2011 6:40 pm
gcb wrote:Rusty,
Then i am guessing you came from another one of my links probably on RCU i am on all sites under the same name.
nitroairplane
nitroairplane
Post  dckrsn Tue Aug 23, 2011 6:51 pm
Thanks,
Rusty,
Just my $.02.
Have you considdered trying a
new piston/cylinder assembly to
breath some life into that
Black Widdow?
Post  RknRusty Tue Aug 23, 2011 8:44 pm
Thanks,
Rusty,
Just my $.02.
Black Widdow?
That engine only has about an hour on it. I bought two brand new ones in June. They had been in the box since 1995, so before I broke them in, I replaced the venturi o-rings, cleaned them out with denatured alcohol and lint free rags(I finally learned that paper and linen towels can cause irregular fuel flow through the tiny orifice). You can't get a cylinder with bypass ports like the #1 any more. They look like other SPI dual port cylinders, but if you measure with a caliper, the #1 has significantly deeper ports. So when they wear out... they are gone.
